Switched out gauges in my 2012 - Mustang Evolution
Old 01-19-2015, 01:58 AM   #1
RomanG's Avatar
I have a base v6 mustang. Recently purchased a premium gauge cluster off of ebay for 60 dollars. Have some before and after pics to show. The two new gauges (Voltage and Oil temp) aren't exactly working? the battery gauge is red and the oil temp isn't on. However I haven't taken this to the ford dealer to get it programmed. Hoping it works after it gets reset and programmed to my car.
Hoping to get it programmed this coming week. It is a very simple relatively cheap mod that can be done to spruce up a base v6 interior.
Took all of 10 minutes to get the old gauge cluster out and new one in to test out.
ID:	173799   Click image for larger version
ID:	173801   Click image for larger version
RomanG is offline   Reply With Quote
Old 01-19-2015, 02:07 AM   #2
DiESeven's Avatar
Are you stuck to that color combination?
Old 01-19-2015, 07:28 AM   #3
Kevin.Cook
Guest
Posts: n/a
You might need to enter the AS Built codes for the 2011/2012 for the ABS And IPC so everything talks to each other. Your car still thinks you have a base cluster and it is not sending the extra info to the cluster. Also, if MyColor is not working, then this may be why as well.
Old 01-19-2015, 07:30 AM   #4
Kevin.Cook
Guest
Posts: n/a
A VCM II tool will be required to make this change. I believe the dealer will only enter the codes if you supply them AND if the mileage of the swapped cluster matchers your old one. Even then, some dealers may be not willing to do this. This is why most people here buy their own VCM tool.
Old 01-19-2015, 11:19 AM   #5
RomanG's Avatar
Color on gauges still retain full ability to switch, you can see in the picture its purple. Obviously ambient lighting ect doesn't work for me.
From a little research it seems like ford charges just as much as the tool actually cost to switch over the gauge cluster, definitely going to look into that. I do have to send out the cluster for a mileage change. (3k difference).
Old 01-19-2015, 11:54 AM   #6
thats actually the next thing i wanted to do; ive been combing through ebay looking....good find on your part!
raykrieg is offline   Reply With Quote
Old 01-19-2015, 12:04 PM   #7
Kevin.Cook
Guest
Posts: n/a
Were you able to pick up a new headlamp switch bezel with the Info button? You will need this to navigate the little menu it has.
Old 01-19-2015, 12:20 PM   #8
RomanG's Avatar
I was actually navigating and switching colors fine with the stock switch. everything worked great
Switched from Poly to Spherical LCAs Napoleon85 2011-2014 Mustang GT 6 07-19-2013 08:40 PM
Switched 5V source? Jukens 2011-2014 Mustang GT 5 01-20-2013 09:44 AM
2012 Camaro SS, 2012 Mustang Boss 302, or 2012 Mustang Gt Premium? iseabail General Mustang Discussion 4 07-18-2011 10:12 PM
2012 Stang :: 2012 Ford Mustang dacriss Member Garages 0 06-15-2011 12:02 PM
check out my gauges! fast64 Pictures and Videos 20 03-23-2005 05:13 AM
11:43 PM
