Noise when I put my car in Park? - Mustang Evolution
Old 01-25-2015, 09:40 PM   #1
DiESeven's Avatar
Hey all,
It's me again. I have a quick question concerning my 14 v6. I installed my JLT CAI and uploaded my revised BAMA 93 Performance tune (I was running a 93 Performance tune before I installed the JLT also) roughly ~7 days ago. In the last ~4 days, I've noticed that when I come to a stop and put my car in PARK the engine/transmission vibrates. It does that almost stalling vibration that a manual does when you release the clutch but aren't giving it enough gas.
I've never had this happen before until the last couple of days. Anyone have any ideas if it's the tune/cai or something else? Any input appreciated.
note: only mods are the tune and the jlt cai.
Old 01-25-2015, 09:43 PM   #2
Commercial Member
au01st's Avatar
Does the idle RPM drop?
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 01-25-2015, 09:44 PM   #3
DiESeven's Avatar
Yes, it has dropped on each occasion. I'm guessing it's as if the car is going to stall but saves itself.
Old 01-25-2015, 09:46 PM   #4
Commercial Member
au01st's Avatar
Should be an option to raise it in the tuner.
Old 01-25-2015, 09:53 PM   #5
DiESeven's Avatar
The tuner has it set at 650 (always has, never had issue previously). It drops below 650 for a second, accompanied by the stall-like vibration, then goes back and idles perfectly fine at 650. It's only the moment I slide it in to Park.
Old 01-25-2015, 10:38 PM   #6
Matts14fp6's Avatar
Bump it to 700 and you should be fine
Matts14fp6 is offline   Reply With Quote
Old 01-26-2015, 12:06 AM   #7
JoeyM91's Avatar
Data log the tune for right when it happens and then get back to the tuner and tell them what's going on.
Noise when shifting in to park! 2000v6stang Pre-2005 V6 Mustang 3 01-13-2014 08:27 PM
weird noise while in park arturo55 2011-2014 V6 Mustang 5 03-28-2013 12:52 PM
Women Can't Parallel Park (and something about Ford's Active Park Assist) OsirisGuy The Bar 8 09-24-2009 09:03 PM
car wont shift out of park Kyle Pre-2005 V6 Mustang 19 06-03-2005 02:10 PM
2nd Annual CJMF Car/Truck Show AUG 28th - Raceway Park 2001 Yellow GT Regional Mustang Discussion 10 09-01-2004 02:39 PM
09:28 AM
