Cutting hole in hood under scoop ?? - Mustang Evolution
Old 12-11-2014, 10:31 AM   #1
grom80's Avatar
Hey guys...I am thinking of installing a good scoop...the MMD...and was wondering...
Would it actually help engine cooling if I cut a rectangular hole in the good underneath where the hood scoop will mount ?
Is that idiotic ?
grom80 is offline   Reply With Quote
Old 12-11-2014, 10:45 AM   #2
invest in a hood rather then chopping your hood and adding a glued on scoop.
to me sounds like a hole is just a easy way to poor water ( when raining ) onto your engine.
Hello is offline   Reply With Quote
Old 12-11-2014, 10:47 AM   #3
Voltwings's Avatar
Gotta ask yourself if thats even a high pressure zone. Cars that actually have functional scoops have hoods that are designed to funnel air to those areas.
Old 12-11-2014, 10:48 AM   #4
grom80's Avatar
Yeah I guess...but the only freakin' hood I am finding is the Cervini which costs a fortune and I don't like
Old 12-11-2014, 10:50 AM   #5
Voltwings's Avatar
They'll all cost a fortune, "Get what you pay for." I'm partial to this one. 2010-2014 Mustang GT500 Fiberglass A72KR Hood (also fits 2013-2014 V6/GT)
Old 12-11-2014, 11:38 AM   #6
MustangDawg's Avatar
That is without at doubt the best looking hood with a scoop I've ever seen on dang near any car. Just beautiful
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 12-11-2014, 11:49 AM   #7
Laquisha's Avatar
It doesn't cost that much!
Naturally Aspirated Is Lyfe
Old 12-11-2014, 06:38 PM   #8
rmb427r's Avatar
Don't cut your hood.. Are you worried that it's going to overheat? It won't. You won't get any more horsepower from a hole in your hood either.
The link posted above is the way I would go, or just get a bolt on scoop. It's all for show anyway.
Ron..
2008 Roush 427R
2014 V6 Prem
rmb427r is offline   Reply With Quote
Old 12-12-2014, 12:43 AM   #9
Cooolbreeez's Avatar
That's nice, real nice.
Cooolbreeez is offline   Reply With Quote
Old 12-12-2014, 02:59 AM   #10
bucko's Avatar
In "the day" when hoods got cut in their center, it was to direct air to the air cleaner that sat on top of the carb. We all now have a factory "CAI", with the air box in the front, drawing cool air from the front grill for our fuel injection vehicles.
They even got smarter "in the day" by creating cowl induction: the air scoop was rearward to the windshield, drawing the cooler air from there, and lowering the wind resistance by not having the hood scoop face forward.
As far as cooling, the engineers already have that figured out. I have yet to read a post on a 2011 and up Mustang with an overheating problem due to factory design.
It would not be a worthy mod performance wise; if you are after looks over function, then sure, go for it.
Old 12-12-2014, 04:37 AM   #11
Strange Mud's Avatar
Yes it'll be cooler. No it won't make a difference other than on paper.
I would not do it.
Old 12-12-2014, 11:36 AM   #12
grom80's Avatar
Cool. I was looking at the Roush scoop because it seams the lowest/less drag than others...
Old 12-12-2014, 01:35 PM   #13
KryptonKnight's Avatar
That small a scoop is for looks PERIOD. By the way, don't bother having your muffler bearings chromed or buying canned seasonal air, cross drilled brake lines, electrodeless spark plugs, or even a heavy duty clutch belt. Seriously, there is nothing you can so for a few dollars that is going to improve your performance. $100's perhaps yes. The best thing you can do is spring for a $400 SCT4 tuner.
CAI,6pt.Cage,FRPPSprings,Raptor,UDP,Hurst,SiliconeHoses,BossStrutBar,LoudMouths,Plenum,Cam,Brake,Battery,StrutCovers,FRPP PC.ValveCovers,Chin Spoiler,Hood Scoop&Pins,painted 10"Stripes & Pins,EleanorGrill,Chin Spoiler,"C" Scoop,1/4 Side Scoops,Rear Fascia,PJ Rear Louvers,Roush Skirts & Rear Wing,Triple Pod & Gauges,CF Dash,2010Projector lights,2014Taillights, Real Carbon Fiber full kit,19" 2014 GT rims.
KryptonKnight is offline   Reply With Quote
Old 12-12-2014, 06:21 PM   #14
rmb427r's Avatar
A heavy duty clutch belt will perform wonders however only if it comes with the special left handed screwdriver for installation.
Ron..
2008 Roush 427R
2014 V6 Prem
Old 12-12-2014, 08:21 PM   #15
VIG
VIG's Avatar
Region: Delaware
You'll also notice performance gains after you get your tuner dialed in with a higher quality blinker fluid. The stuff from the factory is good for a daily driver, but there's more to be had performance-wise with a higher quality fluid.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 12-12-2014, 11:45 PM   #16
Bear376's Avatar
Cutting a hole will do no good.the best way to go is a replacement hood with an air extractor where the hot air from the engine is drawn out at the windshield. The Roush hood scoop has a solid front. You would have to modify that too, and I doubt it could be made pretty. You would still have to have an extractor port, or take a chance that the scoop would damage the hood from air pressure. Keep looking for a hood. There are some very nice ones out there.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Hood Scoop to hide Shaker Scoop 08Mustang 2005-2010 V6 Mustang 5 06-04-2012 08:27 PM
hood scoop, 99-02 hood, and wheels bmw ponyman Mustang Parts for Sale and Wanted 4 03-27-2007 06:44 AM
'02 Black Mustang Hood w/ GT Hood Scoop mattstang Mustang Parts for Sale and Wanted 8 08-22-2006 09:11 AM
Hood Scoop + 04 base model hood Exit_In_Red Mustang Audio & Video 7 10-22-2004 06:10 PM
WTT: Redfire '03 V6/Cobra hood for GT hood w/ scoop tire Mustang Parts for Sale and Wanted 0 02-21-2004 10:07 AM
02:22 PM
