Rattling at High Speeds - Mustang Evolution
Old 10-24-2014, 11:31 AM   #1
VTHokiez's Avatar
Has anyone else experienced an obnoxious rattling noise near the passengers' side from wheel well at high speeds? It sounds like something is flapping in the wind, but I can't figure out what it is. I've checked wheel well lining and side-view mirror. Thoughts?
VTHokiez is offline   Reply With Quote
Old 10-24-2014, 11:35 AM   #2
DiESeven's Avatar
Does it sound like something that is attached to the car flapping around or does it sound like something that is bouncing around in there? Maybe a rock or something that's caught in an unusual place just having the time of its life?
Old 10-24-2014, 11:37 AM   #3
VTHokiez's Avatar
It sounds like something flapping, as it gets progressively louder the faster I go. I can't even drown it out with the radio at 75 MPH
Old 10-24-2014, 11:39 AM   #4
DiESeven's Avatar
Have you removed your wind deflector recently? Could there be a screw/bolt that loosened up causing some part of your car to flap a little bit? Maybe check your driver side too, as well as under the entire car. Not sure what it might be.
Old 10-24-2014, 11:51 AM   #5
SixBanger's Avatar
It could really be anything. Start with a full inspection. If anything feels loose then start with that. I'm sorry I don't have a real answer, but you've got to just troubleshoot this from every part of the car.
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 10-24-2014, 02:24 PM   #6
JoeyM91's Avatar
Check this. I had the exact thing when I changed my cabin filter. I didn't snap it down quite well enough and it chattered the whole way to work till I found it and pressed it back down firmly.
Old 10-24-2014, 05:36 PM   #7
Check your wheel well lining thing. Is it a fender liner? I don't know the term. It's plastic, it's in the gender, it's huge, it's held on w plastic clips. Check those.
Wysh is offline   Reply With Quote
Old 10-24-2014, 06:49 PM   #8
natestang07's Avatar
I think that is the splash guard but could be wrong
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 10-25-2014, 08:23 AM   #9
armymustang's Avatar
I was on the autobahn and I ended up tearing the air deflector under the engine just a bit and it would flap bad. I ended up pulling off and taking that whole cardboard part off. Thease cars weren't meant to cruise at 125
armymustang is offline   Reply With Quote
Old 10-25-2014, 09:40 AM   #10
dj2014's Avatar
I had to remove this piece to run my amp wire and after re-installing it, it rattled at higher speeds, so I re-attached it and that stopped the rattling noise.
2014 Ruby Red V6 Premium, Pony Package, Magnaflow Street Axle-backs, MMD Hood Struts, SCT X4 with Steeda lifetime tunes, Boss 302 Strut tower brace, JLT Oil Separator, OEM extended range remote start, Raxiom Navigation.
dj2014 is offline   Reply With Quote
Old 10-28-2014, 04:54 PM   #11
VTHokiez's Avatar
I think it's the wheel well liner... I adjusted it this weekend, and it helped. Still isn't gone, but now I'll let Ford deal with it! Thanks for all of the help!
top speeds 2300turboford General Car Discussion 75 05-24-2012 06:39 PM
lots of water and car is stalling at highway speeds Pureoctane2001 SVT Mustang 6 06-07-2011 02:30 PM
91 GT shifting into 3rd at parking lot speeds (~15-20 MPH) 91StangGT5.0 1979-1995 Mustang GT 31 06-01-2011 04:01 PM
Freakin Awesome. Comcast Ups Their Upload Speeds Brent The Bar 5 07-05-2008 03:47 PM
09:36 AM
