Discoloration(?) on Tail lights (13-14). What can I do? - Mustang Evolution
Old 11-12-2014, 01:45 PM   #1
DiESeven's Avatar
Hey,
I tried searching for this both on google and this forum. Problem is... I'm not exactly sure what the correct term for this is so I am not finding the information I need.
Both of my tail lights have these streaks going from top to bottom. It is only on the outer part. You can see what I am talking about in the pictures. I noticed this recently and I am not sure what caused it. I can't seem to wash it off either.
Any ideas on what is could be and also how to get rid of it?
Name:	Tail light streaks (1).JPG
ID:	169594   Click image for larger version
Name:	Tail light streaks (2).JPG
Old 11-12-2014, 01:50 PM   #2
kingstrider's Avatar
Looks like something that came through the trunk seam and leaked down. Could be anything, soap residue, salt, bird ****, who knows. Have you tried using some goo gone?
2014 Grabber Blue Mustang GT Premium with nav, RR and comfy packages, 3.73 limited slip axle and optional 19" machined aluminum wheels. Come hang out in the garage and check out my build so far!
kingstrider is offline   Reply With Quote
Old 11-12-2014, 02:01 PM   #3
DiESeven's Avatar
I haven't tried goo gone. I've tried scrubbing it out, washing it out with car soap. Nothing budged in the slightest.
Old 11-12-2014, 03:11 PM   #4
JoeyM91's Avatar
It does look kind of like condensation. Maybe a bad seal? Try blasting it with a hair dryer or a heat gun on very low and see if it starts to clear. Just don't leave it on there too long.
Old 11-12-2014, 05:45 PM   #5
rmb427r's Avatar
May be a dumb question, however have you run your car through a car wash? Some of them use really harsh soap that could stain clear coated plastic pieces.
Another idea.... Can't think of the name but it's an 'as seen on tv' item for restoring auto trim. Comes in a small bottle and has a very strong smell.
Okay, I was installing tint and the soap solution stained my inner door panel. Nothing would take it off so I tried this as a last resort and it worked immediately. If I can think of the name, I'll post it up.
Good luck!
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 11-12-2014, 05:47 PM   #6
Siber Express's Avatar
Get a paper towel and put a little clear vinegar on it and try to wipe it off, it looks like calcium deposits and the vinegar is a mild acid and will probable take it off.
Old 11-12-2014, 07:44 PM   #7
It looks like hard water/soap residue as it appears to be running from the trunk over the lenses. Take it to a detailer they have special semi abrasive cloths that should fix you right up.
Wysh is offline   Reply With Quote
Old 11-12-2014, 07:46 PM   #8
DiESeven's Avatar
Okay cool. I'll try all these suggestions in the next few days when I get time! Thanks for the help. Hopefully one of them works
Old 11-12-2014, 09:45 PM   #9
alrefire's Avatar
Worst case scenario, you trade them for my perfectly good 2012 tail lights :p
The real... boss 227
Old 11-12-2014, 11:45 PM   #10
NewMtang's Avatar
Is your car still under warranty?
Old 11-13-2014, 11:11 AM   #11
Hellish Horse's Avatar
If the Vinegar itself doesn't work add a little Vinegar to some baking soda & make a paste out of it. Scrub the marks out & then buff it out with Maguire's Ultimate Compound. I had Very Oxidized Tail Light on my 94, they were almost white. I did this & they were like brand new again.
Hellish Horse is offline   Reply With Quote
Old 11-13-2014, 04:10 PM   #12
somedopebeats's Avatar
No. ::grumpy cat:: lmao
somedopebeats is offline   Reply With Quote
Old 04-01-2015, 11:08 AM   #13
DiESeven's Avatar
Resurrecting my own thread for an update.
I finally asked my dealer about it and we both concluded that it is clearly streaks on the inside. The service manager took a bunch of pics and sent them to Ford. I should hear back tomorrow about a warranty replacement!
Now let us hope they somehow let me keep the old ones so I can make a little bit of mod money with them
Old 04-01-2015, 11:16 AM   #14
Commercial Member
au01st's Avatar
I'll gladly take credit for you asking the dealer since I mentioned them in discussing warranties, lol.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 04-01-2015, 05:46 PM   #15
bamaboy2014's Avatar
Hey,
Really fast what year is your Mustang
bamaboy2014 is offline   Reply With Quote
Old 04-01-2015, 05:49 PM   #16
DiESeven's Avatar
2014. I can't remember when this discoloration happened but it's been 5-6 months at least. Finally asked the dealer about it today, though. Hoping for a good outcome when they call me tomorrow.
Old 04-01-2015, 09:27 PM   #17
Yea that's weird it's going to be a bad seal
What's this discoloration in my paint? jayochs 2011-2014 V6 Mustang 24 09-18-2014 07:40 PM
For Sale: Raxiom Coyote Tail Lights with Sequential Tail Light Harness 05-09 All - like new dr.gsxr1000nos Mustang Parts for Sale and Wanted 0 06-02-2014 06:40 AM
Stripe removal/discoloration Zstep7 1996-2004 Mustang GT 1 02-19-2013 05:08 PM
Tail lights and marker lights, Painted or Vinyl? michael81 2011-2014 Mustang GT 20 12-02-2011 12:20 AM
FOR SALE: tail lights, head lights, clear corners, tail light covers, dvd, xbox games Zim Mustang Parts for Sale and Wanted 15 12-13-2004 12:45 PM
12:38 PM
