Suspension Clunk - Mustang Evolution
Old 01-13-2015, 09:53 PM   #1
Bdeysher21's Avatar
Region: Delaware
Suspension Clunk
Hi guys, a few weeks back, I installed some new suspension parts in my 2013 v6. When first driving it I was hearing a LOT of clunking noises when i would turn at slow speeds such as pulling out of the driveway. I figured this might have been because of the close to 2in drop and still using the stock sway bar end links because they were very hard to even fit in. I looked around and bought SR Performance adjustable end links and put them at the lowest option even though it still is taller than i feel it should be. This got rid of the major clunking sounds but still some here and there, it has been about 2 weeks now and when turning into spots or doing a K turn on a small road, the clunking is pretty loud, i get a thump, thump, thump every time that i turn the wheel all the way to the left or right...
Anyone have any clue what this could be or a fix to this problem?
here is the parts that i installed:
J&M Adjustable Caster Camber Plates
H&R Super Sport Springs about 2" drop
Stack Racing Strut Tower Brace
Eibach Sway Bar kit (Front and Back)
SR Triple Adjustable Panhard Bar
SR Adjustable Sway Bar End Links
Thanks for any help guys!
Bdeysher21 is offline   Reply With Quote
Old 01-14-2015, 07:28 AM   #2
JoeyM91's Avatar
Are you sure your tires aren't rubbing at lock?
Old 01-14-2015, 07:52 AM   #3
Voltwings's Avatar
My number 1 thing to check when i get suspension clunk is greasing any bushings that have recently been installed. Being that theres a difference between "turning" and the car transferring load from one side to the other, does it happen when turning, or when transferring? Such as coming out of the driveway at an angle? You're turned, but also transferring load?
I believe those sway bars, and that PHB should have greaseable bushings. May be worth a quick once over.
Old 01-14-2015, 08:13 AM   #4
08Mustang's Avatar
I've got an terribly annoying front clunk only when I brake after lowering my car...still trying to figure out what the hell it is
08Mustang is offline   Reply With Quote
Constant clunk in front end suspension Mikeyt03 2011-2014 Mustang GT 28 01-20-2013 02:42 PM
Rear suspension clunk CaptainBeyond 2011-2014 Mustang GT 5 09-05-2012 06:14 PM
Occassional "clunk" on start up flash4353 Pre-2005 V6 Mustang 12 10-11-2007 06:12 PM
2004 Ford Mustang - clunk? lisalulu Pre-2005 V6 Mustang 7 05-08-2007 08:01 AM
08:22 AM
