Antenna install. - Mustang Evolution
Old 12-02-2014, 06:37 PM   #1
blackstang1's Avatar
Antenna install.
I was going to install my new Steeda shorty aluminum antenna today but am not sure if i am missing a piece with it or am doing it wrong. When i removed the stock antenna (just unscrew it), it has a male screw on the bottom going into the female end in the base. the antenna i got just has a female end at the bottom so there is no way to attach it to the base. Nothing else came in the package with the antenna and Steeda is closed for tonight. Anyone have any suggestions. Pic below comparing stock (left) and steed (right).
2014 Mustang V6 w/Technology package, 6MT
Mods: Airaid CAI w/ Synthamax filter, 18" black AMR wheels
blackstang1 is offline   Reply With Quote
Old 12-02-2014, 07:14 PM   #2
rmb427r's Avatar
Hmm that's weird. Certainly looks like a threaded piece is missing. Did you try to gently twist the stock one out with needle nose pliers?
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 12-02-2014, 07:24 PM   #3
Yep. Didn't try too hard because I don't want to break it.
Old 12-02-2014, 07:38 PM   #4
rmb427r's Avatar
It looks like the stock one comes apart. Use the existing base for the new one. Notice the difference in diameter in your pic? I went to their site and both the black and silver ones in the pictures are on the stock base. that has to be it
Ron..
2008 Roush 427R
2014 V6 Prem
Old 12-02-2014, 07:48 PM   #5
What you are seeing in the pic is just the antenna off the car. The base is still on the car and has to be used with the new antenna. The only problem is there is no way to connect the new antenna with the base. Also, the picture doesn't correctly show the sizes. The bottom of the antenna's are, in fact, the same diameter.
Old 12-02-2014, 08:05 PM   #6
DiESeven's Avatar
Here's what the stock antenna looks like if you pull it out further (aka, ruin it).
A car wash personnel was generous enough to f up my antenna by not unscrewing all the way and yanking it off. It's basically a bolt tucked under the rubber piece. So there's no way you can reuse that for the steeda antenna. My guess is that they forgot something or its defective.
Old 12-02-2014, 08:06 PM   #7
Thank you for the pic. I guess they didn't send me a piece or something. Looks like I'll be contacting them tomorrow.
Old 12-02-2014, 08:06 PM   #8
Stangholio's Avatar
I have a shorty antenna that has a double male screw. Screws into the antenna then into the car. I think they forgot yours.
GHIGitty
Stangholio is offline   Reply With Quote
Old 12-02-2014, 08:32 PM   #9
JDM
JDM's Avatar
Antenna install.
Check the box it came in for a plastic envelope for a male adaptor piece.
JDM is offline   Reply With Quote
Old 12-02-2014, 10:02 PM   #10
NewMtang's Avatar
Sorry the information that I gave you was for a Shorty Antenna purchased from American Muscle. At the Steeda site, you use the existing bottom for the top you purchased.
Old 12-03-2014, 04:31 AM   #11
rmb427r's Avatar
Yep. They forgot the male attachment screw then.
Ron..
2008 Roush 427R
2014 V6 Prem
Old 12-03-2014, 05:58 AM   #12
Dammit. I was so excited to get it put on. I guess I'll be contacting Steeda today.
Shorty Antenna rickf73 Mustang Audio & Video 19 09-15-2009 12:36 PM
pics with new antenna edross Pictures and Videos 9 03-30-2008 03:48 PM
antenna electricstang Mustang Audio & Video 7 05-28-2006 10:27 AM
8" antenna red pony V6 Mustang Audio & Video 11 02-16-2005 09:30 AM
Power antenna pics? ASSEMbler Mustang Audio & Video 6 09-26-2004 08:33 PM
04:42 AM
