It used to be a rental, bought it at 50k miles, now at 65k - Maintenance Questions - Mustang Evolution
Old 12-18-2014, 05:02 AM   #1
It's been a year since I've had my 2012 V6. I bought it from a rental agency at ~50k miles. I took it to the dealer and they thoroughly inspected it and gave me the okay to buy it, so I went with it. Now at 65k, I have zero problems.
But I've come to realize that I should probably pay more attention to the maintenance. All I've done is change oil every 3k. I use regular, but after scouring the threads here it's clear that I should make the switch to synthetic. But what else should I budget for so I can keep this car for a while? I don't know much about cars to be honest. I drive in Los Angeles where there are a lot of highway miles, and much more stop-and-go traffic. I'd just like to know some things to keep in mind so I can budget for and have them done over the next few months.
zizour10 is offline   Reply With Quote
Old 12-18-2014, 05:41 AM   #2
fenixignition's Avatar
use name brand fuel, or at least popular stations, more use = more new fuel shipments. being la, That shouldnt be tough.
Highways, go ahead and bolt it. the best way to clean out your engine is hard driving. all that heat out the exhaust gets rid of carbon deposits. especially those california cats. You dont have to use synthetic oil if you use a good brand. But technically, it is a better oil. Dont waste your money on oil flushes or too many additives in the fuel. proper maintainence goes a long way. do a coolant flush. change transmission fluid. and flush your break fluid if you can at some point. fluids are better clean.
2002 GT 5sp. 16x,xxx miles
Old 12-18-2014, 07:53 AM   #3
Commercial Member
au01st's Avatar
I'll just say, people like me are the reason I would never buy a rental car, lol.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 12-18-2014, 08:00 AM   #4
True that. But hey, if the dealer inspects it and says okay and its only 50k, with a really good price i'd probably take it too. But yea, not only is it a rental, its a rental mustang. Im sure its seen its redline quite a bit.
Old 12-18-2014, 08:14 AM   #5
Strange Mud's Avatar
use your OLM (oil life monitor) and change it when it gets to 20-30% (you'll see other opinions) do the recommended maintenance in the owners manual and you should be good. Avoid dealers that try and up sell procedures not in the manual.
enjoy the ride.
Old 12-18-2014, 04:53 PM   #6
Is the OLM accurate to go by? The reason I ask is I'm at 4k miles from my last oil change (regular oil) and it's indicating 70%. That can't be right?
With the transmission and steering fluids, when should those be changed and how much do they cost?
Unrelated, but my mechanic is charging me $240 to change all four breaks. Is this reasonable?
---------- Post added at 05:53 PM ---------- Previous post was at 05:53 PM ----------
Old 12-18-2014, 06:14 PM   #7
paintmann111's Avatar
It's designed for synthetic blend/ full synthetic, if your not using either DO NOT go by the OLM.
paintmann111 is offline   Reply With Quote
Old 12-18-2014, 09:31 PM   #8
I second that. My dad uses Costco fuel exclusively in SoCal (for his '13 Forester), and his car started making weird noises and having performance issues. His mechanic buddy told him it was his fuel injectors, directly caused by ****ty fuel, and he changed it for him for free.
mkashew is offline   Reply With Quote
Old 12-18-2014, 09:49 PM   #9
Be extra careful with rentals since they are often treated like crap. Change every single fluid in that car. Motor oil, transmission, rear end, brake, coolant ect............. Go over the suspension with a fine tooth comb, people generally aren't nice on rental car suspensions.
Old 12-18-2014, 09:50 PM   #10
I've had very good luck with Costco fuel. Always use 91 octane, i'm up in NorCal.
Old 12-18-2014, 10:14 PM   #11
Driven5's Avatar
I can't speak to the fuel quality, but around here gas stations don't get much more high use than Costco.
Just follow the Ford recommendations for oil quality (as a minimum) and change interval as stated in the owners manual. On every modern engine I'm aware of, even ones calling out conventional oil, 3k change intervals are nothing more than an unfortunate myth.
In fact, your owners manual is a great place to start reading if you want to learn pretty much everything you need to know for basic maintenance requirements...Among other things.
-Justin
You can follow my Ford based 'Locost' build at:
GarageOdyssey.blogspot.com
GarageOdyssey.tumblr.com
@GarageOdyssey (instagram and twitter)
Driven5 is offline   Reply With Quote
Old 12-18-2014, 10:17 PM   #12
Stangholio's Avatar
Didn't costco make the list for top tier gases?
GHIGitty
Stangholio is offline   Reply With Quote
Old 12-18-2014, 11:33 PM   #13
ninerone's Avatar
Yes, Costco - more specifically Kirkland - brand fuel is on the list of companies that add more cleaning solutions to their fuel and is considered a top-rated brand. It needs to be a Costco that sells the Kirkland with additives brand - though I'm unsure if any Costco sells anything else anymore. You used to have to pick and choose your Costco.
My last Mustang, 2011 V6 Premium, was a former rental, though it only had about 35k miles on it when I bought it. Still, never had a single problem with it and I put it through the paces plenty. Regular oil changes and getting those multi-point inspections is good advice for any car, not just former rentals.
Also, no matter how badly they are driven, they are usually VERY well maintained by the rental agency - the last thing they need are cars that break down on their customers.
2014 GT / Black / 6-speed manual
Airaid CAI / Roush Exhaust / Bama Tune /
Custom Vinyl / Shelby Spoiler
ninerone is offline   Reply With Quote
Old 03-08-2015, 02:33 PM   #14
Region: Wyoming
I've had a couple of lease return vehicles and I've never had problems. I agree, Rental companies fix problems right away and maintain them well because a car on the lot makes no money
Dr RC is offline   Reply With Quote
Old 03-08-2015, 02:51 PM   #15
brandonhgt's Avatar
We have used Costco for several years in several different cars, a few which "required" premium. Never had any problems and I saw a study years ago where it was rated highly.
2003 GT Vert- Centennial Edition
brandonhgt is offline   Reply With Quote
Buying a used fleet/rental? aap488 2011-2014 V6 Mustang 57 07-03-2014 06:38 PM
Maintenance need after 100000 miles high performance mustang? felan General Mustang Discussion 0 08-26-2009 01:30 AM
Please help my Steve McQueen inspired 67 mustang get a $50k up grade wedge 67 New Member Introductions & Greetings 23 08-03-2006 05:47 PM
black 2000 GT, around 65K miles for $8500! whipster24 Mustangs for Sale and Wanted 0 10-28-2005 02:42 PM
50k miles Monkey The Bar 5 11-06-2003 03:53 PM
04:46 AM
