Ford Ambient Light Kit/Interior Lighting - Mustang Evolution
Old 12-27-2014, 06:43 PM   #1
Kevin.Cook
Guest
Posts: n/a
I tried searching on here but could not find a post with this exact question. Has anyone ever installed the Ford Ambient Light kit on their 2010-2014 Mustang? If so, how were the end results and how rough was the install?
This is the kit with 2 leds for the footwells and 1 led for the cup holder. I did install a cup holder/bezel with the mycolor led ring. My car did not come with Mycolor so I am not sure if I can wire it into other existing wiring to get it to light up. I do not care so much about it changing color.
Old 12-29-2014, 08:45 AM   #2
Fintile's Avatar
I dont know if your car comes with any of the connectors (mine came with My Color), but it might just be easier to splice into the wiring for the door lights if you have them or just wire it in to a switch on its own wire connected to the battery.
Fintile is offline   Reply With Quote
Old 12-29-2014, 09:40 AM   #3
Kevin.Cook
Guest
Posts: n/a
Unfortunately, on the newer Mustangs the harnesses/connectors for MYColor are absent if you get a Base. I had to splice my lighted door sills into the dome lights. Since I got the cupholder with the LED ring, i am going to see if I can splice it into the Ambient lighting kit from Ford. This would allow it to change colors but keep its OEM look by using the rings.
If not, then what i may do is drill very small holes behind the LED rings and secure the LEDs from the light kit behind the holes. So it illuminates the rings but doesn't look tacky.
Experienced with 11+ Mycolor/Ambient lighting back n a stang 2011-2014 Mustang GT 10 02-26-2016 09:46 AM
Ambient Lighting Tribbie 2011-2014 V6 Mustang 3 07-11-2014 09:44 AM
Ambient air temp sensor 07 S197 2005-2010 V6 Mustang 6 09-14-2013 04:55 PM
Ambient lighting tgmeyer 2011-2014 Mustang GT 8 08-01-2012 06:17 AM
ambient lighting 04TRV6 General Mustang Discussion 9 07-14-2012 09:41 PM
» Members Mustangs
98 GT
98RedGT
GT
MHochhaus
Add your Mustang
04:34 PM
