3.73 gear question - Mustang Evolution
Old 01-04-2015, 09:22 PM   #1
Matts14fp6's Avatar
3.73 gear question
Has anyone had problems with their stock axles when they installed 3.73 gears? I'm planning on installing mine within the next month or so and was wondering if most switched to a heavier duty axle or to a 31 spline
Matts14fp6 is offline   Reply With Quote
Old 01-04-2015, 09:30 PM   #2
JoeyM91's Avatar
Your axles are already 31 spline. No issues. You can install new axles if you want though since they have to pull them for the install. If you do, Moser is a good go-to brand.
But none of that is necessary.
Old 01-04-2015, 09:42 PM   #3
Matts14fp6's Avatar
I thought our 8.8 rears came with a 28 spline
Old 01-04-2015, 09:46 PM   #4
JoeyM91's Avatar
Nope. 31. Here's a link to the Moser axles.
http://m.americanmuscle.com/moser-31...axle-2005.html
Old 01-05-2015, 07:12 AM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Nope. In 2011 they started using the same rearend in both the GTs and V6s. 8.8" 31 spline. I believe the only difference is gearing options.
2012 Kona Blue 3.7L V6:
5th gear, gear noise? SitinprettyGT 1996-2004 Mustang GT 6 01-10-2013 06:37 PM
Help! 1st gear issue / 5th gear grinding Missxalii General Mustang Discussion 2 06-06-2012 01:18 PM
1st gear & 2nd gear out! Vick Classic Mustangs 3 05-01-2012 08:29 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
10:11 PM
