Governor - Mustang Evolution
Old 10-15-2014, 12:20 AM   #1
Governor
Where can I go to get my governor taken off of my 2014 base ? I want to see what my mustang can do.
pierre mason is offline   Reply With Quote
Old 10-15-2014, 12:41 AM   #2
14mustang v6's Avatar
Lol tbh I'd worry about getting wider tires and a new drive shaft before u test that out.. and the only way ur able to get ur governor off is if u tune ur car
2014 v6 blacked out.. the only way to do it. Airaid cai, bbk tb, 93htune, 3.73 gears, and magnaflow competition exhaust
14mustang v6 is offline   Reply With Quote
Old 10-15-2014, 12:43 AM   #3
I'll get the wider tires but have to find a place that can tune my car
Old 10-15-2014, 12:57 AM   #4
U can try bama, steeda, or Mpt there all good tuning companys
Old 10-15-2014, 12:57 AM   #5
Thanks
Old 10-15-2014, 05:11 AM   #6
audioAl's Avatar
You need speed rated tires for speeds over 120 mph and a tune to remove that.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 10-15-2014, 05:18 AM   #7
bucko's Avatar
And a legal place to drive at those speeds....
I too would recommend the one piece driveshaft and some suspension mods before attempting long term speeds.
Just keep it for the track. We like our members safe, along with the others you share the road with.
Old 10-15-2014, 07:25 AM   #8
AJcruz1's Avatar
Steeda & MPT are good. Bama is debatable.
AJcruz1 is offline   Reply With Quote
Old 10-15-2014, 07:40 AM   #9
JimC's Avatar
Didn't have any issues with my Bama tune. In fact the 93R was quicker than the 93R from MPT.
JimC is offline   Reply With Quote
Old 10-15-2014, 08:03 AM   #10
Voltwings's Avatar
^^ You'd be the only one. Also, like has been said, the factory speed limiter is based on the speed rating of the factory tires. Its there for a reason. However, assuming you still have the 2.73s installed, you'll likely get bored or run out of road before you get close to that lol.
Old 10-15-2014, 09:25 AM   #11
ponie1992's Avatar
Hmmm... maybe you can explain why my '12 PP V6 has the same limiter. I don't think it's limited because of the tires since mine has the Pirellis.
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 10-15-2014, 09:41 AM   #12
Voltwings's Avatar
Hmm. I know thats how it was for a while, but it looks like those Pirellis have a speed rating W which is 168 mph. I stand corrected lol, maybe since the V6 comes with so many different options the tune is just calibrated for the weakest tire in the line up.
Old 10-15-2014, 09:51 AM   #13
We're tuned at 120ish, Because our stock driveshaft will get us killed when it breaks at a higher speed.
RushGotti is offline   Reply With Quote
Old 10-15-2014, 10:12 AM   #14
JoeyM91's Avatar
Only if you run it ragged at those speeds.
It's weak, yes. Should you replace it? Definitely. It's not going to explode the minute you hit 130 though.
Old 10-15-2014, 11:35 AM   #15
Geok.91's Avatar
I beg to differ watch this http://youtu.be/LZXBjVIrR08
---------- Post added at 11:35 AM ---------- Previous post was at 11:34 AM ----------
Watch at 130 it starts making funny noise
Geok.91 is offline   Reply With Quote
Old 10-15-2014, 11:36 AM   #16
JoeyM91's Avatar
Everyone and their mother has seen that video. There have been 2 incidents of this. Two. The videos also don't explain any underlying issues or the full situation.
Old 10-15-2014, 11:42 AM   #17
Geok.91's Avatar
The situation was he hit high speed on a 2 piece drive shaft it broke soooo be careful if you plan to do the same
Old 10-15-2014, 12:25 PM   #18
I know it's not, But why risk it?
I've been past 120 multiple times and each time I do it, I regret doing it because of that "What if?" feeling.
Old 10-15-2014, 12:57 PM   #19
2011 Kona Blue's Avatar
Like the others said. If you want to remove the speed governor you will need to get the car tuned. Via Bama, Steeda, MPT, Lund, VMP and so on.
I would defently recommend a one aluminum piece driveshaft as well bro.
The Mustang Source Website is complete trash and the moderators are complete toolbags. TMS, Go F yourselves!
Old 10-15-2014, 05:05 PM   #20
NewMtang's Avatar
The Mustang V6 is speed limited to 112 mph from the factory.
The Mustang GT is speed limited to 145 mph from the factory.
You can bet money that they factory has set the Limiter higher to be safe from lawsuits.
Speaking for myself, I have a Bama tuner. I was told the software wouldn't be sold unless I can prove I had purchased or had ordered a new driveshaft. As I purchased my tuner from American Muscle, others might encounter a different policy for their purchases.
Old 10-15-2014, 05:08 PM   #21
ponie1992's Avatar
I thought the limiter was like 117 or 118 mph.
Jeremy
2016 Ruby Red PP GT
Old 10-15-2014, 05:09 PM   #22
Awesome . I've got up to 123 mph in mine though .
Old 10-15-2014, 05:09 PM   #23
ponie1992's Avatar
Yeah, they just limited across the board I'd say.
Jeremy
2016 Ruby Red PP GT
Old 10-15-2014, 06:11 PM   #24
Actually, the only thing AM asks you if you have a one piece driveshaft in order for them to remove the speed limiter. Everybody and there mother is just gonna say , yeah I got a one piece. Ha ha ha ha
need help removen a speed governor 1stang2live4 Pre-2005 V6 Mustang 54 07-08-2008 06:40 PM
During Bill Clinton's time as Governor/President at7311 The Bar 16 05-22-2008 09:32 PM
Lookin to get rid of governor Winger Pre-2005 V6 Mustang 27 05-15-2007 03:33 PM
Alabama Governor calls for boycott of Aruba Brent The Bar 24 11-10-2005 02:21 PM
The governor of texas....... damustangfan14 The Bar 19 02-08-2004 01:01 PM
02:41 PM
