Koni Yellow setting. - Mustang Evolution
Old 12-12-2014, 02:46 AM   #1
Rileychan01's Avatar
Just installed the Koni yellow on my car. Wondering what's the best stiffness setting to fit my H&R SuperSport springs? I like cruising in canyon road and occasionally track it. thanks in advance guys!
Rileychan01 is offline   Reply With Quote
Old 12-12-2014, 05:08 PM   #2
willb2305's Avatar
Stiffening the front shocks would make the car understeer more, softening the front shocks would make the car oversteer more, stiffening the rear shocks would make the car oversteer and softening the rear would make the car understeer. So basically stiffening one end of a car takes grip away from that end, while softening one end of a car adds grip to that end. Softer shocks provide more grip. So you want soft in the rear and stiffer up front.
If you go through canyons you will want stiffer shock settings because stiff suspension reduces body roll in corners which permits more rapid direction changes. Might want to try full soft in rear or 1 click from full soft in rear and full stiff in front for canyons and turns. It might take a couple tries to get the settings just right also get sway bars they will help massively with twisties and wider tires in the rear for more grip.
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
Old 12-12-2014, 06:22 PM   #3
Driven5's Avatar
A stiffer front, softer rear, and wider rear tires?...That sounds like a recipe for terminal understeer.
In regards to handling, dampers are ultimately just a fine tuning tool for transient behaviors, while springs and sways are the primary tuning tool fot steady state characteristics. For street cars, focusing on simply tuning the damping to the springs for ride control is going to be a good general starting point.
-Justin
You can follow my Ford based 'Locost' build at:
GarageOdyssey.blogspot.com
GarageOdyssey.tumblr.com
@GarageOdyssey (instagram and twitter)
Driven5 is offline   Reply With Quote
Koni Yellow or Koni Orange Rileychan01 2011-2014 V6 Mustang 4 08-13-2014 07:04 PM
Koni Yellow's or FRPP adjustable kramer 2011-2014 Mustang GT 0 03-25-2014 05:43 PM
Koni Yellow Drag Strip OzzyLiriano 2011-2014 Mustang GT 19 09-05-2013 08:46 AM
Koni Yellow Sport Shocks vs Tokico Illuminas vs Bilstein HD - with H&R SS springs? paradigm 1996-2004 Mustang GT 11 07-16-2013 07:43 PM
Koni Yellow Adjustable Stut&Shock Install OzzyLiriano 2011-2014 Mustang GT 0 03-05-2013 05:52 PM
06:51 AM
