gears vs. tire sizes - Mustang Evolution
Old 01-12-2015, 03:55 PM   #1
Diehard's Avatar
The best I can determine, increasing the tire diameter by about 2" would effectively be equal to a rear gear ratio change of from 3.31 to 3.55.
Is that right?
Does changing the tire size have the same effect as changing gears?
I know I must be missing something here.
Old 01-12-2015, 03:56 PM   #2
Larger overall tire diameter would equate to a lower numerical gearing.
Old 01-12-2015, 03:58 PM   #3
Diehard's Avatar
Yeah I can see where the rpm per mph is the same but is the effect the same?
Edit: like there's a torque change when you increase the diameter of the tire but I guess it is offset by the toque increase of the higher speed.???
Old 01-12-2015, 04:01 PM   #4
Try using a rpm calculator online. You can plug in different tire heights, and gear ratios to find your rpm at a certain speed. Easy to play around with to see how each affect each other.
Old 01-12-2015, 04:01 PM   #5
This is the one i usually use.
Engine RPM / Engine Speed Calculator
Old 01-12-2015, 04:03 PM   #6
Diehard's Avatar
Yeah thats what I did. That's why I had to check on the final results of power to the road.
Old 01-12-2015, 04:11 PM   #7
Having your tire size go up 2" would be like going from 3.73 to 3.31
Old 01-12-2015, 04:31 PM   #8
Diehard's Avatar
I'm looking at a few different sites and can't agree. (Yet) I'll look again. lol
Look at this site and match 27" with 3.31 to a 3.55 ratio and you get a 29" tire.
Gear Ratio and Tire Size Chart - HowStuffWorks
Old 01-12-2015, 04:39 PM   #9
I see where your confusion is.......
Say you have a 27" tall tire and 3.31 gears. Now, If you upgrade to a 29" tall tire to keep it the same rpms at the same speed you will then need the 3.55 gear. The taller tire counteracts with the numerically higher gear to give you the same rpm. Otherwise, if you upgrade to a 29" tall tire but leave your current 3.31 gearing in, it will now feel like a 3.15 or a 3.00 gear ratio.
Taller tire = lower revs on highway
Numerically higher gear = higher revs on the highway.
Numerically lower gear = lower revs on highway.
So if you were to change your 27" tire to a 29" tire AND say go from 3.55 to 3.31 it will drop the rpms in 2 different scenarios.
This is why if you wanted to say make your rpms higher on the highway, you have 2 options, either get a numerically higher gear OR a shorter tire. They both do the same thing. If you want lower revs on the highway you can either get a taller tire, or a numerically lower gear ratio. Both do the same thing.
Get what i'm trying to say?
Old 01-12-2015, 04:59 PM   #10
Diehard's Avatar
You're absolutely right when you said I was confused.lol
After your explanation and looking at it again it hit me.
I was just playing with the numbers to see what it would take in a tire size change to be equivalent to a gear change. I guess I was backwards, thats why it didn't seem to make sense.
It's tough to get old!
Old 01-12-2015, 05:51 PM   #11
Haha. It's confusing at first. But once it hits you it all makes sense and becomes sooo much more clear.
Old 01-13-2015, 12:07 PM   #12
Fabman's Avatar
Let me add my 2 cents here for clarification.
A numerically higher gear is a lower gear and a numerically lower gear is actually higher numerically.
Confused?
4:10 is a lower gear than 3:55 but it's higher numerically because the numbers are bigger.
It's the ratio that matters. The pinion will turn 4.11 times while the axle will turn once.
Make sense?
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 01-13-2015, 12:14 PM   #13
+1 to above.
Most people get confused by that so I was just saying "numerically" before all the gears.
It's weird
Old 01-13-2015, 12:31 PM   #14
WhiteCali5oh's Avatar
Region: West Virgina
So I have 3.15s and if I go up to a 305 tire. It'll be like having some 2.89s lol?
WhiteCali5oh is offline   Reply With Quote
Old 01-13-2015, 01:05 PM   #15
The width doesn't matter too much. Its more the sidewall. Which remember is expressed as a %.
The difference between say a 275/35-18 and a 305/35-18 is only .8" so its not a huge difference. Might feel like going from a 3.15 to a 3.00. You most likely won't feel a difference.
Now say you went from a 275/35-18 to a 305/40-18 then its a difference of 2" and you will notice the difference.
Old 01-13-2015, 02:53 PM   #16
MustangDawg's Avatar
When I ordered my MPT tunes, they wanted to know the gear ratio as well as the tire size. All are factors in tuning for my V6 auto. Just 2 more cents
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 01-13-2015, 03:05 PM   #17
natestang07's Avatar
That is mostly for speedo calibration I think.
05 Gt Premium Performance White, flowmaster outlaws, Jlt Series 3, Bama 91r tune
Old 01-13-2015, 03:11 PM   #18
Correct.
Old 01-13-2015, 10:56 PM   #19
So right now I have a 295-35-18 and I'm gonna go to either a 305-45 or a 315-40. Will either make much of a difference?
Old 01-13-2015, 11:49 PM   #20
From the 295/35 to the 305/45 it will be a HUGE difference. The 315/40 will make a difference also, but not as much... Still noticeable though.
Tire opinions & tire sizes GT5h0e Mustang Wheels & Tires 6 10-01-2014 05:41 AM
Need help with tire sizes Myles 1996-2004 Mustang GT 7 12-20-2010 07:48 PM
Compare tire sizes, even for different size rims. Otlaw80 Mustang Wheels & Tires 4 06-15-2009 10:03 AM
Tire Sizes for 18's Black95GT Mustang Wheels & Tires 16 04-04-2004 08:33 PM
Tire Sizes Laser02 Mustang Wheels & Tires 26 01-10-2004 12:22 AM
09:54 PM
