How to evaluate knock values on sct x4 - Mustang Evolution
Old 12-23-2014, 09:20 AM   #1
JR4288's Avatar
Can anyone tell me what the knock sensor values mean when datalogging using an x4. I know what knock is but I have negative and positive values on my datalogs and don't know what this means
JR4288 is offline   Reply With Quote
Old 12-23-2014, 09:22 AM   #2
Voltwings's Avatar
The knock sensor PID is measuring crank degrees in the direction of rotation that are added to or subtracted from the normal (usually borderline knock table) spark timing.
When the KS PID reads positive numbers, it means there are more crank degrees at ignition, which means a spark that happens later than normal, and most people call that ******. A negative number means fewer crank degrees at ignition; sure enough, that's ADVANCE.
When you first encounter it, it seems odd, but once you understand it, it makes sense.
You should normally see negative numbers as the KS looks for incipient knock - that's how the gets the most power out whatever octane you're running. It hunts relentlessly for the edge of knocking. Positive values mean your spark tables are providing too much advance.
In laymen's terms, this means "negative knock," is the computer adding more timing, and "positive knock" means the computer is pulling timing due to actual knock.
Taken From: How to: Understand your datalogs
Old 12-23-2014, 10:13 AM   #3
JR4288's Avatar
In either case is there damage to the engine?
Old 12-23-2014, 10:16 AM   #4
JR4288's Avatar
I get negative at the beginning of the pull and then it's zero through the middle and then positive near the end of the run
Old 12-23-2014, 10:21 AM   #5
Voltwings's Avatar
The ecu's logic allows the car to add timing to increase power. That's negative knock, and that's normal.
Positive would be the computer removing timing due to what it deems "knock events." Not going to cause any immediate issues if the numbers are not anything outrageous, but obviously even small amounts of knock should be addressed with your tuner.
Torque Values for Spring Change nitrous2v 2011-2014 Mustang GT 5 03-31-2013 08:09 PM
No 2013 car values on KBB yet, whats up with that? BUSHGUTS 2011-2014 Mustang GT 2 02-13-2013 02:50 PM
Need values on 2 Mustangs? adom Classic Mustangs 5 03-18-2010 08:00 PM
Knock Knock *Language* Brent Pictures and Videos 3 04-03-2008 04:18 PM
It's time to re-evaluate our involvement Ken The Bar 3 04-22-2004 01:33 PM
05:14 AM
