Got an Ebay 3.7 CAI, and looks like well made - Mustang Evolution
Old 12-13-2014, 11:09 AM   #1
Toydos's Avatar
Very impress with this Ebay 95$ at my door CAI. Overall not cheap looking , the couplings are not silicone but the rubber looks strong and up to the task. It even comes with an inlet restrictor like the high$ name brands CAI, the filter looks well made with a big mouth and the metal box is not flimsy.>>Click image for larger version
ID:	171761 got this CAI FOR LOOKS AND A BIT OF SOUND
[SIGPIC] My other toy and babe
Toydos is offline   Reply With Quote
Old 12-13-2014, 11:13 AM   #2
GrabberMeBlue's Avatar
I know I asked this before, but how come I only see one nipple for connecting the vacuum lines like for a stick? Is the second one just harder to see from the pictures?
2012 Grabber Blue Mustang Convertible V6 Premium
1979 Solar Gold Trans Am
1995 Bright Red Trans Am Convertible
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 12-13-2014, 11:19 AM   #3
Toydos's Avatar
Look at the 2od pic and you will see the tube for the Auto with a cap
Old 12-13-2014, 11:23 AM   #4
Ok. Way over there...
1979 Gold Trans Am
Old 12-13-2014, 11:23 AM   #5
FastFord13's Avatar
Isn't your pipe connected to your filter backwards? The opening for the sensor should be down by the filter, no?
Sent from my Nexus 5 using Mustang Evolution mobile app
Old 12-13-2014, 11:27 AM   #6
FastFord13's Avatar
Old 12-13-2014, 11:33 AM   #7
Toydos's Avatar
Originally Posted by FastFord13 View Post
Isn't your pipe connected to your filter is backwards? The opening for the sensor should be down by the filter.
In that position the restrictor inlet will block the the sensor opening and routing will be wrong.
Old 12-13-2014, 11:36 AM   #8
JoeyM91's Avatar
Well....good luck.
Old 12-13-2014, 11:50 AM   #9
Here is OEM. It is well before the vacuum lines. Not sure if that is going to make a difference.
Name:	ImageUploadedByMustang Evolution1418496622.288772.jpg
1979 Gold Trans Am
Old 12-13-2014, 11:50 AM   #10
Toydos's Avatar
Originally Posted by JoeyM91 View Post
Well....good luck.
I will installed it next week , doing a family visit in GA this coming weekend and that way will avoid any issues away from home. Will post results on install later
Old 12-13-2014, 11:54 AM   #11
FastFord13's Avatar
OK..... Its been a while since I installed mine but I thought I remembered the wire being pretty short for the maf sensor. Keep us posted on the results!
Old 12-13-2014, 11:55 AM   #12
Toydos's Avatar
Attachment 171764
A have manual trans , but I see no issues with the vaccum line position
Old 12-13-2014, 12:20 PM   #13
Toydos's Avatar
I did reverse the sensor position next to the box and it does fit and the inlet restrictor type tube is not blocking the sensor , will see after the actaul isntall and see how the routing configuration works out . Any here with info will be welcome.
Old 12-13-2014, 12:38 PM   #14
FastFord13's Avatar
Thumbs. When is the install?
Old 12-13-2014, 02:29 PM   #15
Chaz12's Avatar
I have the same exact intake installed. I installed yesterday. Click image for larger version
Name:	ImageUploadedByMustang Evolution1418506115.414374.jpg
ID:	171773Click image for larger version
Name:	ImageUploadedByMustang Evolution1418506133.978736.jpg
2013 Premium Performance White
Bama 91 Race tune, GT500 blue racing stripes with matching hash marks and side stripes, cold air intake, Flowmaster super 44s with Roush 4" Tips, CDC performance grille, side scoops, painted quarter windows, all lights tinted
Chaz12 is offline   Reply With Quote
Old 12-13-2014, 02:58 PM   #16
Toydos's Avatar
Originally Posted by Chaz12 View Post
I have the same exact intake installed. I installed yesterday. Attachment 171773Attachment 171774
Any issues, did you use the black inner tube/that kooks like an inlet restrictor around the sensor in the install. Did you retain the factory box snorkel
Old 12-13-2014, 04:01 PM   #17
Chaz12's Avatar
Half the snorkel had to come off or else the heat shield will not fit. The other half I left so I do like it. I did have several problems but it seems like it never goes as expected when installing things. I also still need to do some work on it because I rushed the install due to it getting dark and not having any tools besides a wrench and screw driver. You probably want to use a socket wrench to get the stock box out which i did not have so I literally ripped it out.
Old 12-13-2014, 08:57 PM   #18
Toydos's Avatar
I think that the sensor should be closer to the box mimicking the factory set up.
Old 12-13-2014, 09:01 PM   #19
"Cheap" ones can be good! I've had good luck with cheap CAI on other cars.
applebit is offline   Reply With Quote
Old 12-14-2014, 11:22 AM   #20
Chaz12's Avatar
This was the only way I could install it but let me know how you do yours when you do
Old 12-14-2014, 08:54 PM   #21
Voltwings's Avatar
Can you measure the height and Bases of the air filter for me? Want to do some CFM calculations on that thing, just cant help but feel that filter is on the small side.
Old 12-14-2014, 09:37 PM   #22
Here's the link. They have pictures with dimensions.
http://www.ebay.com/itm/Fits-2011-20...560361&vxp=mtr
1979 Gold Trans Am
Old 12-15-2014, 06:48 AM   #23
Voltwings's Avatar
Fits 2011 2014 Ford Mustang 3 7L V6 Heat Shield Cold Air Intake w Red Filter | eBay
Work blocks eaby lol... mind throwing them up for me? Thanks.
Old 12-15-2014, 07:47 AM   #24
Fintile's Avatar
Now why couldn't i find this just last month?! This is what I ended up getting.
BCP Blue 11 13 Mustang V6 3 7L Cold Air Intake Induction Kit Filter | eBay
Worked just fine and i even had a couple extra pieces of piping shipped to me. When i tried to send them back they just told me to keep them so I now have 3 intakes...just no extra filters or couplings. I also did a Datalog with BAMA my last revision was ridiculous! Car responds better than ever before....anyway....Ive been looking for a heat shield for mine as the idle temp tends to rise to about 110*-112* and this was 3 weeks ago when it was 55* outside.
Fintile is offline   Reply With Quote
Old 12-15-2014, 08:12 AM   #25
5" at the top, 6" at the bottom, 5.6" high. However, someone who bought one of these should probably measure the element itself, because it looks like from the picture that the 6" is possibly the hole on the bottom and not the actual element itself.
1979 Gold Trans Am
Old 12-15-2014, 12:14 PM   #26
Voltwings's Avatar
So lets say the Ebay filter is 5 x 5 x 5.6, That comes out to 527 CFM of flow through that filter.
I called Air Raid and got the specs on the 3.7L filter as 6" Base x 7" height x 4.4" base. This works out to 685.776 CFM.
Now, that may be a completely useless calculation, but the air raid does seem to flow a bit better than the ebay one. Granted that does not mean the Ebay one doesnt, or cant, flow enough for the engine; the Air raid could be overkill. It just means it doesn't flow as much as the air raid, take that for what it's worth.
CFM Calculations:
Air Filter Calculations
Old 12-15-2014, 01:42 PM   #27
Fintile's Avatar
CFM Calculations:
Very true, but its usually more a factor of the intakes design itself...a different filter can always be used, but the internal diameter of the intake and the amount of bends/ material it is made out of I feel make a bigger difference. Look at the STEEDA CAI vs AIRAID...its not the filter that changes it so much as its the overall size and material.
Old 12-15-2014, 01:51 PM   #28
Voltwings's Avatar
You're absolutely right. However, a system only flows as well as its most restrictive piece. Even if the intake itself is well designed, the filter is (could be*) holding it back at that point and it would make no difference. Someone did some excellent CFM calculations on this forum for the 3.7 engine a while back, i'll see if i can dig them up.
It really doesnt matter much in the grand scheme of things, but its kind of fun to see, and i'm bored at work haha.
Also, anyone with the (or any i guess) Ebay intake, can you post a datalog for me? I'd like to check the stability of the MAF voltage against another "name brand" intake. That could be kind of neat to see as well.
Old 12-15-2014, 02:26 PM   #29
Fintile's Avatar
If you still have mine in your email you will see....Ive been using it on a BAMA 93 R tune...Ill see if I can dig it up though...maybe resend it..
Old 12-15-2014, 02:49 PM   #30
Voltwings's Avatar
Oh, i didnt realize you had it on with those logs. If you have a more recent one send me that, otherwise i'll go look for that one this evening and compare it to my GFs air raid.
Old 12-15-2014, 02:56 PM   #31
Fintile's Avatar
That was while i was data loging. so the one you have is the most "raw"
Old 12-31-2014, 12:33 PM   #32
Fintile's Avatar
Volt. Any chance you found the datalog?
Old 12-31-2014, 12:36 PM   #33
Voltwings's Avatar
Whoops, complete derp on my part. We're actually going to be doing some logging with MPT here shortly working on an E85 tune, so i'll have a fresh set of logs here within the next few weeks to use for comparison.
Old 12-31-2014, 06:05 PM   #34
Fintile's Avatar
Oh damn, that would be nice to get an e85 tune. Keep me posted
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Old 12-31-2014, 07:39 PM   #35
Diehard's Avatar
"a system only flows as well as its most restrictive piece."
Not entirely true. The final flow is affected by the total pressure loss, which includes everything in its path. i.e. the flow through the filter itself is affected by differential pressure, which is affected by the total pressure losses. Granted the tube itself may not amount to a heck of a lot.
cai
Well looks like i'm gonna be dead within 6-8 months timpryor The Bar 31 03-02-2007 09:34 AM
Well well well England, you are turning into the country of the FATTIES Seph The Bar 10 02-28-2007 04:10 PM
well looks like i might be a traitor Kyle The Bar 77 12-02-2006 01:48 PM
Well guys looks like my bad luck continues..... Brent The Bar 17 12-19-2003 12:41 AM
11:54 PM
