Non Mechanic Needs Help. Please. - Mustang Evolution
Old 11-07-2014, 01:39 PM   #1
sguevara's Avatar
I've been hearing a knock in my rear end for the last month that is getting worse. I removed my spare tire but that wasn't the cause. I crawled underneath and inspected. The mufflers would not knock against anything when I would shake them. I checked the shocks and could see no leaks. The coils appeared to be okay, but couldn't get a great look.
Then I saw a leak!!!! What does this mean (see photo)? Could this be the culprit? And if it is what do I do?
Thank you friends for your insight.
-Sergio
Name:	ImageUploadedByMustang Evolution1415392723.158318.jpg
ID:	169353Click image for larger version
Name:	ImageUploadedByMustang Evolution1415392739.191831.jpg
sguevara is offline   Reply With Quote
Old 11-07-2014, 01:42 PM   #2
Socal Stangman's Avatar
If it is in fact a diff issue have it looked at. The diff is something a lot of driveway mechanics wont even touch, including myself, but for some one with no mechanical ability just have a pro look at. Warranty??
Old 11-07-2014, 01:43 PM   #3
sguevara's Avatar
4k passed warranty. I will have a pro look at it. Just concerned what I'm up against.
Tnx!
Old 11-07-2014, 01:46 PM   #4
natestang07's Avatar
http://mustangforums.com/forum/4-6l-...ial-fluid.html
it is very doable I thibk
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-07-2014, 02:07 PM   #5
JoeyM91's Avatar
Changing diff fluid is fairly easy, but that looks like a worn seal.
As for the OP, when you do have that fixed, I'd opt for an aftermarket diff cover with fill / empty holes. It will make life easier later.
Old 11-07-2014, 02:08 PM   #6
Good ole silicone gasket sealer
Old 11-07-2014, 05:54 PM   #7
Siber Express's Avatar
Tnx!
Is that 38,000 miles or 64,000, because drivetrain is 5 years 60,000 miles
Old 11-07-2014, 09:18 PM   #8
NewMtang's Avatar
Tnx!
Try taking it to the dealer anyway. Explain the problem and maybe the will fix it for "good will."
Nothing to lose.
Old 11-08-2014, 06:48 AM   #9
sguevara's Avatar
A friend found a TSB on it! Looks like I will be going to the dealer.
http://cdn.lrsstatic.com/downloads/t...sb12-08-15.pdf
Ford Mechanic or Your Mechanic 02_Mustang General Mustang Discussion 16 02-01-2013 04:53 PM
Mechanic Question. Please Help? tung General Mustang Discussion 7 03-29-2010 05:47 PM
96 mustang v6, found a nice one, brought to a mechanic, help me out? Tye General Mustang Discussion 12 03-24-2010 09:54 PM
needs some videos/pictures (please help, for a school project) fast64 The Bar 16 01-13-2005 09:37 PM
*Attention Marylanders*ISO Good Mechanic Neptuno Regional Mustang Discussion 1 09-05-2004 07:30 PM
08:26 PM
