Gas leak. - Mustang Evolution
Old 11-14-2014, 11:35 AM   #1
Sgonza33's Avatar
Gas leak.
Hey guys first time posting here,
I've noticed a handful of times that I get a puddle of gas when filling up. I've had the car for a year and have only noticed it like 4-5 times. I was wondering if anyone else having or have had the same issue? Thanks!
Sgonza33 is offline   Reply With Quote
Old 11-14-2014, 11:51 AM   #2
fknjulian's Avatar
I've noticed that as well! It doesn't leak when I drive or it's parked either. But I've noticed once or twice that once I'm done filling up, I see a little puddle underneath.
fknjulian is offline   Reply With Quote
Old 11-14-2014, 11:57 AM   #3
fknjulian's Avatar
Old 11-14-2014, 12:01 PM   #4
Sgonza33's Avatar
I've read that it has an overflow hose and that's what causes the puddling. If that's the case will the gas come out while driving?
Old 11-14-2014, 12:04 PM   #5
fknjulian's Avatar
That makes sense if true. I usually wait til the pump stops then I press on it a little more to make sure it's full. I never noticed it leak other than parked when filling gas up
Old 11-19-2014, 09:25 AM   #6
That is supposedly very bad for your car. When the pump stops, the tank is full!
Thegreenmachine is offline   Reply With Quote
Old 11-19-2014, 09:50 AM   #7
fknjulian's Avatar
Oh wow, I had no idea thanks for the heads up!
Old 11-19-2014, 10:24 AM   #8
Strange Mud's Avatar
+1 on not filling after it clicks. I wouldn't use very bad but it greatly increases the chance of spillage.
Old 11-19-2014, 08:32 PM   #9
Kevin.Cook
Guest
Posts: n/a
Correct. It has a drain hole to prevent over filling. Found this out first hand. Only give your stang what it needs.
Old 11-19-2014, 10:59 PM   #10
Midnight2012's Avatar
There's this little booklet called an Owners a Manual that comes with the car. Has a lot of great information like don't over fill your gas tank or you will have spillage. It also tells you to stop filling at the first click.
Midnight2012 is offline   Reply With Quote
Old 11-20-2014, 12:57 AM   #11
Sgonza33's Avatar
Not sure who this is directed at, but I don't ever fill up after the pump clicks off.
Old 11-20-2014, 07:23 AM   #12
fknjulian's Avatar
The only reason why I've been filling after the click is because my old car wouldn't fill up after the click. I'd check and it would only be 3/4 of the way there so it became a habit. I usually don't go over the click on the Mustang.
Old 11-20-2014, 08:53 AM   #13
Well it's directed at the thread of course. Accurate information direct from Ford.
Old 11-20-2014, 09:05 AM   #14
Btw fknjulian you're ok. Per the manual: • Allow no more than two automatic click-offs when filling.
Old 11-20-2014, 09:07 AM   #15
Seems contradictory I know but sometimes you just want to round off the dollar amount and Ford is just trying to avoid you having spillage since it can cause fires.
Old 11-21-2014, 06:08 AM   #16
back on the original ?
No, I have not had this happen to me.
Low gas mileage, gas leak and smell evan1989 Pre-2005 V6 Mustang 3 03-31-2014 11:08 PM
Possibly Fuel Leak, Gas Tank Mustang1804 1996-2004 Mustang GT 33 04-03-2010 09:46 PM
gas leak upton7 Pre-2005 V6 Mustang 7 04-20-2009 01:32 AM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Gas leak/Smell? runvsofthisbull Pre-2005 V6 Mustang 15 12-27-2008 04:58 PM
01:43 AM
