Blown pinion seal - Mustang Evolution
Old 11-26-2014, 09:59 PM   #1
Region: Alaska
Blown pinion seal
We'll to start off, today I had my car on a lift to change the oil. Just hit 12k miles. My car is 100% bone stock 2013 v6 auto with 2.73 gears... Well I noticed once it was on the lift that right under my rear end the entire bottom was completely saturated. So much so that it is getting on my exhaust pipes right in front of the rear end and also drips pooling in the middle. Has anyone else noticed this problem? It's going to the dealer Friday. The seal is not quite blown but it's more than just seeping out. Just wondering if anyone has had a similar issue or not.
Thanks
CFYA2818 is offline   Reply With Quote
Old 11-27-2014, 06:33 AM   #2
Siber Express's Avatar
Mine was replaced under warranty at 52,000 miles.
It does make a mess under the car, I still need to get under mine and finish cleaning it up.
Old 11-27-2014, 07:19 AM   #3
andrewheath09's Avatar
Mine leaks, but I haven't had it replaced. I've just been making sure it doesn't get low on fluid. 55k 2013 w/stock 3:31
Sent from my SM-N900V using Mustang Evolution mobile app
andrewheath09 is offline   Reply With Quote
Old 11-27-2014, 09:47 AM   #4
JoeyM91's Avatar
Thanks
Yep, had that exact thing happen on the passenger side around 58,000 miles. I went ahead and got gears done but I had them rebuild the entire diff.
I did gears, new seals and bearings, carbon clutch packs, new rear axle bearings (mine was starting to whine), new diff cover and brand new fluid with friction modifier.
All that put an end to all of the issues I was having. I did it all at once because it will just save labor in the long run as they have to take all of that out to replace gears anyway. Plus my car was at the mileage those seals start to fail.
Old 12-02-2014, 08:40 PM   #5
JDM
JDM's Avatar
Mine is seeping
JDM is offline   Reply With Quote
Just changed the pinion seal @50k Charles.young10 2005-2010 Mustang GT 1 06-14-2012 10:32 AM
pinion seal 2002Gt 1996-2004 Mustang GT 3 04-05-2012 06:21 PM
Pinion seal advice 04machazblue 1996-2004 Mustang GT 9 09-07-2011 09:18 AM
Pinion seal now fixed SpectorV Pre-2005 V6 Mustang 2 01-11-2005 07:19 PM
Got a pinion seal leak... SpectorV Pre-2005 V6 Mustang 18 01-04-2005 08:19 PM
01:43 PM
