Gears and warranty - Mustang Evolution
Old 12-01-2014, 08:10 AM   #1
Gears and warranty
Which warranty do gears fall under?
I'm itching to move up from the 2.73s but want to avoid risking my warranties.
What cruising rpms can I expect in 6th at 75mph with the various gears?
Wysh is offline   Reply With Quote
Old 12-01-2014, 08:14 AM   #2
fknjulian's Avatar
Gears and warranty
3.31 gears
I think they might have to be installed by Ford as well, Im not sure though
fknjulian is offline   Reply With Quote
Old 12-01-2014, 08:54 AM   #3
Strange Mud's Avatar
with my MT 3.31 70 mph = 2100 rpm
Unless you have a Ford dealer install/re-flash you MAY loose some of your wtty...talk with your dealer.
Old 12-01-2014, 09:38 AM   #4
bigmac3's Avatar
My auto/3.73 is a bit over 2200rpm @ 70mph.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 12-01-2014, 02:15 PM   #5
Driven5's Avatar
Your dealership would have to really be looking hard for reasons to specifically void your warranty, in order to go through the time/effort to check for things like the ring and pinion ratio not being stock...Unless you also have the speedometer/odometer recalibrated.
-Justin
You can follow my Ford based 'Locost' build at:
GarageOdyssey.blogspot.com
GarageOdyssey.tumblr.com
@GarageOdyssey (instagram and twitter)
Driven5 is offline   Reply With Quote
Old 12-01-2014, 02:19 PM   #6
Matts14fp6's Avatar
My ford dealer said I can do 3.73 because it is something they can flash since the Shelby's have 3.73
Matts14fp6 is offline   Reply With Quote
Old 12-01-2014, 02:46 PM   #7
VIG
VIG's Avatar
Region: Delaware
I'd run very far from that dealership considering they aren't aware there's never been V6 Shelby.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 12-01-2014, 03:03 PM   #8
JoeyM91's Avatar
3.31 is the highest they can flash for as that's what was offered in the v6 performance package. Past that they would have to tinker with tire size settings to get it close, but it won't be spot on without an actual aftermarket tune.
Old 12-01-2014, 03:22 PM   #9
Matts14fp6's Avatar
They said it didn't matter what motor was in it
Old 12-01-2014, 03:27 PM   #10
Matts14fp6's Avatar
Just about the rpms the transmission switchs at
Old 12-01-2014, 03:28 PM   #11
Matts14fp6's Avatar
Did you have to use a tuner?
Old 12-01-2014, 03:43 PM   #12
VIG
VIG's Avatar
Region: Delaware
Negative.
You can't flash a 3.7 with a 5.0 or a 5.8 tune.
You'd need a custom tune for anything that isn't 2.73 or 3.31.
Old 12-01-2014, 03:45 PM   #13
VIG
VIG's Avatar
Region: Delaware
Yeah, have to use a tuner unless you go 3.31 since 3.31 was a factory option.
Some dealerships will flash the 3.31 program on there for about $100.
Old 12-01-2014, 04:01 PM   #14
Matts14fp6's Avatar
Well damn, looks like I'm going to have to void my warranty with a tune
Old 12-01-2014, 05:27 PM   #15
Matts14fp6's Avatar
Just spoke with ford factory and it can be done on a 3.7l at the dealership, however it is not a ford recommended move, and the dealership has to feel comfortable doing it. Also it voids the fords factory warranty for your rear end
Old 12-01-2014, 05:31 PM   #16
FastFord13's Avatar
Ford doesn't offer 3.73s on our 3.7s, so a ford factory tune wouldn't be possible because they just don't offer it. Maybe your dealer will use a Steeda tune or something else. I went through this very issue when I went to 3.73s and I can tell you it won't be a factory ford tune you'll be getting.
Sent from my Nexus 5 using Mustang Evolution mobile app
Old 12-01-2014, 06:01 PM   #17
VIG
VIG's Avatar
Region: Delaware
Yeah, the dealership will put the actual gears in, that's not the problem (aside from getting butt raped on price) but they won't be able to calibrate it. Your speedo, odo and shift points will all be off.
Old 12-01-2014, 07:02 PM   #18
Matts14fp6's Avatar
The ford factory said they will be able to calibrate and set it up if they have the right tools, not all dealerships have those tools
Old 12-01-2014, 07:09 PM   #19
Is the rear end considered drivetrain or is it under the number to bumper warranty?
I think I would like 3.73s but I think it would be a pain with 110 miles of highway, sometimes bumper to bumper. 3.31s sound like they would be more commuter friendly.
The 2.73s are great for highway cruising I just want to bump that 6th gear rpm up to 2k at 75mph. At 75 now in about 1750rpm and on any incline, the Roush hums something awful. I either have to push it up to 80 or down to 70 to get out of that zone.
Old 12-01-2014, 07:20 PM   #20
Matts14fp6's Avatar
3.73's get to speed quicker, they actually say you get better gas mileage in the city with them, that's one of the reasons I chose 3.73's
Old 12-01-2014, 07:37 PM   #21
VIG
VIG's Avatar
Region: Delaware
I'm really questioning the info you're getting.
Your dealership also said they could calibrate your 3.7 for the 3.73s because the Shelby's have them, which can absolutely not happen with a Ford made tune.
What's the name of your dealership? If they can do the 3.73s and tune it, I'd be willing to make the trip from Delaware.
Old 12-01-2014, 08:09 PM   #22
JoeyM91's Avatar
It's the opposite. Crap city mileage, only marginally worse highway.
Old 12-02-2014, 07:52 AM   #23
Matts14fp6's Avatar
Capitol ford in Charlotte nc
Old 12-02-2014, 03:48 PM   #24
DEvermore's Avatar
Region: Iowa
Gears and warranty
Please note your tune will affect mpg as well. An aggressive tune cares more about power than gas.
My car has 3.73s and I do run an aggressive tune. There was some change in town mpg and a 4mpg decrease highway. However, driving conditions are really important -- my commute to work is only a few miles but with max speed of 35, and so many stop lights I spend 40% of the drive standing still. This means I get about 16 mpg when I'm easy on the accelerator -- but that's much better than the 12-14 I had on my 2.73s...
2017 GT350 w/electronics package.
DEvermore is offline   Reply With Quote
Old 12-05-2014, 12:58 PM   #25
smurf stang's Avatar
They are so wrong.
The dealership can not flash for 3.73 on a V6 mustang.
Ask them how many they have done, bet ya it is zero.
2016 VW GTI 2.0 Turbo
Old 12-08-2014, 07:49 PM   #26
JCALD's Avatar
Gear Change
Probably the 3.31 s since that is what Ford certifies. I have attached a spreadsheet showing ratios and speeds based on the six speed standard. I chose to go from the 2.73 to 3.55.
JCALD is offline   Reply With Quote
Old 12-09-2014, 07:10 AM   #27
Your chart seems off for 6th. My rpm at 80 in 6th is almost 2k. 90 would put me at about 2200-2300.
Old 12-09-2014, 02:54 PM   #28
JCALD's Avatar
I may not have the correct 6th ratio. Will check on that.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
Want to Mod and have Warranty READ THIS! SpectorV General Mustang Discussion 4 07-21-2011 02:33 PM
Gears and warranty Smoke 2011-2014 Mustang GT 3 03-12-2011 12:22 PM
Voided warranty and not a GTR! DarkShadows The Bar 7 12-18-2008 03:23 PM
New 7.5 3.73 gears for $149.99 with a lifetime warranty Blue232 Pre-2005 V6 Mustang 16 11-23-2006 04:27 PM
09:45 PM
