What's inside the panhard bar? - Mustang Evolution
Old 01-13-2015, 12:34 PM   #1
Commercial Member
au01st's Avatar
While trying to locate my rear suspension clunk, one of the suggestions was to go hit on various parts with a rubber mallet to see if anything is loose. Everything seems tight and secure, but when I tapped on the factory panhard bar it sounds like the thing is full of pennies. Just curious if anyone has cut this thing open to see what's rattling around in there? Because I may just do that when I install an aftermarket bar.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 01-13-2015, 12:36 PM   #2
Laquisha's Avatar
It's full of antigolacmites to even the pressure out when the tires are rotating. Your fine.
Old 01-13-2015, 12:42 PM   #3
Commercial Member
au01st's Avatar
Oh, I'm not worried about it. More of a curiosity thing.
Old 01-13-2015, 12:54 PM   #4
Yes! From the latin word "antigola" meaning "small beads".
I concur... They are there for a very specifc reason.
Old 01-13-2015, 01:07 PM   #5
Makes me kind of want to check mine. Granted mine isn't a factory unit, and designed for a completely different year. I don't ever remember hearing anything inside of mine.
Old 01-13-2015, 01:13 PM   #6
I've had the front bar off, it is tubular, and I didn't notice anything rattling around inside.
You don't have the factory rear bar anymore?
Old 01-13-2015, 01:15 PM   #7
JoeyM91's Avatar
Yeah the one I took off my 2011 didn't make any sounds either that I remember. I may pull it out of the shed and check it out of curiosity. Maybe I can use it as a rain stick and call down some rain to wash this salt away.
Old 01-13-2015, 01:21 PM   #8
The panhard bar?
I think we are thinking of two different things. Our cars never came with one at all.
Old 01-13-2015, 01:29 PM   #9
The panhard bar?
Haha.
I was thinking sway bar!
I'm going to go climb back underneath my truck and grind some more rust off of the frame now... Carry on fellas!
Old 01-13-2015, 09:41 PM   #10
Bdeysher21's Avatar
Region: Delaware
haha thats exactly what it sounds like when you turn it up and down
Bdeysher21 is offline   Reply With Quote
Old 01-13-2015, 09:48 PM   #11
Commercial Member
au01st's Avatar
Well seeing as I'm going with new upper and lower control arms and sway bars, I'm not terribly concerned about NVH that I add. I just got curious when I was searching for the source of the NVH from the factory and discovered the "rain stick" when tapping around back there.
Old 01-13-2015, 10:23 PM   #12
Only wimps cower from NVH. Men embrace it!!
Old 01-13-2015, 10:39 PM   #13
Commercial Member
au01st's Avatar
Haha, I will embrace the handling improvements provided by new parts.
My old truck, lowered 3" with 267/70/17 tires had terrible NVH, so I just got a louder stereo. I could make the tires rub the inside of the front fenders if I hit the brakes hard enough, lol.
Old 01-13-2015, 11:51 PM   #14
My car squeaks, rattles, clunks, drones ect..... Roll windows down, drop a gear, and hit the apex. You'll forget all of it.
Old 01-14-2015, 11:01 AM   #15
Fabman's Avatar
That's how we connect with the vehicle....
---------- Post added at 01:01 PM ---------- Previous post was at 01:00 PM ----------
Yup....if you can hear all that crap your pipes aren't loud enough.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Good Aftermarket Panhard Bar? Skinsfan6 2005-2010 Mustang GT 7 03-05-2010 10:07 AM
rear sway, or panhard bar? A5295 1979-1995 Mustang GT 12 07-16-2007 08:05 AM
panhard bar eagle05 1979-1995 Mustang GT 12 07-09-2007 08:03 AM
Will a MM Rear Swaybar work in junction with the MM Panhard bar? MustangMatt Pre-2005 V6 Mustang 8 02-02-2005 04:28 PM
Panhard Bar Question njstang97 Pre-2005 V6 Mustang 6 11-07-2004 11:31 PM
05:36 PM
