Are Nitrogen-filled tires necessary? - Mustang Evolution
Old 12-10-2014, 03:59 PM   #1
MadGenius's Avatar
So one of my tires got a puncture recently so I went to my local Firestone to replace it. My Mustang is equipped with the Performance Pack so I have nitrogen-filled tires. I asked if they carried nitrogen filled tires and they replied "unless you're going on a rally or constantly going to track days there's no need for it. Then I went to a local speed shop and they basically said the same thing, they air filled tires are completely fine for everyday driving. So what do you guys think. Are they a rip-off or are there advantages to spending a little extra $ to have them filled?
MadGenius is offline   Reply With Quote
Old 12-10-2014, 04:20 PM   #2
paintmann111's Avatar
As someone who has sold, installed and repaired tires for a living I can tell you 100% you don't need it. The main benefit of nitrogen is that it is more resistant to temperature changes, which cause fluctuations in the tires pressure. If you check your tires pressure even once a month you have negated any advantage they have in a daily driving scenario.
For track use, the same applies, but since the temperature changes are considerably more than someone who is DD the car, it has its advantages. As temperatures increase, PSI increases and the opposite when the tires cool. Thus having a more stable PSI means you have more predictable and consistent handling/grip.
paintmann111 is offline   Reply With Quote
Old 12-10-2014, 04:21 PM   #3
Exactly what he said.
Also nitrogen molecules are larger, so they are less likely to escape causing the pressure to lower over time.
Old 12-10-2014, 04:55 PM   #4
WJBertrand's Avatar
The only reason that the pressure is more consistent with temperature is because the process of separating nitrogen from air causes it to be extremely dry. The Ideal Gas Law shows that dry air would perform exactly the same as dry nitrogen as there's no accommodation in that formula for the type of gas. The problem is that most compressed air sources use compressors that just compress normal ambient air. What you will find is that most of these sources are poorly maintained and tend to accumulate moisture.
When that moisture gets into your tire you now have a substance (water) that can change state from liquid to gas with temperature. This changing of state can cause large fluctuations in pressure at higher temperatures like one might encounter in racing, For street use your tires won't get hot enough for that to make much difference and as you are not generally driving at the limit of traction, even if you did have large pressure changes, they would likely be inconsequential and unnoticeable in normal driving.
If the tire shop include nitrogen as part of their service - great, but I wouldn't pay a nickle extra for it. After all air is already 80% nitrogen.
As far as molecular size it's not that simple. The process in which a gas is lost from a closed container, such as a tire, is called permeability. Permeability is a factor of simple diffusion (which is related to molecular size) and the solubility of the gas in the material the container is made from. Try filling a balloon with CO2 and a second balloon with air and then monitor their deflation. In spite of CO2 being a much larger molecule than either oxygen or nitrogen, the CO2 filled balloon will deflate so quickly you'll think it's got a leak. The diffusion coefficient of the permeability is much slower that for air but because the CO2 is so much more soluble in the rubber, there are many more molecules making the trip across the rubber at any given time.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 12-10-2014, 05:01 PM   #5
Here's an interesting article about using Nitrogen in tires...
https://ahotcupofjoe.wordpress.com/2...-tires-a-scam/
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 12-10-2014, 05:13 PM   #6
Commercial Member
au01st's Avatar
Whenever I hear someone ask if something is necessary...
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 12-10-2014, 05:23 PM   #7
JoeyM91's Avatar
But I like the taste!
Old 12-10-2014, 05:24 PM   #8
Eno07's Avatar
I am surprised people charge for nitrogen, the only reason I got it was for the pressure changes with the temperature, but it's free everywhere I checked so I thought why not.
G.H.I.G 2014 V6 Mustang
MMD Ducktail spoiler
Roush axle back exhaust
Black upper and lower retro billet grille
MMD 551c matte black rims
Eno07 is offline   Reply With Quote
Old 12-10-2014, 05:26 PM   #9
JoeyM91's Avatar
It's the opposite here where I am. If you can even find it outside major cities, tire shops will charge you about $2.50 a tire on normal passenger car tires. (At least the ones I've scouted out)
Old 12-10-2014, 05:30 PM   #10
Eno07's Avatar
That's weird
Old 12-10-2014, 05:33 PM   #11
VIG
VIG's Avatar
Region: Delaware
Also keep in mind that the air we breathe is almost 80% N2.
And unless they are able to vacuum every last bit of air out of the tire, you're going to have more than just pure N2 in there
It's just a scam.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 12-10-2014, 11:19 PM   #12
WJBertrand's Avatar
Yup.
-Jeff
-Jeff-
Ventura, CA
Old 12-11-2014, 12:29 AM   #13
Bear376's Avatar
It was started as a story about how racers use nitrogen in their cars, and so every wannabe racer started doing it. Tire shops found it easier to jump on the bandwagon than argue. Maintaining your tires with pressure checks, rotation, and inspection will do more than nitrogen.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 12-11-2014, 04:39 AM   #14
Strange Mud's Avatar
it ain't necessary but it's good for the seller. This was one of the lines I X'd out on my order form along with VIN etch. Nothing wrong with them but not at what most dealers try to get. Truthfully I wouldn't pay $20 for both if that's what they wanted.
Strange Mud is online now   Reply With Quote
Old 12-11-2014, 04:47 AM   #15
bucko's Avatar
Hmmm. I heard that id made the car 30% lighter, and therefore you would get 4 to 5 MPG more using it in your tires.
Darn...another myth brought to fact.
Old 12-11-2014, 06:27 AM   #16
VIG
VIG's Avatar
Region: Delaware
Only if you get it dialed in with your tune.
Old 12-11-2014, 08:39 AM   #17
smurf stang's Avatar
That's why I fill mine with helium.
It works.
2016 VW GTI 2.0 Turbo
Old 12-11-2014, 09:40 AM   #18
Molten lead, although you might think the weight would work against you for those of us that like blasting down twisty roads it lowers your center of gravity.
Old 12-11-2014, 10:25 AM   #19
Commercial Member
au01st's Avatar
Combine that with enriched plutonium wheel weights when balancing wheels and you stay shielded from radiation while being able to generate enough power for the flux capacitor. But don't try this without a tune!
Old 12-11-2014, 10:44 AM   #20
bigmac3's Avatar
Most of the few places that offer it around here do not charge for N2, however one of the Ford dealers added it as a $100 dealer option on new Mustangs. Now that's a rip-off. This was the same dealer that once added $7K to all his GT500s as a "Market Adjustment" fee. Found out later that he had to drop it or watch the cars just sit on his lot.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Wanted: Green valve stem cover for nitrogen filled tires Te172r Mustang Parts for Sale and Wanted 0 01-24-2014 09:25 PM
Nitrogen filled tires 98mustang11 Pre-2005 V6 Mustang 11 09-26-2012 03:18 PM
Nitrogen vs air Sprintradc Mustang Wheels & Tires 2 04-01-2012 10:43 AM
Nitrogen ? rickf73 General Mustang Discussion 40 07-18-2009 02:37 AM
01:05 PM
