Single Mass Flywheel and Alu driveshaft - Mustang Evolution
Old 10-21-2014, 06:47 PM   #1
So I had an issue several months ago where Ford didn't have a duel mass wheel for me and I ended up putting a Ram Billet Steel flywheel in. The car was new to me, only had a few hours in it, so I can't really comment on the differences between the two- but it revs nice with this one. I am getting a rattling/ chatter sound and am being told by Ford that it's backlash from the lighter single mass wheel.
I've only had my stang since July so I haven't done many mods yet. Put in the Blowfish shifter bracket ( big improvement) and a GT sound tube ( because I like it). I'd like to continue refining the ride of the car and I'm thinking about an aluminum drive shaft next. The car clunks a little on low speed shifts ( where I can hear it) and I've been told this in the stock shaft.
The question is: does anyone know if the aluminum driveshaft with have an effect on the noise created but the single mass wheel? I couldn't live with it getting worse and would really like to quiet it down. Any advise??
Ppkonablue12 is offline   Reply With Quote
Old 10-21-2014, 08:15 PM   #2
Voltwings's Avatar
That's just the nature of the beast with a lighter mass flywheel. The clutch really only chatters in neutral, or low speeds, where the driveshaft isn't much (if any) of a factor anyways. I believe it will be fine. Or at the very least not get worse.
Old 10-21-2014, 09:19 PM   #3
Thanks Voltwings. Do you know if the AD will quiet down the shifts... those clunks?
Old 10-22-2014, 04:46 AM   #4
UltArc's Avatar
A lot of people found that the one piece DS helped things, but not me. Maybe acceleration and fuel economy a bit, but that mild clunking sound is now an obvious clunking sound. At low speeds, it can act weird, too.
What I mean is, say it's morning. I hop in the stang, clutch in, first gear, start the engine, let the clutch out smoothly. It pulls to 7-8 mph, kind of bucks, and then is doing like 5. Sometimes it keeps it at 8.
I don't know much about how DS work (beyond the obvious spinning, I mean like the physics), but I believe the two piece is quieter because bit has that play in the middle. That joint (I imagine) would allow some play and reduce noise and aggressiveness.
Luke 11:9-10 “So I say to you ...*search and you will find; knock and the door will be opened to you.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 10-22-2014, 06:50 AM   #5
Crap, I was hoping for something a little more straight forward... hate to jump in when there's been mixed results.
Old 10-22-2014, 08:36 AM   #6
5pointYoBro's Avatar
I have an auto and the DS helped a lot with vibration in 6th gear at low rpm. Also acceleration
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 10-23-2014, 03:33 AM   #7
UltArc's Avatar
I don't experience any vibration from it, although I did not note any before. The DSS DS I got seems like a great product.
Old 10-23-2014, 07:05 AM   #8
It didn't change much for me. I still have the same chatter, and the clunks will be about the same in my opinion as it's less rotating mass but a more direct driveline vs the 2 piece.
2014 Mustang Deep Impact Blue, Appearance, Tech, Airaid Intake, Pypes Pipes Bombs exhaust, Bama Tune, Steeda LCA, Steeda UPR control arm, SR Performance Springs,
gandy.zachary1 is offline   Reply With Quote
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
Duel mass flywheel??? FastFord13 2011-2014 V6 Mustang 0 06-30-2013 08:57 AM
Clutch and Flywheel Stang23 2005-2010 Mustang GT 8 12-16-2011 07:56 PM
SPEC Flywheel, pressure plate, disk and bearings Foxone Mustang Parts for Sale and Wanted 1 07-19-2010 05:36 PM
Where's the best place to find/buy a new clutch kit and flywheel for a 200 Ford Mustang V6? dunmore General Mustang Discussion 3 04-11-2010 02:50 PM
04:28 AM
