Mustang went spastic - Mustang Evolution
Old 11-29-2014, 06:52 PM   #1
Matts14fp6's Avatar
Cold start, pulled out of my neighborhood like every other day, brakes started pumping like abs was engaged but I wasn't even on the brakes. Then I turned left at a light and my traction control started turning itself on and off like 10 times causing the car to shake. Car has 4k miles on it, v6 automatic 2014
Matts14fp6 is offline   Reply With Quote
Old 11-29-2014, 06:56 PM   #2
yellowconve's Avatar
whoa i would look for a short or a fuse blown or maybe try unplugging the battery see if that fixes if not have ford fix it its under warranty
yellowconve is offline   Reply With Quote
Old 11-29-2014, 06:58 PM   #3
Matts14fp6's Avatar
Taking it to ford Monday, really concerned they won't fix it, maybe I can catch it on my go pro
Old 11-29-2014, 07:08 PM   #4
Mine did something similar, no abs action though. Just random traction control kicking on. I took it to the dealer, they looked for event codes, found nothing. Service manager was not surprised, says it happens every so often with newer Fords.
It hasn't happened again, I'm not too worried but I know it can happen so I can react if it ever happens at highway speed.
Mine is a '14 with about 7k now, I want to say it was like 5k when it happened.
Wysh is offline   Reply With Quote
Old 11-29-2014, 07:15 PM   #5
Matts14fp6's Avatar
Well considering I'm putting new gears and a lot of aftermarket parts on it, it has me worried
Old 11-29-2014, 08:05 PM   #6
Frozen Yettie's Avatar
Strange that has never happened to me I have 9K on mine.
2014 Black Mustang 3.7L V6 Premium | 93Race MPT Tuned | Too many mods to list just check out my garage.
Frozen Yettie is offline   Reply With Quote
Old 11-29-2014, 08:27 PM   #7
If you are concerned for warranty related stuff, hold off on your mods. My impression from the service manager dude, and I quite respect this dealer as they do all my mods for me, is this is a gremlin in the system. It can happen and it's not much to be concerned with. I would take it in and get it scanned for events and if nothing comes of it, call it a fluke and move on, just keep an eye on it.
If you are going to go with extensive mods, you need to factor in what repairs you could be out of pocket for if by chance they choose not to honor warranty work because of your mods.
Old 11-29-2014, 08:39 PM   #8
Matts14fp6's Avatar
I've made sure that non of my mods will void engine warranty, but am definitely concerned with the electronics, obviously something isn't right
Old 11-29-2014, 08:41 PM   #9
Matts14fp6's Avatar
So far just gears "otw", driveshaft "otw" and axle backs which have already been installed, and suspension soon, but nothing with the done with the motor
Old 11-30-2014, 01:23 AM   #10
Mines done this as well. Perfectly level and dry service, going straight around 30mph and the traction control started flashing and it felt like I had no control of my car. Wheels felt disconnected from the pavement and my brakes were digging in sort of as if I was on ice. Very weird.. Only lasted about 5 seconds but a little scary. Has happened twice in 13k miles.
Dhawk1313 is offline   Reply With Quote
Old 11-30-2014, 05:34 AM   #11
Matts14fp6's Avatar
Did the dealership say anything about it?
Old 11-30-2014, 10:06 AM   #12
Do you have a traction control light come on when it kick in? Mine has cut power when I lose grip but I have never had a light come on.
CUBuffalo is offline   Reply With Quote
Old 11-30-2014, 10:08 AM   #13
Matts14fp6's Avatar
It flashed on and off multiple times. Dry pavement, less than 30 mph and 2k rpms... Nothing makes sense... Going to see if I can catch it again on gopro
Old 11-30-2014, 12:12 PM   #14
Didn't even bother taking it to the dealership. There's really no recreating that as its so random and I doubt my car would throw any codes because it's drives perfectly fine otherwise. Eh I just kind of wrote it off. Really don't want it to happen again lol
Old 11-30-2014, 01:04 PM   #15
Matts14fp6's Avatar
If they find something I'll post back
Old 12-01-2014, 02:23 PM   #16
Matts14fp6's Avatar
They said the exact same thing everyone else said, they couldn't find a code or anything wrong, but it's now documented before I put all my mods on so ford can't say my mods caused the problem
Old 12-01-2014, 08:04 PM   #17
Matts14fp6's Avatar
It occurred again. I think the abs box got hit in my wreck and wasn't replaced, taking it back tomorrow and having them replace, hopefully it does the trick
Old 12-01-2014, 08:11 PM   #18
Wow! Glad nothing bad has come of this yet. Wonder if that will do the trick. Keep us updated
Old 12-02-2014, 10:20 PM   #19
Cooolbreeez's Avatar
My car did the same thing this morning. A little over 4k on engine. No mods.
Cooolbreeez is offline   Reply With Quote
Old 12-02-2014, 10:42 PM   #20
Matts14fp6's Avatar
I'm positive it's something with the abs module but I think ford has a bigger problem on their hand that they aren't willing to fix
Old 12-03-2014, 08:29 AM   #21
RaceRed3.7's Avatar
Its something to do with the fuse(most likely). I know there is a fuse that controls both abs and traction control. its a 5amp orange in the passenger side box. Not sure of the specific number though.
RaceRed3.7 is offline   Reply With Quote
Old 12-03-2014, 08:36 AM   #22
Matts14fp6's Avatar
If it was a fuse it would do it everytime I turned the car on wouldn't it?... And I eliminated traction control as the problem, it's definitely just the abs
Old 12-03-2014, 10:25 AM   #23
Strange Mud's Avatar
Mine did this 1x (and 1x that was a maybe) good luck but getting it to happen for them ain't easy. Good luck I remember one person on another forum had some type of flight data recorder on hers and ended up getting it repaired but it was a hassle and took lots of effort on her part.
Old 12-03-2014, 10:37 AM   #24
Matts14fp6's Avatar
Do you remember what part they fixed on hers?
Old 12-03-2014, 10:26 PM   #25
Matts14fp6's Avatar
So the ford dealership won't let me take the vehicle home until they've figured it out because they know if I get in a wreck due too the abs there will be a huge lawsuit, unfortunately I think it's something simple like a wheel speed sensor but they won't test anything until they can replicate it
Old 12-03-2014, 11:49 PM   #26
Damn, that sucks. Does that mean someone from the dealership will be driving your car around until it happens? Putting miles on it, doing burn outs and other fun stuff to your car without you?
Old 12-04-2014, 04:28 AM   #27
Matt,
a link to another forum with what I believe to be the best thread on this. You are not alone.....but realize how difficult intermittent problems can be to find then fix.
Advanctrac incident caught on Flight Data Recorder - Ford Mustang Forums
Old 12-04-2014, 05:26 AM   #28
2011fastford's Avatar
Region: New Mexico
its happend to me maybe 3-4 times since ive had the car.. 60k miles and lots of mods..
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 12-04-2014, 07:43 AM   #29
We should get a master thread going with:
Year
Miles
MT/AT
Mods
What were you doing when it happened?
This seems to be a pretty common thing and a large documented thread can help people when they go to the dealer for warranty work or to position to Ford for further investigation.
Old 12-04-2014, 01:22 PM   #30
had the wierdest thing happen yesterday i pushed the gas and the peddal stayed all the way foward exelerating the car causing it to go side ways i almost spun out and had to mess with everything b4 i turned it off and has not happened since what should i do scared the crap out of me
Old 12-04-2014, 02:23 PM   #31
Matts14fp6's Avatar
Atleast I'm not alone on this, and yeah it sucks some else is driving my car and having fun in it, but not a lot .
---------- Post added at 04:23 PM ---------- Previous post was at 04:22 PM ----------
Take it to the dealer!
who went to MUSTANG WEEK ? curtin1991 2011-2014 V6 Mustang 21 07-22-2012 08:23 PM
Went to a mustang meet at hooters, pictures Yellow50 2011-2014 Mustang GT 11 06-25-2012 09:59 AM
2009 mustang gt500 tires went on right side!! Ahmed ali khan 2005-2010 Mustang GT 12 10-18-2011 09:45 PM
Went & took pics of the 05 Mustang and GT40 [LARGE RES PICS INSIDE 56k BEWARE] Seph The Bar 13 11-11-2004 06:17 PM
pics of the mustang trip i went on last weekend. Black00GT The Bar 7 05-02-2004 10:05 PM
07:23 PM
