2014 Auto Tranny linkage question - Mustang Evolution
Old 10-12-2014, 08:12 AM   #1
Is the linkage on my transmission mechanical or electronic? When I put my car in reverse, for instance, is that a mechanical response or does the gear selector tell a computer to put it in reverse?
BrewGuy is offline   Reply With Quote
Old 10-13-2014, 09:44 AM   #2
It tells the computer what to do.
The automatic transmission is controlled by your computer. That is why having a good tuner can really benefit an automatic transmission. Change shift points and increase shift change time is all controllable through the CPU.
This is nothing new. It has been this way since the mid eighty's on a lot of different cars. About 97 up I think 98% of the automatic transmissions went this way.
It's not really a bad thing because it does work very well.
Old 10-13-2014, 10:04 AM   #3
Voltwings's Avatar
If it were mechanical, you would be driving a standard
Old 10-13-2014, 10:44 AM   #4
Not sure I understand the question, but there is a mechanical connection between the shifter and the transmission. The computer still has the final say over shifts however.
2011 Mustang 3.7: 13.2 @ 105
BBK Shorty, MRT H, Borla S, 3.55 Gear, MPT Tuned.
LiveWire003 is offline   Reply With Quote
Old 10-14-2014, 08:11 PM   #5
What I am asking is, when I put my car in reverse, is the shifter pulling a linkage to the transmission to put it in reverse? Or is it telling the computer to tell the transmission to give me reverse?
I know that these days the computer tells the transmission when to shift, it used to be hydraulic pressure that determined shifting points. But that is after I put it in drive. Does linkage have anything to do with operating the transmission anymore? or does the shifter just tell the computer what you are requesting?
Old 10-15-2014, 06:44 AM   #6
Yes the shift linkage tell the transmission what to do
Although the transmission works with hydraulics it is the CPU that is the second in line after you, Telling the transmission what to do.
http://www.carparts.com/transmission.htm#Computer Controls
Read this and scroll down to where it says computer controls.
Auto tranny VS. Manual tranny x2bittz Classic Mustangs 15 06-29-2013 07:07 PM
Kick down linkage on a c4 BA68 mustang Classic Mustangs 4 11-17-2012 05:57 AM
Shifter does not move linkage on my trans? Mustang5 1979-1995 Mustang GT 8 01-11-2012 11:15 AM
shifter linkage on a toploader with hurst shifter gardgriff24 Classic Mustangs 7 03-02-2009 10:34 PM
fox body shift linkage for aod...help!!! svtlx 1979-1995 Mustang GT 4 05-07-2007 07:38 AM
07:10 PM
