mustang v6 2012 air condition after use the hot air do not blow cold air - Mustang Evolution
Old 12-13-2014, 02:59 PM   #1
blackout2012's Avatar
Hello guys this just happen after have be use the hot air for couple day and now when i try the cold like always air not work what can be ??
blackout2012 is offline   Reply With Quote
Old 12-13-2014, 07:42 PM   #2
Did you click the AC button back on or just turn the knob to cold? You need to do both to get the cold air back.
CUBuffalo is offline   Reply With Quote
Old 12-13-2014, 07:50 PM   #3
Hello and yes is working fine this happen today after the wird day of cold in Miami and today ready to use the air condition but only hot air i check fuse anything. The last option is check the frion
Old 12-13-2014, 11:22 PM   #4
Check the belt too. That happened to me with 200mils on my 2014.
Sent from my HP SlateBook 10 x2 PC using Mustang Evolution mobile app
fission is offline   Reply With Quote
Old 12-13-2014, 11:25 PM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
That's a good starting point. May just need a top off. When you switch over to A/C and pressure the button too, there should be a noticeable difference in output pressure. Are you getting that? Also, I hope you aren't using freon, as it was deemed a greenhouse gas and may actually be illegal to use now/in the near future. I believe it's been replaced with a refrigerant called R-410A.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 12-14-2014, 08:17 AM   #6
What wird issue ! Just one day cold in florida and my Pony not like it!! 😜 anyway what I will do next check the if the system has the correct freon i hope is that ready check:
Fuses , filter cabin door all air vent and disconnect the negative from the battery to reset ( possible ) the system....... Let see what next!
A/C doesnt blow cold XSlashDashX 1996-2004 Mustang GT 39 06-05-2013 07:18 PM
94gt factory cold air intake vs aftermkt cold air intake justjake94boss 1979-1995 Mustang GT 1 04-15-2012 12:22 PM
Blow by blow racings 2011 GT DDTCM 2011-2014 Mustang GT 7 11-11-2010 08:59 AM
Where to buy a 1967 Mustang Fastback in black for about 10-15 grand not in best condition? akira4 Classic Mustangs 1 08-24-2009 01:43 AM
What Oil Filters TO Use, And Not To Use JROC General Car Discussion 10 02-24-2007 09:19 AM
09:17 PM
