Ford Handling Pkg vs Eibach Pro Kit - Mustang Evolution
Old 10-31-2014, 04:27 PM   #1
Hey all does anyone have any experience with the handling package for the V6? One of my friends has the Ford kit with struts, springs, sways, etc.and is looking to make a deal, but I've heard really good things about the Eibach Pro Plus Kit (~1k). Which one should I go with? Does it matter?
Sent from my XT875 using Mustang Evolution mobile app
2011 Fully-loaded V6 Premium
PythonV6 is offline   Reply With Quote
Old 10-31-2014, 04:35 PM   #2
JoeyM91's Avatar
Eibach. The FRPP is okay, but for the same price you can get a better quality Eibach kit.
Old 10-31-2014, 06:43 PM   #3
What exactly is bad about FRPP vs. the Eibach? It should be noted this isn't a retail comparison. It's 1k for the Eibach and X for the FRPP, where X is some steeply discounted number from retail.
So the question is this: for the money, is a retail Eibach kit still better than a discounted (70% retail or less) FRPP kit?
Old 10-31-2014, 06:48 PM   #4
JoeyM91's Avatar
How much exactly is the kit you're considering? A good complete kit from eibach is about $1000. Last I checked retail on the FRPP is around $1400. Eibach is better simply because of quality and durability, cost is another benefit.
Old 10-31-2014, 07:13 PM   #5
NewMtang's Avatar
Three things that the Ford Package has that the Eibach package doesn't.
Ford:
What's in the box?
(2) Struts
(2) Shocks
(4) Lowering Springs
(1) Front Sway Bar with bushings
(1) Rear Sway Bar with bushings
(1) Strut Tower Brace
Jounce stops
Front Strut Mount Upgrade
$1499
Eibach:
What's in the box?
Pro-Damper Front Struts
Pro-Damper Rear Shocks
Pro-Kit Lowering Springs
36mm Tubular Front Sway Bar
25mm Solid Rear Sway Bar
Front and Rear Sway Bar Bushings
$999
You will have to price out adding a Strut Tower Brace, Jounce Stops and Upgraded Front Strut Mounts, to be fair price wise.
I have the Ford and really like it.
Old 10-31-2014, 07:34 PM   #6
Commercial Member
au01st's Avatar
Also, is doesn't the Ford Racing strut tower brace connect to just two bolts on each side, where other companies make them that connect to all four bolts? Seems like one would be sturdier than the other...
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 11-03-2014, 12:55 AM   #7
Ford:
What's in the box?
(2) Struts
(2) Shocks
Jounce stops
$1499
Eibach:
What's in the box?
$999
Thanks for the opinions and additional info guys. I already have a tower brace, and I've heard additional support in favor of the Eibachs, so I think I'm going to go with that when the time comes.
Old 11-03-2014, 06:50 AM   #8
AJcruz1's Avatar
I wouldn't go with the Eibach kit as there dampers are sub par compared to others. FRPP (rebranded Tokico dampers) isn't much better but if your getting the package for 1K or less then it would be a good deal. If you plan on tracking your stang look elsewhere for suspension parts. Steeda, BMR, Koni, Ground Control just to name a few.
AJcruz1 is offline   Reply With Quote
Eibach pro kit or Ford K? Turtlestang39 2005-2010 Mustang GT 11 01-22-2013 10:10 AM
Eibach Pro-System-Plus vs. Eibach Sport-System-Plus MustangGT02 1996-2004 Mustang GT 15 01-12-2013 02:45 PM
Eibach Pro Kit vs Ford K Springs Ravnus 2011-2014 Mustang GT 12 06-30-2012 03:38 PM
Eibach Pro kit SVT_99_Cobra Mustang Parts for Sale and Wanted 2 06-09-2005 12:05 AM
eibach pro kit springs cagedthought Pre-2005 V6 Mustang 4 01-25-2005 09:33 PM
11:52 PM
