Change in my gear shifter :/ - Mustang Evolution
Old 10-12-2014, 02:51 PM   #1
RomanG's Avatar
Hello forums i have an automatic tranny, over the few months of owning my car I've continuously made the mistake of placing change in the gear shifter. it eventually slides down into the hole as pointed out in the picture. It makes a ton of noise while driving lol I removed the center console to remove the change only to the shifter boxed in as shown in the picture.
does anyone have an idea as to how to open up this box safely to remove the change?
ID:	167767   Click image for larger version
RomanG is offline   Reply With Quote
Old 10-12-2014, 04:02 PM   #2
It's not me, it's you.
primer2tone's Avatar
Well, I've never removed an automatic shifter before but I'd assume you'd have to remove the top portion of the shift knob and then pry up the plastic cover surrounding the PND321 indicator. Do you see any screws or bolts that may be holding it in place?
Old 10-12-2014, 04:12 PM   #3
RomanG's Avatar
Thats what i was thinking, it seems to be a 2 piece box, separating top from bottom and it seems possible to open it up. i don't see any visible screws or bolts on any of the sides
Old 10-12-2014, 06:41 PM   #4
How about in front of the shifter? Any pilot holes or clips that might free up the shifter? I image once you get that off you could try to gently pry at the top cover.
Old 10-13-2014, 10:59 AM   #5
JoeyM91's Avatar
Use the disassembly guide from this shifter for the automatic. Go to Install Guide:
http://m.americanmuscle.com/tci-ratc...er-1013gt.html
Old 10-13-2014, 04:06 PM   #6
RomanG's Avatar
Looks complicated enough! Ill be giving it a shot thanks guys
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 10:20 AM
t-lok and gear set change 02V6TTcoupe Pre-2005 V6 Mustang 2 12-13-2006 02:45 PM
Gear change progress. SrATEX Pictures and Videos 5 03-01-2006 03:57 PM
Automatic Gear Shift Change luckyman Mustang Audio & Video 9 08-20-2003 06:50 PM
04:44 AM
