Advice on lowering - Mustang Evolution
Old 01-20-2015, 08:46 PM   #1
Will2329's Avatar
Advice on lowering
Today I put on my new wheels and tires and they look amazing but it's time to close that gap. Am looking to get the SR performance springs from AM which seem fine but my question is should I add the adjustable panhandbar? Any idea of what a shop would charge to install all of this? Or anything else I should know about lowering in general? Click image for larger version
Name:	ImageUploadedByMustang Evolution1421811987.851422.jpg
1BMF-v6
Roush axle back exhaust
BBK cold air induction system
Bama Performance Tune
Raxiom LED licence plate bulbs
Black GT500 style spoiler
Will2329 is offline   Reply With Quote
Old 01-20-2015, 09:25 PM   #2
08Mustang's Avatar
If you're gona lower then yeah you'll want the adjustable panhard bar. And either camber bolts or plates.
08Mustang is offline   Reply With Quote
Old 01-20-2015, 09:27 PM   #3
Matts14fp6's Avatar
Definitely get an adjustable panhard bar, I'm running the same setup just with a lot more parts, AM, has several great adjustable panhard bars to choose from and your probably looking at 300-400 in labor unless you know someone
Matts14fp6 is offline   Reply With Quote
Old 01-20-2015, 10:17 PM   #4
Will2329's Avatar
So with the springs and the panhand bar, what would the camber bolts be used for exactly?
1BMF-v6
Old 01-20-2015, 10:28 PM   #5
Commercial Member
au01st's Avatar
Correcting the camber in the front wheels which will prevent them from wearing prematurely and keep maximum contact with the road.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 01-21-2015, 12:04 PM   #6
Voltwings's Avatar
With a drop of around an inch or so you dont need camber bolts, my alignment was still in spec after a ~1" drop, and honestly Camber bolts have a slightly higher fail rate than i am comfortable with. Camber plates on the other hand, are amazing, but more expensive.
Any time you lower though, a panhard bar is certainly necessary.
Old 01-21-2015, 07:58 PM   #7
Will2329's Avatar
Which springs did you buy?
1BMF-v6
Old 01-21-2015, 08:08 PM   #8
gkcontra's Avatar
If lowering can you go with the watt's link instead of the panhard bar?
gkcontra is offline   Reply With Quote
Old 01-21-2015, 08:43 PM   #9
JoeyM91's Avatar
The Whiteline unit replaces the panhard bar.
Old 01-22-2015, 06:35 AM   #10
Voltwings's Avatar
These: http://www.americanmuscle.com/eibach...-2011gtv6.html
Granted, i have a GT, the shocks / struts from my car (along with these springs) are now on my Fiance's V6 and it sits pretty similarly to how it did on my GT.
^^ This, a panhard bar replaces a panhard bar, they're just a lot more expensive, although exponentially "better."
Old 01-22-2015, 06:39 AM   #11
2011fastford's Avatar
Region: New Mexico
i used the camber bolts made by eibach actually helped
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 01-22-2015, 07:14 AM   #12
Sterlingbeast5.0's Avatar
I did Eibach sportline springs and camber bolts. Also did Panhard. IF you are going to do anything about traction I would suggest doing the upper and lower control arms at the same time to save installation money. Also depending on your milage you may want to do shocks and struts as well. I did springs, shocks, struts, panhard, UCA and LCA's with alighnment and paid $520. BTW, whenthey go to do it there is about a 75% chance the strut mounts will come apart so may want to get those as well.
Old 01-22-2015, 07:15 AM   #13
audioAl's Avatar
2014 DIB 3.7 w/ sport shift "Blue Cyclone"
My 12 was a learning affair, I only did rear springs and adj. panhard. Bad idea, now when I lower I am using coil over's, so when a helicopter buzzes me I'll be unafraid!
Name:	tn_Helicopter & Mustang 011.JPG
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 01-22-2015, 07:22 AM   #14
Will2329's Avatar
Only 4800 miles on mine, shocks and struts? Couldn't imagine
1BMF-v6
Old 01-22-2015, 07:29 AM   #15
JoeyM91's Avatar
The point to replacing them isn't always because they're worn out. A good set from Koni, Bilstein, etc will outperform the stock in just about every way except possibly a small sacrifice in ride comfort.
Old 01-23-2015, 07:37 AM   #16
When I installed sr springs in my previous mustang, I only did the panhard bar as well. The front end was still within spec but very close to needing camber adjustment.
Josh_101 is offline   Reply With Quote
Lowering advice. 03gteddy 2005-2010 Mustang GT 0 06-28-2014 01:29 PM
Lowering my Coyote need some advice GE3G 2011-2014 Mustang GT 15 06-26-2012 10:19 PM
First Post/ Need advice on lowering my 02 GT 02GT_BLACK 1996-2004 Mustang GT 3 10-02-2006 02:30 PM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
Need some engine advice B4 I go to the races Rellik Pre-2005 V6 Mustang 24 07-17-2003 06:16 AM
11:24 AM
