Driveshaft/Transmission problems? - Mustang Evolution
Old 12-05-2014, 10:14 AM   #1
Ugh, I just posted that there was nothing wrong with it too in another thread lol.
I replaced my driveshaft to an aluminium one piece not too long ago, Everything was running smooth, unfortunately just recently it started making a popping sound whenever the gear would engage, Downshift or upshift and reverse, I thought maybe the person who installed my driveshaft didn't tighten the screens on correctly, Which is bad on its own, But I took it today to get checked out, They lifted the car and the driveshaft was perfectly tightened.
They wiggled the rear end side of the driveshaft, Nothing, Then they wiggled the front side that goes on the transmission housing and there was a LOT of play, They told me it's something inside the transmission, So when the gear kicks in, It jumps and bangs on the housing...
Has anyone heard of this? Does anyone know what it could be exactly that went wrong?
RushGotti is offline   Reply With Quote
Old 12-05-2014, 10:30 AM   #2
Strange Mud's Avatar
idk whats wrong but it ain't good. Looking at your mods they're gonna tell you it ain't covered.
Merry Christmas!
poor impulse control
Old 12-05-2014, 03:24 PM   #3
JoeyM91's Avatar
Merry Christmas!
With a new driveshaft? Hell no it won't be covered lol. They'll tell you to go fly a kite and blame it on the new yolk.
What manufacturer is your DS Rush? If it's just those goofy adapter plates on the u joint, that may have something to do with it.
Old 12-05-2014, 03:58 PM   #4
Frozen Yettie's Avatar
In the last pic are those suppose to be subframe connectors?
2014 Black Mustang 3.7L V6 Premium | 93Race MPT Tuned | Too many mods to list just check out my garage.
Frozen Yettie is offline   Reply With Quote
Old 12-05-2014, 04:04 PM   #5
VIG
VIG's Avatar
Region: Delaware
This is the first auto I've heard having issues.
Really hoping it's nothing major.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 12-05-2014, 09:33 PM   #6
JimC's Avatar
My guess is that he has a convertible. That is the extra bracing that the convertible has in place.
JimC is offline   Reply With Quote
Old 12-05-2014, 09:49 PM   #7
It's this one :
Mustang Mustang Aluminum One Piece Driveshaft (11-14 V6) - Free Shipping
It just says "Aluminum One Piece Driveshaft"
Yeah, I have a convertible.
Old 12-06-2014, 02:11 PM   #8
Originally Posted by RushGotti View Post
It's this one :
I had the same driveshaft on my car, had no issues with it. Whodat bought it from me and he hasn't posted any dislikes about it.
Bigshow14 is offline   Reply With Quote
Old 12-06-2014, 04:20 PM   #9
JoeyM91's Avatar
I've seen that ds. I can't remember the brand right off hand. It could be because of the adapter plate it uses rather than having a full joint built on like the DS Shop or dynotech.
Old 12-06-2014, 04:24 PM   #10
Axle exchange
Old 12-06-2014, 04:42 PM   #11
JoeyM91's Avatar
Originally Posted by Bigshow14 View Post
Axle exchange
That's it! Lol
Old 04-16-2015, 12:55 PM   #12
tym_v6's Avatar
I have the stock telescoping DS and was also noticing some increased driveline noise and vibration. I was thinking U-joints and had a race shop look at it. They said the U-joints and rear end lash were fine, but they also found increased play in the tailshaft coming out of my 6R80 auto transmission, plus a small stain from a bit of fluid leakage. The shop felt that the issue was not enough to warrant any work right now--just to keep an eye on it.
I did some research into how the tailhousing and tailshaft go together. There is a large needle bearing (instead of a metal bushing) and a couple of thrust washers...if the bearing is going bad, that could easily explain the increased play and noise. My transmission shifts and operates fine. I've ordered all the parts and will probably have the race shop swap them out soon now that its warming up.
I also have heard of no problems with the 6R80, so I think it would be *really* unlikely that there's anything bad going on inside the OP's transmission or mine. Might just be the bad needle bearing, which is a $30 from Ford, but probably requires a special tool for removal/installation.
Old 07-02-2015, 12:47 PM   #13
tym_v6's Avatar
A brief update. With a few days off, I took my car to one of the better-rated transmission shops around here to have the tailshaft wobble looked at. They said that the amount of play is among the worst they've seen and they'll have to drop the trans to know for sure, but probably the needle bearing in there has crapped out. The car drives and shifts fine, but the tailshaft is flopping around and making a lot of clunking that sounds like driveline noise (bad U-joints or rear end problems, even though everything back there checks out). I'm having them rip into things and start the fix, and will update you all with what they find when I get my car back.
Pretty weird, as the 6R80s aren't really known to have problems, and I can't see how botched rear end work in the past could have caused this to happen unless something was whaled into place with a wicked big hammah.
Would love to know how the OP turned out!
Old 07-02-2015, 01:50 PM   #14
Really off topic but what size are those tires op, those things look huge!
Lan_Evo is offline   Reply With Quote
Old 07-02-2015, 07:05 PM   #15
tym_v6's Avatar
Back on-topic, I have a question. I realized I have a Ford ESP "Premium Care"...can that be used at an independent garage?
Old 07-02-2015, 07:06 PM   #16
Kevin.Cook
Guest
Posts: n/a
Only official Ford dealers my friend. I had that to and cancelled it. Got like 2-3k back. I can take care of the maintenance myself.
Old 07-02-2015, 10:19 PM   #17
tym_v6's Avatar
Fortunately I got it for free from my regional CSM. This sentence on Ford's website is what intrigued me: "For vehicles outside the factory warranty, most independent garages will also accept a Ford ESP." I'm outside of the 3/36 but just inside the 60k powertrain warranty...wondering if I can get it to work in my favor. Can't hurt to ask.
Old 07-02-2015, 10:30 PM   #18
Kevin.Cook
Guest
Posts: n/a
Wouldn't hurt
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
02 Mustang Possible Transmission Problems TK225 General Mustang Discussion 3 10-07-2008 06:41 AM
driveshaft and transmission Mustangbobby General Mustang Discussion 1 04-24-2008 07:07 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
03:51 AM
