car wanting to "turn off" idle - Mustang Evolution
Old 11-19-2014, 07:23 PM   #1
elkoritaNAY's Avatar
I recently installed shorty headers and air filter came off but now it's on why does the car feel like it wants to go off on idle? could something be loose?
Flowmaster force 2 exhaust, jlt cai, x4 bama tuner, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit, Bbk shorty ceramic tuned headers
elkoritaNAY is offline   Reply With Quote
Old 11-19-2014, 07:35 PM   #2
natestang07's Avatar
Vaccum leak somewhere perhaps. Is your maf in nice and right?
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 11-19-2014, 08:28 PM   #3
Kevin.Cook
Guest
Posts: n/a
Check/clean maf sensor. Make sure throttle body isnt gummed up. If you just installed stuff, maybe unplug your battery for 30 min to an hour so your car can relearn stuff. Check for vacuum leaks. If you think you got ahold of some bad gas, try fuel cleaner.
Does it get worse when the AC is on at idle? What are the RPMs like? How many miles on the car?
Old 11-19-2014, 08:30 PM   #4
I installed two weeks ago... literally when at stop sign it's like it wants to go off but it doesn't... I got 25k miles
Old 11-19-2014, 08:35 PM   #5
Kevin.Cook
Guest
Posts: n/a
If thats happening then check if your RPMs dip down to 500 or below. Definitely make sure your sensors are ok. Try the things listed above. Start with the cheap fixes and work your way up. I cant remember if you can record data logs with your tuner. If so, that may help capture what is going on.
Old 11-19-2014, 08:43 PM   #6
Kevin.Cook
Guest
Posts: n/a
I see you have listed it as Tuned headers. So did you get an updated tune for the new headers? I have heard of exhaust leaks after header installs as well. Wouldnt hurt to make sure all the bolts are tight.
Old 11-19-2014, 08:44 PM   #7
yeah I got updated tune and I checked most bolts especially ones from headers to pipe and it seems fine
Old 11-19-2014, 08:48 PM   #8
Kevin.Cook
Guest
Posts: n/a
That is good then. Yea go with cleaning and checking the maf sensor. Make sure the throttle body is clean. It may be possible the tune is a little off for your car. If the suggested fixes dont do anything, may have to ride around with your tuner and collect a data log. If you got the tuner from American Muscle, I have heard they are good with walking you through collecting a log and examining it.
Old 11-19-2014, 08:53 PM   #9
so the tune can be off? I ain't risking the car stalling on me because of this right? it won't turn off???
Old 11-19-2014, 08:57 PM   #10
Kevin.Cook
Guest
Posts: n/a
Try the easy/cheap fixes first before we look at thinking the tune is off. You can get a can of carb cleaner for about $5-$6 and clean the maf sensor and throttle body. Then maybe another $5 for a bottle of fuel cleaner.
When you are idle, does the roughness get better if you put it into neutral at stops? This can be a temp fix to get you over till you are able to try the cheap fixes.
Old 11-19-2014, 08:59 PM   #11
I have manual so rs always on neutral
Old 11-19-2014, 09:01 PM   #12
Kevin.Cook
Guest
Posts: n/a
So even on neutral it wants to die? If it was me i would already be under the hood examining things!
Old 11-19-2014, 09:03 PM   #13
Kevin.Cook
Guest
Posts: n/a
If you have your stock tune still saved, you could try reapplying that if the cheap fixes dont work. To see if anything changes. If nothing changes, you could always reapply the new tune. Just trying to isolate where the problem could be.
Old 11-19-2014, 09:06 PM   #14
car won't shut off on me though?
Old 11-19-2014, 09:07 PM   #15
Kevin.Cook
Guest
Posts: n/a
It shouldnt. If it shudders then give it a little gas.
Old 11-20-2014, 02:04 PM   #16
Site Sponsor
Hey! Sorry to hear about the trouble but it's sounding like something could be potentially loose here. If it's still acting up shoot Bama a call directly at 888.226.9764 and they're happy to help troubleshoot this with you!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 11-20-2014, 02:18 PM   #17
Alex
loose? I don't think so, I've checked bolts and nuts, and they seem to be on tight. Could it possibly be the updated tune I received because of the addition of the bbk shorties?
Old 11-20-2014, 06:45 PM   #18
alrefire's Avatar
Spray carb cleaner around anything and everything to determine for leaks.
Just don't spray it straight into your filter.
I did this when I was trying to determine why my car would stall out.
The real... boss 227
Old 11-20-2014, 07:02 PM   #19
Kevin.Cook
Guest
Posts: n/a
Have you cleaned the maf sensor and throttle body yet? It literally takes 5 minutes if you got some carb cleaner and a small towel. You said the air filter came off? Maybe the intake got some dirt in it that might be messing with the maf sensor, etc.
Old 11-20-2014, 07:05 PM   #20
I am uploading a revised bama tune as we speak hopefully that'll do the trick
Old 11-20-2014, 07:42 PM   #21
man wth I loaded tune turned oncar was idling at 1000 the tool wrench loght was on n when I pressed gas to rev it shut off eth went and uploaded my previous one
Old 11-20-2014, 09:04 PM   #22
Kevin.Cook
Guest
Posts: n/a
Well obviously the tune isnt right then.
Old 11-20-2014, 10:35 PM   #23
Socal Stangman's Avatar
Dude, come on how can we help when people probably dont even know what you're saying...
Old 11-20-2014, 10:42 PM   #24
what r u talking about don't know what I'm talking about? read the title thread
Old 11-21-2014, 12:47 AM   #25
alrefire's Avatar
He's implying that your post presents yourself as having poor command of the English language.
Proofread your post. It'll make it easier for everyone else to understand.
Old 11-21-2014, 05:26 AM   #26
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I can hardly understand his post either.
OP, have you taken off your throttle body or MAF to check/clean them yet? The revised tune sounds like the cause of your most recent issue, but the original idle problem could still be because one of these two is gummed up.
2012 Kona Blue 3.7L V6:
Old 11-21-2014, 07:28 AM   #27
Kevin.Cook
Guest
Posts: n/a
I worked in customer service so this is like second language to me
Old 11-21-2014, 08:07 AM   #28
I was driving when typing so it may not have been the clearest I guess
Old 11-21-2014, 08:44 AM   #29
Kevin.Cook
Guest
Posts: n/a
Its ok. I understood. Try contacting bama. They may have to rewrite a new custom tune for you.
Old 11-21-2014, 08:45 AM   #30
yeah I just got into the office that's the first thing I'm going to do
Old 11-21-2014, 08:59 AM   #31
Kevin.Cook
Guest
Posts: n/a
I know some people have positive experiences with tunes, but for these reasons is why i do not mess with it. Plus i have all my warranties still.
Old 11-21-2014, 09:26 AM   #32
You were What ???????????
Did you say "Driving while typing???
If I were you I would not worry about how my car is acting, You will either be in the hospital, Or even jail if you kill someone else or if your lucky you will just run off the road and wreck your car without killing your self or hurting someone else.
I had to go back and read it again. Yep, You said it
[QUOTEI was driving when typing so it may not have been the clearest I guess][/QUOTE]
Driving white texting or typing is probably the very stupidest idiot thing anyone can ever do. Driving when drinking ain't even as bad as that. At least a drunk can see what they run into.
Keep typing while driving and I hope your car shuts off and never starts again with you behind the steering wheel.
Old 11-21-2014, 09:28 AM   #33
at a red light... not literally driving... one cannot physically type drive a stick and focus on the road ... red lights in la get heavily backed up
Old 11-21-2014, 09:36 AM   #34
fenixignition's Avatar
Not with that attitude.
Ok seriously, no, you cant. manual transmission is an effective anti texting/driving device.
2002 GT 5sp. 16x,xxx miles
Old 11-21-2014, 10:02 AM   #35
Strange Mud's Avatar
this makes me glad your car is shutting off.
How to Mute Kenwood Nav Voice Prompts / Turn-by-turn Guidance EastTNMustang Mustang Audio & Video 0 11-03-2013 04:25 PM
how to turn off "change oil" indication Kona Blue 5.0L 2011-2014 Mustang GT 15 08-28-2013 04:43 PM
02:44 AM
