Burn out - Mustang Evolution
Old 12-24-2014, 12:58 PM   #1
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
Burn out
Can't seem to get my car to do a burnout. I put my foot on the break and give it gas but no luck #automatic #advancetractionOff
roushMarlon831 is offline   Reply With Quote
Old 12-24-2014, 01:04 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Do hashtags even work on this forum? The '13-14s require a tune to disable the throttle cutoff when trying to do a burn out.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 12-24-2014, 01:06 PM   #3
Originally Posted by WhoDat View Post
Do hashtags even work on this forum?.
No they don't.
Old 12-24-2014, 01:08 PM   #4
Vic14's Avatar
Lol.
On the newer models there's a limiter on the cars so can't do burnouts. But it can be removed; only need a tune to remove it.
"I know I was born and I know that I'll die... The in between is mine." -Pearl Jam
Vic14 is offline   Reply With Quote
Old 12-24-2014, 01:30 PM   #5
jayochs's Avatar
really? that's funny. not that I ever do burnouts but it's funny that I can't bc they disabled the ability. lol
Sent from my Samsung Galaxy Note 4 using Tapatalk.
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 12-24-2014, 04:40 PM   #6
Voltwings's Avatar
Did you just push the advance trac button or hold it for 10 seconds?
Old 12-24-2014, 04:58 PM   #7
What does it do when you hold it for 10 seconds?
Sent from my HTC One_M8 using Mustang Evolution mobile app
sam 76 is offline   Reply With Quote
Old 12-24-2014, 05:15 PM   #8
jayochs's Avatar
completely turns off advance trac.
hitting it only turns off traction control. holding it will turn the whole system off
Old 12-24-2014, 05:23 PM   #9
Cool, thanks for the info.
Old 12-24-2014, 05:27 PM   #10
Matts14fp6's Avatar
Mine doesn't say anything when I hold it down for 10 seconds
Matts14fp6 is offline   Reply With Quote
Old 12-24-2014, 05:32 PM   #11
Rapinator126's Avatar
Foot has to be on the brake also. Should only be 5 seconds.
Old 12-24-2014, 05:35 PM   #12
JimC's Avatar
Turning off TCS and Advance Track doesn't work on the 2013+ for doing a burn out. You can turn them off but the torque management system will still limit the engine to no more than 2,000 rpm when you do a brake stand - you can drop the accelerator to the floor and it won't make a difference.
You need a tune to override the torque management. When the 2013 came out that was the first thing those of us who go to the drag strip discovered. My car was the test mule for Doug when he was with C&L and it took a lot of tune adjustments to find the right combination. He sent me one where the TCS and Advance Track was turned off completely in the tune and it didn't make a difference. He also sent me a new street tune that day to try out and give him so driving impression about - that one turned out he found the right combination and I called him and told him that the race tune didn't work but whatever he did on the second tune had the clue. He spent the next day going through it again to see what he changed that could account for the ease of doing a burn out on that tune. Within 2 weeks every tuner was able to tune it out.
JimC is offline   Reply With Quote
Old 12-24-2014, 05:44 PM   #13
Burn out
Yea I've turned the advance traction control off completely. I also have the bama tuner.. There's a section where it gives me a choice of selecting what Rpms I want when I'm on neutral or when I want to rev.. Is that were I need to configure in order to burnout or do I have to get a custom tune?
Old 12-24-2014, 05:52 PM   #14
Geok.91's Avatar
You can do donuts though lol
Geok.91 is offline   Reply With Quote
Old 12-24-2014, 06:49 PM   #15
Laquisha's Avatar
It's a V6. No need to do a burnout.
Naturally Aspirated Is Lyfe
Old 12-24-2014, 07:00 PM   #16
This guy is no help at all^ just cause it a v6 doesn't mean anything. There's v6's capable of destroying v8's
Old 12-24-2014, 07:05 PM   #17
On the 2013 and 2014 Automatic Mustangs have boa and limits rpm in gear brake on to 2000 rpm . You will need a handheld tuner or have a tuner remove it . Most can tunes have it removed. It is in the torque management part of the program. If you have a tuner from Bama it should already removed ,if not call them and they should take care of that for you. As a self tuner i would have a custom tune done if you have mods done.
hope this helps
Merry Christmas
:dance
efiv6 is offline   Reply With Quote
Old 12-24-2014, 07:18 PM   #18
Nygreenmachine's Avatar
There is a trick to do a burnout.Turn advancetrac fully off then put the car in sport mode and shift up to third gear while still standing still. Then floor the gas while holding the brake and downshift into 1st. You will do a burnout.
2014 DIB V6
Nygreenmachine is offline   Reply With Quote
Old 12-24-2014, 07:47 PM   #19
jayochs's Avatar
whats sport mode??
Old 12-24-2014, 07:48 PM   #20
Laquisha's Avatar
Originally Posted by jayochs View Post
whats sport mode??
Did you not read your users manual for your car after you bought it?
Old 12-24-2014, 07:51 PM   #21
JimC's Avatar
It has to be configured in the tune - the parameters aren't open on your handheld.
Old 12-24-2014, 07:54 PM   #22
JimC's Avatar
And how long do you think that transmission will hold up to that? Might as well just do a full neutral drop if you are going to do this.
Don't follow this advice OP - you will be leaving your transmission parts behind eventually. Just have the tune adjusted to remove the torque management controls.
Old 12-24-2014, 07:56 PM   #23
JimC's Avatar
Ahh, a V8 god shows up. From my observation most of the V8 gods who say this never go to the track anyway - so the extra 2 cylinders are wasted on them - wow, so your V8 can get to the next stop light how many milliseconds quicker than a V6?
Old 12-24-2014, 08:03 PM   #24
Vic14's Avatar
Lol 😂
Maybe he has a manual and that's why he doesn't know about sport mode?
Haha 😂😂
Old 12-24-2014, 08:08 PM   #25
Diehard's Avatar
whats sport mode??
Sport mode is on Automatics only. Another drive with more aggressive automatic shifting and the ability to manually tap through the gears.
Old 12-24-2014, 08:10 PM   #26
jayochs's Avatar
oh, so that's why I didn't know what it is, seeing as mine is stick.
yeah sorry, I skip over anything "automatic" in the users manual.
Old 12-24-2014, 11:02 PM   #27
JUST DID IT.. This work. Thanks bro
Old 12-24-2014, 11:04 PM   #28
Just tried it and it worked!! Thanks a lot
Old 12-24-2014, 11:40 PM   #29
I'm sure if you do this everyday your transmission will get messed up but if you try it a couple times everything will be fine.
2014 DIB V6
Old 12-24-2014, 11:48 PM   #30
Commercial Member
au01st's Avatar
Anybody got the over/under on the OP's post count before we see "help my transmission won't shift into 1st"? 500. Any takers?
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 12-25-2014, 12:30 AM   #31
If it's burnouts you want, should've gotten a manual. Slip the clutch a little at the correct RPMs and even most 4 bangers can do quite well. I've rolled smoke off my tires without touching the brakes, even with the 2.73 gears.
Sent from my Nexus 7 using Mustang Evolution mobile app
95Z28 is offline   Reply With Quote
Old 12-25-2014, 05:16 AM   #32
Grabber Blue5.0's Avatar
Bahahahahahahah
Old 12-25-2014, 06:04 AM   #33
jayochs's Avatar
agreed. idk why, but for some reason I just assume everyone drives manual mustangs lol when in fact there's probably a lot more automatics out there...
Old 12-25-2014, 09:13 AM   #34
So for 2013 mustangs they don't want you to do burnouts but the 2015s get line lock at least ford is learning
Brandneutral is offline   Reply With Quote
Old 12-25-2014, 09:50 AM   #35
VIG
VIG's Avatar
Region: Delaware
Under
IG: workshardplayshard
VIG is offline   Reply With Quote
SRT 10 Burn out stampde General Mustang Discussion 10 12-21-2010 11:06 PM
Burn out-traction control? occhopperman27 1996-2004 Mustang GT 19 08-21-2009 02:19 PM
BURN OUT 2007STANG Pre-2005 V6 Mustang 4 06-29-2009 09:13 PM
Bike Burn Out Justin Pictures and Videos 3 02-15-2007 09:48 AM
Burn out/ break stand? calstud1028 Pre-2005 V6 Mustang 14 06-25-2004 07:10 AM
10:47 AM
