Exhaust difference? - Mustang Evolution
Old 12-06-2014, 06:13 PM   #1
Black_out's Avatar
Exhaust difference?
What's the difference of the axlebacks from the v6 to the v8? If I have borla ataks and I want to transfer them to a v8 what will be the difference? If any
3pointHeaven
Black_out is offline   Reply With Quote
Old 12-06-2014, 06:15 PM   #2
Only the diameter of the inlet pipes to the muffler. They're bigger on the v8
Bigshow14 is offline   Reply With Quote
Old 12-06-2014, 06:21 PM   #3
Black_out's Avatar
So will that change the sound?
3pointHeaven
Old 12-06-2014, 06:27 PM   #4
3pointHeaven
The biggest change to the sound you'll notice is that they're two different engines so they won't give off the same tone.
Quack is offline   Reply With Quote
Old 12-06-2014, 06:29 PM   #5
3pointHeaven
You will have to get a muffler shop to make a new inlet pipe or weld it solid which I dont recommend. The sound difference should be the same maybe a slight difference depending on how you decide to mod the inlet pipes to match the gt exhaust.
Old 12-06-2014, 11:54 PM   #6
JoeyM91's Avatar
There are pipe adapters that can be welded in, but as Bigshow said, there will be a different tone because of the pipe step-down. You "could" have a muffler shop cut the connecting pipe and weld on new larger 2.75" pipe to mate to your over axles. But that's fab work that costs money and most certainly will void any warranty on the mufflers.
exhaust
Distinct exhaust note difference Mustang Coyote 2011-2014 Mustang GT 14 10-03-2014 11:26 PM
Does anybody else notice a difference in exhaust? DarkShadow Pre-2005 V6 Mustang 27 11-17-2005 03:22 PM
What is the difference between these paint codes..... domin8stang Mustang Audio & Video 3 11-02-2003 02:23 PM
Difference between Michael Jackson and Neil Armstrong *WW* DropTop_Stang The Bar 18 10-28-2003 02:20 PM
Difference between Liberals, Conservatives and Southerners Ken The Bar 6 10-24-2003 05:19 PM
02:41 AM
