procharger supercharger - Mustang Evolution
Old 10-21-2014, 09:19 PM   #1
elkoritaNAY's Avatar
for those who have already installed this beautiful piece of machinery... my question goes: what other unforeseen mods will I need to make?
Flowmaster force 2 exhaust, jlt cai, x4 bama tuner, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit
elkoritaNAY is offline   Reply With Quote
Old 10-21-2014, 09:41 PM   #2
bazinga11's Avatar
Lol bro I thought this was covered a few weeks ago in a separate thread. Oh wells.
|| ~BlackOnBlack~ ||
Old 10-22-2014, 12:38 AM   #3
Daveauth21's Avatar
Things needed for FI
Sent from my HTC6600LVW using Mustang Evolution mobile app
Daveauth21 is offline   Reply With Quote
Old 10-22-2014, 09:59 AM   #4
this thread is not answering the question: basically if I install a procharger supercharger kit what else would I need to do to my car whther it be now or a year from now because of the install
Old 10-22-2014, 10:01 AM   #5
Daveauth21's Avatar
If you purchase a complete kit everything needed is there. Only thing that would be greatly beneficial would be a dyno tune. What year and type of transmission do you have?
Old 10-22-2014, 10:03 AM   #6
Daveauth21's Avatar
Fyi, my car will have dual catch cans,full exhaust,3.85 pulley,65lb injectors and a good dyno tune. Lower control arms will help with traction as will drag radicals.
Old 10-22-2014, 10:27 AM   #7
14 base v6 only performance mods are exhaust CAI ad tune nothing else. everything else is stock... if the procharger will cause wear and tear (I'm not gonna drive it hard, but I'm concerned that wear and tear will be coming sooner rather than later w this piece of fine machinery.
Old 10-22-2014, 10:36 AM   #8
bazinga11's Avatar
Procharger supercharger 2014 v6
I'm too lazy to type it up again, check this thread where I have posted previously as to what you 'might' need.
|| ~BlackOnBlack~ ||
Old 10-22-2014, 11:01 AM   #9
so a 5k investment will actually cost a couple of thousand more? wth
Old 10-22-2014, 11:06 AM   #10
Rapinator126's Avatar
Just go turbo, there is a reason everyone who had the procharger on the v6 took it off, it's not worth the money, actually pretty depressing
Old 10-22-2014, 11:09 AM   #11
depressing as in power gains and more and more mods required? I will have to research more on turbo. My initial thoughts have been go supercharger as install is a breeze, but I'm afraid my stock car (as a direct result of more power) is going to need way way more modifications.
Old 10-22-2014, 11:10 AM   #12
Daveauth21's Avatar
I thing all 3.7s should upgrade to a one piece driveshaft. The clutch will need to be replace soon or later(just the nature of the beast),at least one catch can and a oil drain line(to make life easier)for the procharger. It's hard to say you only need the purchase the kit and that's it .There are other aspects of the car that needs upgrades as well but not 100% necessary. For instance control arms and tires are not completely necessary buy without them you'll bounce and spin all day long.
Old 10-22-2014, 11:43 AM   #13
Voltwings's Avatar
Why two catch cans, and how do you plan on routing them ...
Old 10-22-2014, 11:56 AM   #14
Daveauth21's Avatar
One on each side, passenger side valve cover to intake manifold. Driver side valve cover to procharger air inlet tube. I want to catch as much oil as I can. The way procharger has the driver's side pvc line running from valve cover to inlet tube letting blow by oil enter the procharger then enter the intercoller.
Old 10-22-2014, 12:04 PM   #15
Voltwings's Avatar
Just making sure you realized the Drivers side would only ever make a difference at WOT. Also, keep an eye on the check valve they send you on the passenger side, a buddy of mine had his fail and was actually boosting the crankcase.
What we did in his case was route both valve covers to a single catch can, then tie that into the intake. This way, the IM was capped off and there was no need for a check valve, and the intake would actively pull a vacuum on the crankcase at WOT eliminating any potential CC pressure. Worked very well in his case, and even during daily driving the nature of the procharger will put vacuum on the crankcase. You could possibly save some money (or time and effort) and just go with 1 large can instead of two. Just something to think about.
Old 10-22-2014, 12:07 PM   #16
Daveauth21's Avatar
Thanks I'll look into that, I currently have two JLT catch cans sitting in my garage.
Old 10-22-2014, 01:01 PM   #17
Daveauth21's Avatar
Double post
Old 10-22-2014, 03:50 PM   #18
any one know how much twin screw would cost or if available on v6?
Old 10-22-2014, 06:24 PM   #19
JimC's Avatar
There is no positive displacement blower option. The 60 degree configuration doesn't work
JimC is offline   Reply With Quote
Old 10-23-2014, 01:42 AM   #20
2011fastford's Avatar
Region: New Mexico
i reccomend getting the tuner kit getting your own injectors and taking it to get dynotuned. my car made 406rwhp and 336rwtq on 6lbs with my auto
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 10-23-2014, 07:00 AM   #21
Dyno tune is a MUST for any extra modifications. And your going to need more anti-freeze. Along w/ typically a wideband air sensor of some sort since our cars don't come w/ it from the factory.
2014 Mustang Deep Impact Blue, Appearance, Tech, Airaid Intake, Pypes Pipes Bombs exhaust, Bama Tune, Steeda LCA, Steeda UPR control arm, SR Performance Springs,
gandy.zachary1 is offline   Reply With Quote
Old 10-23-2014, 09:51 AM   #22
Voltwings's Avatar
The car is equipped with a factory wideband, that's the reason we can tune via email; because the tuner has access to a live readout of the AFR. The car does not come with a gauge to display AFR however, if that's what you meant.
Old 10-23-2014, 09:53 AM   #23
do u have some clips or videos that i can see of the setup and/or you using ur car?
Old 10-23-2014, 09:20 PM   #24
Region: New Mexico
http://m.youtube.com/results?q=2011fastford&sm=3
there's a lot of videos on my youtube channel feel free to check em out
Procharger supercharger in CA Shengzhe 2011-2014 V6 Mustang 2 07-19-2014 11:48 AM
Procharger d1 supercharger Mmustang01 Mustang Parts for Sale and Wanted 0 08-15-2012 09:05 PM
Procharger or Supercharger? Jackal43x 2011-2014 Mustang GT 6 07-10-2012 03:02 PM
Supercharger or Procharger Reddragon New Member Introductions & Greetings 9 03-03-2007 11:31 AM
P-1SC ATI Procharger Supercharger Kit 99-04 V6 Mustang V6Pak Mustang Parts for Sale and Wanted 6 01-18-2005 03:38 PM
05:18 AM
