'13-14 swappable GT parts - Mustang Evolution
Old 12-21-2014, 10:15 AM   #1
Prezona's Avatar
Hey guys, today I was sitting here wondering what could I do to make my car perform better(like I always am) and I started to think about which parts from the stock GT are swappable to our v6 That would provide a performance upgrade.
Prezona is offline   Reply With Quote
Old 12-21-2014, 10:22 AM   #2
natestang07's Avatar
The engine
But as far as part swaps go you are better off looking towards the aftermarket
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 12-21-2014, 10:30 AM   #3
Prezona's Avatar
The engine
Haha!! Really, nothing at all? I read something about the brakes for minor improvement. I would totally go aftermarket but I can get ford parts virtually free through my work so that's why I'm seeing what I can pull off of a GT haha
Old 12-21-2014, 10:31 AM   #4
The only thing I can think of is the throttle body, but I really think that is pointless
Old 12-21-2014, 10:32 AM   #5
+1 on the after market but wheels, strut tower brace, brake rotors I would look into oem for cheaper upgrades
Bigshow14 is offline   Reply With Quote
Old 12-21-2014, 10:33 AM   #6
Ah yeah the strut tower brace would be nice to pick up!
Old 12-21-2014, 10:56 AM   #7
VIG
VIG's Avatar
Region: Delaware
If you're going I do the strut tower brace it's got to be from the boss. The OEM GT strut tower brace won't clear the intake manifold of the V6.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 12-21-2014, 11:43 AM   #8
Prezona's Avatar
Strut tower brace!! Nice thought!
Throttle body? Will that bolt right onto the v6?
And yeah I think I'm definitely going to pick up the rotors.
Old 12-21-2014, 12:53 PM   #9
Matts14fp6's Avatar
Sway bars,
Matts14fp6 is offline   Reply With Quote
Old 12-21-2014, 01:33 PM   #10
Throttle body will not bolt up. Requires machining
sledge42hammer is offline   Reply With Quote
Old 12-21-2014, 04:09 PM   #11
Cise's Avatar
Does the over axle pipe with the resonators bolt up?
Cise is offline   Reply With Quote
Old 12-21-2014, 04:57 PM   #12
iguanaman3's Avatar
You will need the GT caliper brackets to make the GT rotors fit. If you could get me a set of GT brackets too I would make it worth your while or at least the part #s. They seem to be hard to find.
iguanaman3 is offline   Reply With Quote
Old 12-21-2014, 09:21 PM   #13
rob.james.arias
Guest
Posts: n/a
This is the Boss strut tower I have on my 3.7? I thought I had a plain jane gt strut tower brace. (Its black because I painted it).
Old 12-21-2014, 11:30 PM   #14
Bear376's Avatar
The only thing I know of that is swappable and would make an improvement, is the struts and shocks. And that was only when you could get take-offs from Roush really cheap. Everything else is designed for the added weight of the 5.0 and not worth the effort. I would recommend going with the FRPP N springs if you want to lower the car, but everything else, look to your goals and find a manufacturer that delivers that. For my wants, I went with the Whiteline suspension parts and Koni shocks/struts.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 12-22-2014, 06:14 AM   #15
Voltwings's Avatar
OEM GT shocks / struts / springs will bolt right up to a v6, we've done it, and it actually sits quite well with the Eibach sportline springs (the 1" GT drop, i believe its the sportlines)
Really suspension pieces are the only things worth bringing over, but all those pieces should just be swapped with aftermarket if you're going through the trouble.
The 5.0 and V6 use the exact same caliper, the GT just uses a 13.2" Rotor and the V6 a 12.5", so you'll need the larger GT caliper Carrier to clear the larger rotor. I bought my Fiance' a set of 5.0 take offs from a guy that swapped to Brembos and got Calipers, pads, rotors shipped for $170. Just the new carriers themselves from Ford are $150 so its worth taking a look. That being said, most people that swap to Brembos race, and the kit i bought had been trashed, going to need a complete rebuild as far as the boots and seals are concerned, but thats another $30 in the grand scheme of things; i'll make a thread on it here soon.
Old 12-22-2014, 08:57 AM   #16
VIG
VIG's Avatar
Region: Delaware
Yep the Boss and V6 with performance pack use the same STB. It arches up more than the OEM GT brave to clear the intake. Same as the V6.
Old 12-22-2014, 10:37 AM   #17
Strange Mud's Avatar
how about the 5.0 badges?
poor impulse control
Old 12-22-2014, 10:42 AM   #18
JoeyM91's Avatar
Don't start that again.
Old 12-22-2014, 10:44 AM   #19
TedG's Avatar
This is the OEM strut brace for the 3.7
It comes with the Performance Package, or after-market.
Become an Organ Donor today: http://donatelife.net/register-now/
Save as many as 50 lives. Thanks.
TedG is offline   Reply With Quote
Old 12-22-2014, 02:20 PM   #20
Fintile's Avatar
Also too the GT 500 STB works as well. i have one off an 07 GT500...its a little tight closing the hood but all in all it works.
Doesnt bolt up but you could always have it welded in...the GT H pipe fits right up in there as well. I had my oem mid pipe cut out and the GT H slipped right over the pipes and the shop just welded from there...10 min job.
Please do...Im 100% a visual learner and you can tell me all day how to do it and Ill still question if im doing it right. At least if i see someone in the process of swapping the rotors or doing the suspension I'll be good to go.
Fintile is offline   Reply With Quote
Old 12-22-2014, 03:06 PM   #21
yellowconve's Avatar
lol
yellowconve is offline   Reply With Quote
Old 12-24-2014, 05:37 AM   #22
jande063's Avatar
I am pretty pleased with my brembo conversion.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 10:04 PM
Crazy Singe Port Performance Parts/ 94-03 Parts Forged! v6stanger Mustang Parts for Sale and Wanted 4 10-27-2006 12:13 PM
4.2 split port engine parts/torque converter/steeda parts Horse Mustang Parts for Sale and Wanted 33 03-17-2006 04:03 PM
parts parts!!! whipster24 The Bar 1 04-22-2005 04:37 PM
11:59 PM
