Front wheel spacers? - Mustang Evolution
Old 10-14-2014, 09:54 PM   #1
RomanG's Avatar
Hello, does anyone have 1" or 1"5 inch wheel spacers in the front of your mustang? I have 5/16 and my center caps for my rims still dont fit so i was thinking about going 1 or 1.5 inch all around. I have 20x8.5 rims all around, would it fit in the front without any tire rub against the fender?
RomanG is offline   Reply With Quote
Old 10-15-2014, 07:23 AM   #2
Voltwings's Avatar
1" or 1.5" spacer? No way in hell would i run that. Even if it was hub centric, you're basically taking the weight off the hub and putting it on the wheel studs, which will break them. Not to mention the fact you'll need much longer (likely ARP) Wheel studs to insure adequate threading. You're asking for problems with that big of a spacer, i certainly would not risk it.
Are those rims designed for a Mustang? Sounds like you ended up with an offset thats WAY off somehow.
Old 10-15-2014, 07:37 AM   #3
RomanG's Avatar
Interesting, people seem to be more than content with their wheel spacers based off the reviews on american muscle. The offset is a little higher, 40 i believe but based off the American muscle guide, they can handle max 22'rims with 35-50 offset
Old 10-15-2014, 07:38 AM   #4
JoeyM91's Avatar
Agreed with Volt. That is way too much of a spacer. Those rims were not meant to go on that car with that kind of offset.
Old 10-15-2014, 07:41 AM   #5
RomanG's Avatar
To clarify i dont need a 1inch spacer minimum for the center cap to fit, i probably need 1/16 of an inch bigger to seat the cap perfectly flush. Have 5/16's on the front at the moment
Old 10-15-2014, 07:47 AM   #6
JoeyM91's Avatar
The biggest single spacer I see is 5/16th on AM. Then the hubcentrics like this one, but it's just shy of 1", sketchy.
http://m.americanmuscle.com/eibach-spacers-25mm.html
Might check Jegs or Summit for a 7/16ths. Just make sure the bolt pattern is correct.
Old 10-15-2014, 07:51 AM   #7
RomanG's Avatar
Yeah the wheel offset isnt that bad, its a bit higher, the black ball on the hub doesnt stick out past the wheel, im talking about 16's of an inch here nothing more than that. I was just curious about the 1-1.5 inch spacers
Old 10-15-2014, 08:34 AM   #8
Some good information
I take it you already removed the clips from the studs that held the disc on for assembly line purpose.
Here is some good information on Wheel spacers for you to know.
Installing Wheel Spacers- How to
Old 10-15-2014, 08:58 AM   #9
RomanG's Avatar
How thick is that clip? thick enough to not let the wheel sit down all the way not allowing the cap to sit flush?
---------- Post added at 07:58 AM ---------- Previous post was at 07:57 AM ----------
Im going to have to double check, can't remember
Old 10-15-2014, 09:07 AM   #10
Voltwings's Avatar
No, Its basically paper thin. What are those wheels from? If you're not in them for too much i'd honestly just sell them and get some proper wheels. Seen a lot of broken fenders / damage from when the studs break and the wheel falls off. By the time you get some proper Hub Centric spacers and longer ARP studs you're going to be in it for a few hundred anyways...
Old 10-15-2014, 09:30 AM   #11
RomanG's Avatar
Are you talking about with the spacers? My rims are 20x8.5 bolt pattern is 114.3 and the offset is 38.
According to American muscle, 22 is the max wheel size and the wheel well can fit from 35-50mm Offset. Ive had my rims on for about 9 months and have had no problems with them. I do my tire rotation every 3k miles and visually inspect my suspension components. A few friends of mine even have the same wheels and none of us have had problems
Old 10-15-2014, 09:33 AM   #12
RomanG's Avatar
The offset on the rims from american muscle average about 33-35 Also so mine isn't to off
Old 10-15-2014, 09:44 AM   #13
Voltwings's Avatar
Yes, im talking with spacers, since the weight often times gets put on the lugs.
You're also only taking 1 piece of the equation. a 10" rim with a +42 offset is not the same as an 8" rim with a +42 offset, then theres the back spacing, over all height, lip if any. Theres a lot of factors invovled, you cant just throw a blanket statement like "The offsets are similar" on there.
Old 10-15-2014, 09:49 AM   #14
RomanG's Avatar
Well the average i listed actually comes from 20x8.5 rims.. but I get what your saying. I am in the market for the new MMD Axim wheels, However I'm currently tackling my suspension. I haven't had any trouble with my current rims, the offset is a bother. OCD like that
Old 10-15-2014, 10:41 AM   #15
To answer this question
The clips were only put on for when the car was on the assembly line. On some NON-FORD wheels they will not let the wheel lay flat against the hub and must be removed. They are really not needed at all after the car came off the assembly line.
Old 10-16-2014, 06:43 AM   #16
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I personally don't like the idea of a wheel spacer on the front wheels. Just so many more factors that can cause failure on the fronts. All I can say is definitely make sure you go with a quality brand or else something like this can happen.
2012 Kona Blue 3.7L V6:
Old 10-16-2014, 07:24 AM   #17
RomanG's Avatar
I think theyre was confusion, i had meant wheel Adapters and not spacers.
Anyways, love the response he gave, knew exactly what happened
wheel spacers (adapters) OXstang11 Mustang Wheels & Tires 9 10-28-2005 11:42 AM
2 H&R 1" Wheel Spacers 5x114.3 tedness Mustang Parts for Sale and Wanted 6 10-18-2005 11:42 PM
wheel spacers own you tedness The Bar 22 04-21-2005 01:14 PM
Wheel Spacers 19ClearCobra96 1996-2004 Mustang GT 3 11-21-2004 03:18 PM
1.25" wheel spacers!!! a1yola Mustang Parts for Sale and Wanted 10 03-01-2004 05:53 PM
10:25 AM
