Tire Rubbing in Wheel Well - Mustang Evolution
Old 01-17-2015, 01:38 PM   #1
sguevara's Avatar
Hi Folks! Just had my stock 17" wheels and rims replaced with a stock 19" GT rims with 255/40z/19s put on them. Parking at a restaurant a few moments ago I was caught off guard when I heard tire rub! It freaked me out because I knew I was far from the curb.
Does this mean that I'll need rim spacers? When I get home I'm going to inspect to make sure that the wheel well covers are not loose.
Anyone having done a similar change had this happen?
Thanks!!!
-S
sguevara is offline   Reply With Quote
Old 01-17-2015, 01:57 PM   #2
RomanG's Avatar
Thanks!!!
-S
Interesting, i myself am running 255 35 20's all around and have no issue rubbing, are you lowered? I would defenitely inspect before hand, try and find out where its rubbing exactly
RomanG is offline   Reply With Quote
Old 01-17-2015, 02:03 PM   #3
You need steering rack stops. Roush Mustang Steering Rack Stops 404476 (05-14 All) - Free Shipping
When I bought GT Brembo 19" wheels for my previous Mustang, the tires rubbed against the lower control arm when turned all the way. Even more so when I installed lowering springs, the control arm was the only thing it touched. I later installed those steering stops, then no more rubbing.
Josh_101 is offline   Reply With Quote
Old 01-17-2015, 02:28 PM   #4
sguevara's Avatar
Josh thanks. I'll have a closer look to make sure that's it!
Old 01-17-2015, 07:25 PM   #5
VIG
VIG's Avatar
Region: Delaware
Yep, Josh is spot on.
You're going to need the steering stops. When the car has this option from the factory these steering stops are added at the factory.
VIG is offline   Reply With Quote
Old 01-17-2015, 08:01 PM   #6
Diehard's Avatar
I've heard this before and don't understand why they only list the one turning diameter for all their v6 models including the performance package that has the 255/40-R19's. I would think the steering stop would result in a larger diameter.
Old 01-17-2015, 08:05 PM   #7
Socal Stangman's Avatar
What offset are your wheels? I run a 255/35/20 and I dont rub
Old 01-18-2015, 03:33 AM   #8
iantrusive's Avatar
Do NOT get spacers. Either don't turn the wheel as tight like I do, or steering stops. I've heard spacers are incredibly dangerous from many people.
Sent from my Mustang.
iantrusive is offline   Reply With Quote
Old 01-18-2015, 07:40 AM   #9
Siber Express's Avatar
Ford's website used to have the steering stops listed on the page with the wheels for use on V6 cars with 16 and 17 inch wheels.
The Steering stops come on all Mustangs with 18 and up wheels so if you have a Pony Package or MCoA it already had them.
Old 01-18-2015, 09:32 AM   #10
audioAl's Avatar
I've not had any trouble like this yet, I do have 5/16" spacers all around. No trouble out of the spacers yet either.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 01-18-2015, 09:36 AM   #11
Spacers are safe if done right. I'm using spacers all around.
Old 01-18-2015, 11:55 AM   #12
RomanG's Avatar
What size are you running? Are they spacers or wheel adapters
Old 01-18-2015, 12:23 PM   #13
VIG
VIG's Avatar
Region: Delaware
Spacers aren't a great option, but they're ok if they're not too big and they're hub centric (never use lug centric).
And preferably only used on the rear wheels, not on the wheels used for steering.
IG: workshardplayshard
Old 01-18-2015, 02:41 PM   #14
iantrusive's Avatar
What size?
Old 02-05-2015, 02:07 PM   #15
Ive got a 14 v6 with 255/35R20 and 295/35R20 rear and it doesnt rub!
Ride or die!
efrain is offline   Reply With Quote
Old 02-05-2015, 02:13 PM   #16
I was in the same boat when I upgraded to Brembo wheels and tires. Now I am on 20inch MMD Axims. To my surprise these didn't rub. Then I later found stocks tires are 8.5 in offset and I think GT is 9 or 9.5. which makes them Rub. My new 20's are 8.5.
No Do not get wheel spacers. I think Steering Rack Stops are the best solution.
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX |P.S MORE TO COMEEEEE!!!!
Firstang001 is offline   Reply With Quote
Old 02-06-2015, 08:39 AM   #17
sticks123's Avatar
They just warned me of the same thing on my thread. I have a 2011 v6 and changed out the wheels and tires off a 2013 GT w/19". I only drive it to the dealership to have them changed. I noticed no tire rub. But I didn't make any sharp turns. It's parked for the winter....but they suggested I jack up the front end and turn the tires tight and spin the wheels. Still haven't got to it, but will post results after doing it!
sticks123 is offline   Reply With Quote
Squeak or rubbing noise on front left tire Mlp07 2011-2014 Mustang GT 2 02-05-2015 02:30 PM
Wheel is off center in wheel well. S197stanGT 2005-2010 Mustang GT 9 03-04-2013 02:55 AM
2004 GT 315 Tire Rubbing Issue TheJigShow 1996-2004 Mustang GT 11 11-13-2011 07:31 AM
1965 Mustang wheel rubbing and clearance question: Please advise!!? wakiza Classic Mustangs 6 08-23-2009 09:32 PM
Well well well England, you are turning into the country of the FATTIES Seph The Bar 10 02-28-2007 04:10 PM
06:59 AM
