2011 stang convertible leaks in heavy rains - Mustang Evolution
Old 10-16-2014, 02:10 PM   #1
Guys,
Help please. I have a 2011 convertible. the last two heavy rains have left me with puddles in the passenger side floor boards.
i dont believe its coming from the convertible top or windows as there is no evidence of water there.
i havent really gotten down and looked in the well but my guess is its coming in through the outer body some where.
anyone have any experience with this?
thanks.
Runingwithpower is offline   Reply With Quote
Old 10-16-2014, 02:19 PM   #2
bazinga11's Avatar
It could be your windows werent shut properly the night it rained. Happened to me on my previous car where I literally had to drain a full bucket of water from passenger floor boards.
Use a vacum that people use to dry rugs, keep your windows shut nicely and see if it stays dry the next rainfall.
|| ~BlackOnBlack~ ||
Old 10-20-2014, 10:20 AM   #3
found the trouble. on the passenger side in front of the wipers is a plastic covering. took that off. below that is the cabin air filter and below that there is a semi circular rubber drain. leave refuse had built up there and clogged the drain. this caused water to back up and flow through the cabin filter down into the footwell of the car. good thing i found it as on that outer wall is the interior fuse box.
if this occurs to anyone there is a video on youtube.
Old 10-20-2014, 10:40 AM   #4
bazinga11's Avatar
Perfect! Thanks for sharing the info. Also, did you notice any foul smell coming off from your vents each time you turned the fan on?
Now that I think about it, I remember my civic smelled like shiet whenever I turned AC/defrost on. I thought it was due to excessive pungent water/wet mats, but seems like it was a clogged up drain.
|| ~BlackOnBlack~ ||
Old 10-21-2014, 01:57 PM   #5
no foul smell but im still putting the top down at 50 degrees. wth. i just wear a coat.
it's like flying.
never felt this way about a car before. top down, roaring home from work (benefits of opposite commute) 500 shaker going and im giddy like a schoolgirl.
When it rains......... Ken The Bar 30 03-24-2011 08:37 PM
When it rains rickf73 General Car Discussion 15 11-03-2009 12:30 PM
What does it make you feel like when it rains? eljin The Bar 17 08-17-2009 02:42 PM
another prime example of "when it rains people cant drive for sh*t" Bane- The Bar 14 10-18-2004 01:09 AM
2000 Convertible Top Leaks sctalbott Pre-2005 V6 Mustang 2 11-10-2003 09:58 PM
05:36 PM
