Forged bottom end - Mustang Evolution
Old 10-19-2014, 07:01 AM   #1
Daveauth21's Avatar
Forged bottom end
Ok so I'm currently researching on what all is needed to do a basic bottom end job. Where all you built guys getting your rotating assembly from? I see supersix offers pistions but no rods or crank. MMR shows complete rotating assemblies but from what I read they might not have them instock. LPF said they will offer these services at a later date. What should one do, if wanting to build up their bottom end.
Sent from my HTC6600LVW using Mustang Evolution mobile app
Daveauth21 is offline   Reply With Quote
Old 10-19-2014, 07:33 AM   #2
AJcruz1's Avatar
You already have a forged bottom end (crank). You mean Pistons and rods is what your looking for?
AJcruz1 is offline   Reply With Quote
Old 10-19-2014, 07:49 AM   #3
I may be wrong on this
I thought I read someplace that the 3.7 V6 already had Forged Rods and crank, It may or may not only would need pistons depending on what you are doing to it.
From the turbo 3.7's I have seen and read about they all seem to do nothing to the engine and have no problems at all.
The 10 second CFM 3.7 owner is not touching anything inside the engine until it blows. So far it has not blown up.
The 3.7 Ford engine is used in the Ford trucks and is built very sturdy to begin with.
Old 10-19-2014, 08:35 AM   #4
Daveauth21's Avatar
Ford 3.7 has a powder forged crank and rods. Pistions are not forged.
Old 10-19-2014, 08:39 AM   #5
Daveauth21's Avatar
I will run my car with a procharger but plan on forging the bottom end. While the crank and rods are powder forged if I'm opening the engine to change out the pistions I just as soon change out the rods and crank to a stronger forged type.
Old 10-19-2014, 08:43 AM   #6
Thanks A Lot
That is what I thought I had read more then once on these forums.
I know it is really a very sturdy engine and not only used in Ford trucks but a few Imported cars and trucks use this engine.
I know I really like my 3.7 Cyclone and had a few chances to get a V8 but turned it down every time. I like the MPG, Power, Insurance rate, MPG ( Oh I already said that) and I hope this engine will last at least 100,000 miles or more before it wears out.
Old 10-19-2014, 08:51 AM   #7
Daveauth21's Avatar
My overall plans are to run mid 11 1/4 I think that's fast enough for a daily driver I'm just concerned that the engine might not like being pushed that hard with boost for a long time. It would be nice to get 60k out of the stock engine with high boost.
Old 10-19-2014, 11:02 AM   #8
Voltwings's Avatar
mid 11s will not be very demanding from the 3.7, nor will the amount of boost needed to get there from a procharger. Prochargers are nice to an engine in a sense that they don't make a lot of torque, I'd say a basic set up with around 450 whp 375 wtq is enough to get you into the 11s with proper tire and suspension and be fine on the stock motor.
You're talking about adding thousands of dollars to a build that just aren't necessary to mid 11s.
Old 10-19-2014, 11:24 AM   #9
Daveauth21's Avatar
It's definitely not necessary to build the bottom end for a mid 11s 1/4 run but for overall durability and longevity I would feel more comfortable with it built. Plus who knows I might decide to up the boost and run a d1 head unit down the road.
Old 10-23-2014, 05:57 PM   #10
ak_stang's Avatar
Region: Alaska
I believe The 3.7 has the same bottom end as the 3.5 ecoboost in the f150 since they are basically the same engine, in the f150 that engine is making 365 hp and 420 tq . The 3.7 is just a bored out 3.5
Sent from my LG-D801 using Mustang Evolution mobile app
ak_stang is offline   Reply With Quote
Forged bottom end? DtrMustang 2005-2010 Mustang GT 0 04-06-2014 07:57 PM
forged bottom 3.8 Blackedout Pre-2005 V6 Mustang 19 10-09-2012 10:59 AM
low power in bottom end stangman81 1996-2004 Mustang GT 6 08-22-2008 02:41 PM
Blew my bottom end up (kind of)... its rebuild time. Zim 1979-1995 Mustang GT 45 06-14-2007 09:54 PM
why not to run 600hp on the stock bottom end of a 99 cobra fast64 The Bar 10 08-13-2004 04:28 PM
05:05 AM
