Panhard bar mystery - Mustang Evolution
Old 11-18-2014, 10:25 AM   #1
rob.james.arias
Guest
Posts: n/a
Panhard bar mystery
I have a 2014, last night I installed a new adjustable panhard bar. When I removed the stock unit I noticed something odd. It sounds like a rain stick when inturn it on end. It appears to be internally weighted.
I searched high and low, curiosity is going to get the best of me. Perhaps someone could chime in and help explain before I cut the old one open.
-What is inside the stock panhard bar? Sand, ball bearings....
-Why is it weighted?
-Since the mechanism of weighting was dynamic (could move) rather than static that means almost always the weight would have shifted to the lower side of the bar. Why? Why would the bar purposely be weighted to be heavier on one side?
Old 11-18-2014, 02:50 PM   #2
JoeyM91's Avatar
Strange. Mine from my 2011 was just a solid bar. Never heard of any bearings inside the thing
Old 11-18-2014, 04:29 PM   #3
FastFord13's Avatar
My stock one did the exact same thing when I removed it. I'd be interested in the answer to this also.
2013 3.7 Manual Candy apple red metallic,
GT 500 stripes, painted side mirror covers, GT 500 spoiler, 2010 GT premium wheels with Pirelli P-zero tires, upper and lower front billet grille, Barton shifter bracket, Airaid Cold air intake, S.R lowering springs, J&M adjustable panhard bar, Boss 302 strut tower brace, 3.73 ford racing gears, Bama tuned, BBK shorty headers, Roush Axel backs.
Old 11-18-2014, 05:45 PM   #4
Rob, I just did mine last weekend. Same thing here. Sounds like it is half-filled with steel shot. Thought I got the one made by the pissed-off assembly line worker.
Current Mustang: '14 GT/Track Pack/6spd-sold
Previous Mustangs: '68 Coupe, '73 Mach 1, '89 GT,
Hoss is offline   Reply With Quote
Old 11-18-2014, 05:49 PM   #5
rob.james.arias
Guest
Posts: n/a
I am so intrigued. Now it appears some have and some have not had this. Why the change? I may against my better judgement cut it open. I just hate not having a spare around. I'm also mostly curious as as to the "why" more than the "what" at this point.
Old 11-18-2014, 06:54 PM   #6
My stock bar didn't make any noise, btw did you get the springs installed yet?
Bigshow14 is offline   Reply With Quote
Old 11-18-2014, 06:57 PM   #7
rob.james.arias
Guest
Posts: n/a
All installed. More of a project than I expected. I have done quite a few other cars, this was a beast!!! The panhard bar was the rosiest part. Thanks for the parts, major improvement over stock.
Old 11-18-2014, 07:03 PM   #8
Glad you like them, my car now feels like a 4x4. Did you get the rear centered?
Old 11-18-2014, 07:09 PM   #9
rob.james.arias
Guest
Posts: n/a
I did the best I can. I think I am off by about 1/8th inch but it's not visually noticeable. I gotta ask why did you decide to sell the parts? You can pm me if you would prefer.
Old 11-18-2014, 07:47 PM   #10
Commercial Member
au01st's Avatar
So, hack saw? I'm dying over here!
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 11-18-2014, 07:50 PM   #11
smittybat's Avatar
They did that to cut down on nvh.
smittybat is offline   Reply With Quote
Old 11-18-2014, 07:58 PM   #12
rob.james.arias
Guest
Posts: n/a
Sources? Not doubting you just curious on how or where this information came from.
Old 11-18-2014, 07:59 PM   #13
rob.james.arias
Guest
Posts: n/a
I may in the next day or so. Will keep everyone posted and take a ton of pictures if I do.
Old 11-18-2014, 08:22 PM   #14
Panhard bar mystery
About 95% sure im getting rid of my car probably around January or February. I traded in my 2013 F-150 screw 5.0 for my mustang early this year. Im really liking the 2015 F150 so pretty sure im heading back in that direction
Old 11-19-2014, 07:33 AM   #15
MustangDawg's Avatar
What do you mean by "nvh"?
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 11-19-2014, 08:04 AM   #16
Strange Mud's Avatar
noise/vibration/harshness
Good Aftermarket Panhard Bar? Skinsfan6 2005-2010 Mustang GT 7 03-05-2010 10:07 AM
rear sway, or panhard bar? A5295 1979-1995 Mustang GT 12 07-16-2007 08:05 AM
panhard bar eagle05 1979-1995 Mustang GT 12 07-09-2007 08:03 AM
Will a MM Rear Swaybar work in junction with the MM Panhard bar? MustangMatt Pre-2005 V6 Mustang 8 02-02-2005 04:28 PM
Panhard Bar Question njstang97 Pre-2005 V6 Mustang 6 11-07-2004 11:31 PM
04:19 PM
