Strange rattle - Mustang Evolution
Old 01-20-2015, 05:14 PM   #1
paintmann111's Avatar
Strange rattle
So about a month ago I installed BMR LCA's, BMR pan hard bar and Steeda pan hard bar brace. Everything installed smoothly, but after about 200 miles I noticed a clunking sound when going over bumps so I went to recheck the torque on the bolts. I found the right rear LCA bolts to be loose (4 turns to get to 130 ft lbs on the wrench). After tightening them the sound went away...until now.
When I got back from a trip I took the car out and the sound was back...WTF, but since I am in CT at my apartment I had to bring it to the dealer for them to check (no access to ramps). They put it on the lift and checked all the bolts, but all were within spec and tight...So what could be causing this sound? Its only over bumps and the bigger the bump the louder the clunk...Help please.
paintmann111 is offline   Reply With Quote
Old 01-21-2015, 07:09 AM   #2
JoeyM91's Avatar
Did you lube the zerk fittings? Dry bushings can cause a clunk.
Old 01-21-2015, 10:57 AM   #3
Figured it out. It was a loose adjuster nut on the Panhard bar. Somehow it backed off...lol
Old 01-21-2015, 11:41 AM   #4
Voltwings's Avatar
loctite. Not something you want happening.
Old 01-21-2015, 01:24 PM   #5
I was going to but I don't have a heated garage and that stuff refuses to set up when it's 5* out.
Strange rattle... The Puma 2011-2014 V6 Mustang 16 11-16-2015 02:47 PM
3.7 6spd strange rattle on accelerating dwilder14 2011-2014 V6 Mustang 10 11-05-2014 04:54 PM
Dash Rattle?? Tranny Rattle?? ricklmesa Pre-2005 V6 Mustang 0 03-08-2006 07:19 PM
Found something strange. Ghostrider304 Pre-2005 V6 Mustang 6 05-01-2005 11:44 AM
am i the only one who finds this strange? ItWouldAppearSo The Bar 4 12-11-2003 08:30 AM
02:33 PM
