Rattles! - Mustang Evolution
Old 01-14-2015, 02:46 PM   #1
lisl12's Avatar
Thumbs down Rattles!
I'm a bit disappointing that rattles are already starting in my 4month old car. There's a buzzing behind me on the driver side, rattling gauge cluster and rattling near the driver side vent/mirror..Seem to be worst when the car is cold..Any advice on fixing the rattles?
lisl12 is offline   Reply With Quote
Old 01-14-2015, 06:24 PM   #2
forceflow2's Avatar
Honestly? Your best bet is to trade it in for something that's not a Ford. Rattling is a trademark of the Ford brand on just about any car they make. It's worse when it is colder because the materials shrink ever so slightly. I am fairly certain Ford has never made a rattle-less car. Unless you're willing to cut up a bunch of strips of foam and have those stuck everywhere or try throwing dynamat at the problem, you're just going to have to live with it.
2013 V6 Premium GHIG purchased 01/16/13
forceflow2 is offline   Reply With Quote
Old 01-14-2015, 08:25 PM   #3
Kevin.Cook
Guest
Posts: n/a
You could try pulling the Cluster Bezel off and drive around to see if you can pin point the sound. The bezel just pulls right out. Make sure to lower your steering wheel. The is also a little plastic part where your Mirror adjustment switch is that you can pop off to see if it is causing it.
Old 01-14-2015, 08:34 PM   #4
I always here about the "Ford Rattle" i've owned old and new fords. i've never had one that rattles.
thegreystang is offline   Reply With Quote
Old 01-14-2015, 08:37 PM   #5
Kevin.Cook
Guest
Posts: n/a
I had an 08 Mustang where the chrome rings around the AC vent were loose and rattled. But i didn't care though because I was trading that POS in the first chance I got.
Old 01-15-2015, 04:28 AM   #6
iantrusive's Avatar
Mine's rattling in the exact same spots. Really annoying when I can hear it over my music blasting.
Sent from my Mustang.
iantrusive is offline   Reply With Quote
Old 01-18-2015, 11:33 AM   #7
I hear ya. Mine is a year old and I can't believe how fast rattles developed - in the same spots as the OP. It's the biggest disappointment I have with my car. It drives me nuts.
2014 V6 manual
Charlotte Stang is offline   Reply With Quote
Old 01-18-2015, 06:35 PM   #8
WordySanchez's Avatar
Dang, I feel lucky. I rent cars probably ~180 days a year and drive a lot of diff cars. That's how I started noticing that Fords were getting better about their build quality. I finally pulled the trigger, and bought a '12. With 60k on the clock at that. Not a single rattle. With so few miles on it, you might see if your dealership will do anything under warranty?
WordySanchez is offline   Reply With Quote
Old 01-19-2015, 09:33 AM   #9
dibstang's Avatar
Welcome to the club. I also have the same annoying sounds. My friend's mustang which is 2012 has the same rattles too. My other friend's focus St has some other rattles. I started to think that it's just a tradition.
dibstang is offline   Reply With Quote
Old 01-19-2015, 11:07 AM   #10
Strange Mud's Avatar
if my rattles were in a generic car I would be pissed but since it's a Mustang I tolerate them.
2012 V6 with suspension, shifting, stopping and sound mods.
Old 01-19-2015, 02:31 PM   #11
None of those rattles for me. 2014, 5 months old, 5K miles. There is some kind of rattle in bottom? of right side passenger door. Cannot find where it is cming from.
tucsondivots is offline   Reply With Quote
Old 01-19-2015, 03:08 PM   #12
NewMtang's Avatar
Take it back to the dealer, it should still be under warranty.
Getting a tune on monday! Rss1227 2005-2010 Mustang GT 15 04-06-2014 08:58 PM
how can i tell the difference between factory installed a/c & a dealer installed? Anthony90GT General Mustang Discussion 0 12-01-2012 10:42 PM
Getting windows retinted monday Blackedout Mustang Paint, Appearance & Detailing 23 04-09-2012 08:35 PM
Detroit Rocker cams, 4.10s, UDP, CMDP is being installed...Dyno tune is up next. Rainson 2005-2010 Mustang GT 8 01-28-2012 08:57 AM
Cenla MONDAY Sept 7th Labor Day Autocross, MONDAY, MONDAY, MONDAY, LABOR DAY SEPT 7th DarkShadows Regional Mustang Discussion 20 09-08-2009 12:24 PM
12:53 AM
