Transmission Cooler V6 Auto - Mustang Evolution
Old 10-13-2014, 11:04 AM   #1
sguevara's Avatar
Hey all!
A mechanic friend of mine is strongly recommending that I purchase a transmission cooler. He said that even as a DD it is a small investment for prolonging the life of the transmission.
I only have two bolt on mods: Airraid CAI and Borla axelbacks. I am also using an MPT performance tune (87 at the moment but have a 93 too).
AM sells them for under $100 and state that the installation is easy.
Thoughts?
-S
sguevara is offline   Reply With Quote
Old 10-13-2014, 11:24 AM   #2
Your mechanic friend is a wise man.
Anything that you can do to decrease the transmission temperature will increase it's life.
Old 10-13-2014, 12:04 PM   #3
FastFord13's Avatar
Agreed!
2013 3.7 Manual Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 10-13-2014, 12:05 PM   #4
Voltwings's Avatar
It wont hurt anything, but its not like 6r80s are dropping dead anyways. Personally i wouldn't waste the money. If you want to give your transmission a worth while improvement, take that same money and put in some quality fluid.
Old 10-13-2014, 01:12 PM   #5
Cooler is good if your going to run it hard a lot.
f you just drive it and get on it once in a while the cooler is not really what you would want. It's like anything that uses lubrication. You need a certain amount of heat not only to let the transmission function properly but the proper heat will keep the moisture away from inside the transmission.
Old 10-13-2014, 03:19 PM   #6
FastFord13's Avatar
True, but something for around a 100$ isn't a hefty investment along with some good fluid, after all heat is usually the #1 transmission killer. If your in a southern state I'd say not a bad investment for the cost.
Old 10-13-2014, 07:36 PM   #7
alrefire's Avatar
I'll be doing that with a stall and a cooler :p
Best to do it all at once "while I'm there"
The real... boss 227
Old 10-13-2014, 07:37 PM   #8
When I install a trans cooler, I route the fluid through the external cooler first, and then back into the radiator "cooler" (Or heater, as I like to call it) and then back into the transmission. That way, the fluid is still being warmed to operating temperature but (Hopefully!) it never exceeds the radiator coolant temperature.
You'll have to decide how long you're going to keep the car and how many miles that you plan to put on it, OP.
$100 dollars is cheap insurance for a transmission that could cost a few thousand to replace.
Old 10-13-2014, 08:15 PM   #9
JoeyM91's Avatar
You can get them for about $700 on ebay . Same with the MT82
Old 10-13-2014, 08:47 PM   #10
I still say it's not needed for a street car.
There are millions of cars of all makes and models driving around with no transmission coolers on their automatics. I would probably guess that almost all of them have never had a fluid or filter changed in 100,000 miles or more. They are still on the road with no problems.
I think it is a good idea to have the transmission flushed every 60 to 75 thousand miles if you plan on keeping your car forever. Use good trans fluid and a genuine Ford filter and you can be assured of a long living automatic.
If your going to be auto X-ing every weekend or tracking the car a transmission cooler will not hurt but it still is not really needed. I sure don't want one on a car I'm using every day though.
Old 10-13-2014, 08:58 PM   #11
FastFord13's Avatar
I had two t-birds, one 5.0 and 3.8 and both had transmission failures. The 3.8 at 125k and the 5.0 at 155k. Fluid was replaced regularly but still failed. Maybe the cooler would have help, maybe not, but for a relatively small investment it might have prolonged both transmissions. I think why people are interested is because it could be preventive maintenance at very low cost. I have invested quite a bit into my mustang already, another 100$ or so wouldn't hurt that could potentially help extend the life of my transmission if I had an auto. Hell up here 100$ is almost a tank of 91 gas lol.
Old 10-13-2014, 10:29 PM   #12
NewMtang's Avatar
One thing I didn't see, what state do you live in? If you live in Arizona or down on the border in California, your cooler would be better. Driving a DD in +100 or more heat would certainly do a lot more on the engine and the rest of the car.
If you live in Arkansas or Missouri, I think you could get buy without it.
Whomever said you should get a better transmission fluid is right. In fact everyone should be doing that. It's not that expensive.
MY TWO CENTS.
Old 10-14-2014, 02:44 AM   #13
bucko's Avatar
^^ This ^^
And flush the fluid every 30K, if you want long life out of ANY automatic transmission. Not just a pan drop, as that only gives you 3 to 4 quarts of fresh fluid; theres still several quarts of old stuff in the torque converter that only a proper flush will remove. Many auto manufacturers put a synthetic oil in the automatic, and this is good. However, they label it "lifetime", which is not good. I would not leave automatic transmission fluid in my transmission over 30K.
Old 10-14-2014, 04:28 AM   #14
Grabber Blue5.0's Avatar
The transmission coolers on these cars are huge and thus not needed to be upgraded.
12:00 AM
