2012 v6 random misfire? - Mustang Evolution
Old 01-21-2015, 11:05 AM   #1
Yesterday I was driving and going onto an on ramp that is slightly elevated. I was in 2nd gear approaching 5000 RPM just about to shift to sixth gear due to the speed limit of 50. It was at this point the engine began to sputter and go all the way down to an idle and the check engine light began flashing. I quickly put it into neutral, while the engine barely remained alive and when the engine light stopped flashing the car regained it's normal idle and I continued to drive the couple miles home. When I got home I checked the DTC code with my tuner and nothing came up, I also let it run for a little bit before going to bed. Then this morning I woke up and let it run a bit and then checked again for DTC code and nothing. So I returned the car to it's stock tune and again checked the DTC and again nothing. It was idling normal so I decided to drive it to school. It ran fine on the way to school and I even revved it up to 4000 in my drive way to see if it would misfire again, it did not. I am unsure of what to really do or if anything is wrong. The car is running fine it has seen less than 10 miles since the misfire last night. Any help is appreciated.
UPDATE: the check engine light now comes on after 15 seconds of turning the key on but not starting the engine. The check engine light flashes 8 times then goes away. Still no engine light when I'm driving. However, I've noticed I'm only getting 14-15 MPG and the exhaust smells gasser then usual.
Mods = Bama SCT flash tuner, Borla Stinger S type mufflers, and an Air Raid CAI
gmnichols is offline   Reply With Quote
Old 01-21-2015, 12:41 PM   #2
RaceRed3.7's Avatar
Originally Posted by gmnichols View Post
Yesterday I was driving and going onto an on ramp that is slightly elevated. I was in about 2nd gear approaching 5000 RPM just about to shift to sixth gear due to the speed limit of 50. It was at this point the engine began to sputter and go all the way down to an idle and the check engine light began flashing. I quickly put it into neutral, while the engine barely remained alive and when the engine light stopped flashing the car regained it's normal idle and I continued to drive the couple miles home. When I got home I checked the DTC code with my tuner and nothing came up, I also let it run for a little bit before going to bed. Then this morning I woke up and let it run a bit and then checked again for DTC code and nothing. So I returned the car to it's stock tune and again checked the DTC and again nothing. It was idling normal so I decided to drive it to school. It ran fine on the way to school and I even revved it up to 4000 in my drive way to see if it would misfire again, it did not. I am unsure of what to really do or if anything is wrong. The car is running fine it has seen less than 10 miles since the misfire last night. Any help is appreciated.
You're fine man! Dont sweat it! Drive it like a boss and just keep rollin
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
Old 01-21-2015, 01:02 PM   #3
natestang07's Avatar
So you were shifting from second to sixth?
Old 01-21-2015, 01:12 PM   #4
no I was in second and going to put it into 6th but then it misfired and began to die. When the misfire happened i immediately put it into neutral from 2nd.
Old 01-21-2015, 01:15 PM   #5
Dcauchon's Avatar
Was your tank full ? Maybe **** in the tank....sometimes it happens when you tank is almost empty and it sucks the bottom of it while climbing a hill or something like that...
Airaid Bama tune/Hood strut/MBRP axel back
Dcauchon is offline   Reply With Quote
Old 01-21-2015, 01:18 PM   #6
No I have about 3 quarters a tank, 87 Octane I believe.
Old 01-21-2015, 07:46 PM   #7
paintmann111's Avatar
If it happened while using the bama tune I would do a data log and have them take a look at it to make sure everything is within spec. Voltwings on here can help you if you are unsure of how to do one.
paintmann111 is offline   Reply With Quote
Old 01-21-2015, 07:48 PM   #8
How do I datalog?
Old 01-21-2015, 09:00 PM   #9
VIG
VIG's Avatar
Region: Delaware
You're sure it was the CEL and not the traction control light?
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 01-22-2015, 05:52 AM   #10
Strange Mud's Avatar
internet guess = throttle body
sudden rpm change / large TB movement
key word guess
Old 01-22-2015, 06:07 AM   #11
Yes It was the check engine light. I looked at the manual and it said when the light is flashing while driving that means that a misfire is occurring. I've experienced a lose of traction with traction control on. It was defiantly not it but thanks for the reply
Old 01-22-2015, 08:26 PM   #12
Sorry. Pet peeve of mine.
Where do you think it sucks gas when the tank is full?
cherry3m is offline   Reply With Quote
Old 01-22-2015, 09:56 PM   #13
Waylap1's Avatar
Region: New Hampshire
". When I got home I checked the DTC code with my tuner and nothing came up, I also let it run for a little bit before going to bed. Then this morning I woke up and let it run a bit and then checked again for DTC code and nothing. So I returned the car to it's stock tune and again "
There's your problem. You've tuned your car. Welcome to your future of check engine lights.
If you're in a state that has vehicle inspections, you will grow to hate tunes and never go that route again.
Waylap1 is offline   Reply With Quote
2012 v6
Flashing Check Engine light, Random Misfire code Crystalwilliams Pre-2005 V6 Mustang 5 10-14-2014 03:38 PM
Random misfire codes 67mustang97 1996-2004 Mustang GT 4 06-20-2013 11:07 PM
random misfire at idle 1995 v6 95convertable Pre-2005 V6 Mustang 5 04-16-2013 08:52 AM
I need some advice ... i keep getting code p0300 random misfire? cruz Pre-2005 V6 Mustang 1 03-22-2010 10:29 PM
06:15 PM
