Clutch pedal sticks at redline - Mustang Evolution
Old 12-09-2014, 10:43 AM   #1
JR4288's Avatar
My clutch pedal does not come up when I shift at redline. It comes up a few inches and then I have to lift it with my foot. Only happens at close to redline. Anyone have this issue?
JR4288 is offline   Reply With Quote
Old 12-09-2014, 10:46 AM   #2
Voltwings's Avatar
Very common issue on this trans. Look into removing the "assist spring" on the clutch pedal. If that doesnt help, look into swapping to a stainless steel clutch line and adding some DOT4 brake / clutch fluid.
Old 12-09-2014, 11:10 AM   #3
JR4288's Avatar
Is taking out the assist spring an easy fix?
Old 12-09-2014, 11:24 AM   #4
Voltwings's Avatar
Takes 10 minutes. Search them on google, theres quite a few videos and write ups. You will notice an increase in pedal effort, but its not going to be anything serious.
Old 12-09-2014, 12:11 PM   #5
JR4288's Avatar
Do you think this could damage the clutch? Basically slipping the clutch?
Old 12-09-2014, 12:22 PM   #6
Voltwings's Avatar
Removing the assist spring? No, its just there to reduce pedal effort.
The sticking? Possibly, but basically as soon as you let out the revs will start dropping, and the clutch will return to normal operation (and under virtually no load at that). Its not anything like slipping the clutch for a 1/4 launch. Interesting point though, i've never thought of it like that before, but i dont think its an issue in that sense.
Old 12-09-2014, 12:23 PM   #7
I believe Ish had the same issue with his car a while back.
Old 12-09-2014, 12:36 PM   #8
JR4288's Avatar
Ya i meant the sticking. I just don't want extra wear on my clutch. Haha I can already do that myself. I will just pop the spring out tonight. Thanks for input!
Old 12-09-2014, 01:15 PM   #9
Ish416's Avatar
Still do. Removing the clutch assist spring made my issue much worse.
I posted a video of this on youtube after several trips to local dealers and being told it's "normal". Someone from Ford sent me a message on youtube asking me to remove the video. Shortly after, my dealer had gave my information to Ford corporate for them to contact me. I talked with an engineer and he said that they were well aware of the issue and were working on a fix for all MT82 equipped cars (Boss, GT, V6) along with the new design being implemented into the S550 and that it would be available as part of a service bulletin. That "fix" was supposed to be out in early spring of this year (2014). To my knowledge the "fix" never happened.
My thread about this along with a link to the video I posted - Clutch pedal sticking..
If I knew I was going to keep my car for more than a few years, I would just Tremec swap it. However, I don't see myself holding onto this car for much longer (likely let it go sometime next year), so I will just deal with it for now.
Old 12-09-2014, 01:51 PM   #10
Voltwings's Avatar
Ahh yes, i remember us talking about it now ... I still think your case is different than everyone else, removing an item restricting the clutches ability to return to neutral physically cant make it worse... You obviously still seem to have the issue though, so maybe its something more extreme. At any rate, that conversation has already taken place, no need to have it again.
Old 12-09-2014, 02:02 PM   #11
Ish416's Avatar
On a side note - mine has gotten better after a fluid change. 1-2 still does it frequently, just not as often, 2-3 hardly ever has an issue anymore.
Old 12-09-2014, 02:27 PM   #12
JR4288's Avatar
I never noticed it before. Until I started doing 3rd gear pulls for data logging. I know I don't have the problem in 1st or 2nd. Not sure why it happens in different gears for different people. I would expect it to happen in all gears or one specific gear for everyone.
Old 12-09-2014, 05:22 PM   #13
JR4288's Avatar
Well got the spring out. Now I just need to wait till it gets a little later to test and see if it did the trick.
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
TR3650 shifter sticks sikstang03gt 1996-2004 Mustang GT 7 02-20-2015 03:27 AM
Sticks n Stones Plague 2011-2014 V6 Mustang 8 04-04-2012 04:46 AM
What Happens When you light 30,000 match sticks at once? Brent Pictures and Videos 10 06-26-2007 12:17 PM
Air and Sticks for Sale drummerstang98 The Bar 1 09-07-2004 11:33 PM
05:36 AM
