How do I make the Procharger run 10PSI?? - Mustang Evolution
Old 11-07-2014, 09:36 AM   #1
I read this in a different thread a couple days ago and saved it, But forgot to save the username of the poster...
You can add a "torque booster" to the procharger and end up with some fat torque. I personally am a fan of turbos, but as far as the 3.7 is concerned the procharger is the way to go.
Basically with a centrifugal supercharger, if you install a 10 psi pulley you get 10 psi somewhere around redline. With the torque booster, youd install a 15 or so psi pulley, and then add a 10 psi wastegate (psi can be adjusted via springs) on the cold side and voila; you now have 10 psi for virtually your whole pull since you're spinning the blower harder.
Seems like the easier and safer route to me. I believe LPFs problem is not a shoddie kit. Justin and I may not see eye to eye, but I have seen his work and even tuned some of his kits before. I don't question his fabrication skills. His ability to tune however, after seeing the fate of a few of his cars now, I do question. But that's enough of that.
Where can I get the stuff required to make the procharger run 10 PSI at all times like the user above said?
I see this right here :
Procharger 8 Rib Supercharger Pulleys - Justin's Performance Center
Which one would be the one required for 15PSI (As stated) and also what else exactly would I need?
I just ordered my procharger from AM.
RushGotti is offline   Reply With Quote
Old 11-07-2014, 09:45 AM   #2
Voltwings's Avatar
It was me, something like this is what you're looking for with a 10 psi spring. As far as what specific pulleys will get you there, that i do not know, you'll have to ask someone with a procharger.
Team Beefcake Racing "Torque Booster" for 2011-2014 Mustang 5.0's with Vortech / Paxtons
Also understand that this piece is designed for a 5.0 pipe route, it may not work with the v6 pipe route or diameter (though i believe both kits are 3"). It may be worth doing some googling and finding a 3" piece of straight pipe with a V-band such as this:
Tial Blow Off Valve Adapter- TREADSTONE PERFORMANCE
And just find a corresponding wastegate that will match that V-band. This may give you a little more versatility in placing the WG.
Also, you have a 6 rib blower kit, not an 8-rib, so those pulleys likely wont be the best choice.
Old 11-07-2014, 12:51 PM   #3
bazinga11's Avatar
Subscribed. I have looked around too, but could only find beefcake.
|| ~BlackOnBlack~ ||
Old 11-07-2014, 01:15 PM   #4
smurf stang's Avatar
Definitely give Terry a call.
2016 VW GTI 2.0 Turbo
Old 11-07-2014, 03:54 PM   #5
bazinga11's Avatar
I don't have fist hand knowledge about FI systems, is it true procharger built 1 psi of boost every 1000 rpms or so? If so, does it mean it will have 3 psi at 3k, and 7 psi at redline? Assuming it's a stock procharger kit with no upgrades.
Also, let's say you're using a 15psi pulley with 10psi waste gate like volt suggested. At what rpms can you expect to see your full 10 psi boost? Umm 3500-4000 rpm or even before?
|| ~BlackOnBlack~ ||
Old 11-07-2014, 06:09 PM   #6
Daveauth21's Avatar
The kit I have came with a 3.85 pulley and from what I can find this is a 9.5psi pulley. To run a pulley small enough to hit 15psi you would have to run 8 rib pulley and custom 8 rib crank as the procharger supplied pulleys are 6 rib. I've ran a 3.4 pulley on another car years ago and needed to swap over to a 8 rib set up due to the massive belt slip I was getting with the 6 rib.
Sent from my XT1254 using Mustang Evolution mobile app
Daveauth21 is offline   Reply With Quote
Old 11-07-2014, 06:27 PM   #7
Daveauth21's Avatar
Centrifugal superchargers build boost in a nonlinear way. Say you start making boost at 2000rpms then at 3000rpms your at 2 psi some where in the rpm range it will start to increase. Say at 4000rpms instead of 4 psi you might see 4.5 psi and at 5000rpms it might be 6 or 6.5 psi. This is of course just an example and not the boost curve of a procharged 3.7
Old 11-07-2014, 06:51 PM   #8
bazinga11's Avatar
I'm guessing you can upgrade to a D-1 procharger and a 8 rib setup when you order your kit? Is there any 'significant' advantage of going with a D1 blower instead of P1? I have read quite a bit about these two, but mostly on v8 cars pushing 625+ hp.
I completely understand what you're trying to say about the boost curve. However, I was wondering wouldn't your blower make 10psi of boost at around 5000rpm IF you're using a 15 psi pulley with a waste gate? Assuming you'll be pushing 15 psi at 7000 rpm.
Also, can your ecu/tune make a difference (to a certain degree) to how soon/late you're building boost. Sorry for noob questions, it's still uncharted territory for me.
|| ~BlackOnBlack~ ||
Old 11-07-2014, 08:59 PM   #9
Voltwings's Avatar
No, the waste gate controls the boost, so the max it will ever be is still only 10 psi, it will just see it much sooner, and thus have a stronger mid range.
Old 11-07-2014, 09:05 PM   #10
bazinga11's Avatar
Exactly that's what my question is/was. Is 'how soon' fairly subjective and depends from blower to blower?
|| ~BlackOnBlack~ ||
Old 11-08-2014, 06:41 AM   #11
Daveauth21's Avatar
You would have to find someone who has done that on a 3.7 mustang to get a answer on rpm vs psi with wastegate. I look around a few months ago but had no luck,as for the 8 rib pulley, yes you can get drive pulley for the blower but you will have to source your own crank pulley. Procharger only makes a 6 rib atleast that's what I was told when I called them a few months ago.
Let's make a what have you run thread! i973eat1 At the Track 13 08-26-2012 03:47 PM
Procharger or Paxton.. 5.0 373s 6MT.. Gotta make decision today! JG5.0 2011-2014 Mustang GT 42 07-16-2012 06:43 AM
Poles on batter got hooked up wrong. What do I have to fix to make it run again? makis 1979-1995 Mustang GT 5 12-11-2011 03:01 AM
I am trying to put a F2 ProCharger on a 67 Mustang, can I make it fit? sein 2.3 Mustang 2 03-06-2010 07:40 PM
Project Make Brent's Car Run Brent The Bar 19 06-30-2007 09:55 PM
01:27 PM
