Dash vibrating - Mustang Evolution
Old 01-30-2015, 06:45 PM   #1
Matts14fp6's Avatar
Dash vibrating
Does everyone else's dash vibrate?
Matts14fp6 is offline   Reply With Quote
Old 01-30-2015, 06:48 PM   #2
Commercial Member
au01st's Avatar
No. My mirror does. Working on a fix for that as soon as the dealer figures out the rear end.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 01-30-2015, 07:01 PM   #3
Matts14fp6's Avatar
Yeah mine rattles and my rear diff whines a little now that my I changed gears
Old 01-30-2015, 07:33 PM   #4
FastFord13's Avatar
What gears do u put?
Sent from my Nexus 5 using Mustang Evolution mobile app
Old 01-30-2015, 07:42 PM   #5
Matts14fp6's Avatar
3.73
Old 01-30-2015, 10:01 PM   #6
My dash rattles exactly on the right side where it meets the door.
Ranger052 is offline   Reply With Quote
Old 01-31-2015, 03:19 AM   #7
iantrusive's Avatar
My cluster bezel rattles and it drives me up the effin wall. I'm about 3 days away from glueing it down.
Sent from my Mustang.
iantrusive is offline   Reply With Quote
Old 01-31-2015, 06:58 AM   #8
Mine did at certain temps on far left driver side near mirror control. I pushed some foam between dash and side plastic. Has stopped the vibration.
tucsondivots is offline   Reply With Quote
Old 01-31-2015, 07:18 AM   #9
jande063's Avatar
I have all kinds of dashboard rattles. The upper DC outlet cover rattles, the far left vent surround vibrates, the top left corner has to be touched every so often to stop a rattle. If I did not know better, I would say that either Subaru or British Leyland put my interior together...
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 02-12-2015, 12:12 PM   #10
Bonsai_Fox's Avatar
My glovebox does. Its terrible. Get some black foam that you'd put under a chair to avoid scratching on wood floors and wedge it in to help get rid of rattle. Takes some tinkering but ha worked for me in past. Good luck
Bonsai_Fox is offline   Reply With Quote
Old 02-13-2015, 12:04 AM   #11
mutaz102's Avatar
I only have the rear view mirror rattles horribly. I don't know if the dealer would fix it because I'm at 39K. Any suggestion how to fix it or should I just go to the dealer, and see what they can do?
mutaz102 is offline   Reply With Quote
Old 02-13-2015, 03:10 AM   #12
Cooolbreeez's Avatar
Sounds like you guys need to turn the stereo up louder.
Cooolbreeez is offline   Reply With Quote
Old 02-13-2015, 07:55 AM   #13
Camboss123's Avatar
My rear mirror rattles a lot, but to fix it just turn up the radio!😜
Camboss123 is offline   Reply With Quote
Old 02-13-2015, 10:36 AM   #14
Matts14fp6's Avatar
Our cars are falling apart!
Old 02-13-2015, 10:40 AM   #15
Kevin.Cook
Guest
Posts: n/a
Who said they were even built right to begin with?! :O Just kidding....lol
Old 02-19-2015, 11:35 PM   #16
Have any of you pulled off the dash and reinstalled it like after putting in a radio or something? And what speed do your cars do this at. Also I have a vert are the convertible frames stronger because they don't have the top keeping things strong?
2014_MCA_Vert is offline   Reply With Quote
Old 02-20-2015, 02:13 AM   #17
tym_v6's Avatar
No dash rattles (usually what rattles is loose stuff in the glovebox or console), but I do get an occasional rattle from the driver's door lock pin at highway speeds. A bit annoying as it's within inches of my left ear...LOL.
Old 02-20-2015, 10:46 AM   #18
Yea I feel the only time I get vibration is when I'm doing like 140 but it only starts when I start to slow down.
Old 02-20-2015, 11:06 AM   #19
Kevin.Cook
Guest
Posts: n/a
140?! Lol. I don't think Ford's intentions for the V6 was to build a land rocket. XD
Old 02-20-2015, 11:07 AM   #20
I get a rattle from my rear view mirror under acceleration, but that's because of the parking pass I have hanging on it for college.
Old 02-20-2015, 12:13 PM   #21
Mine rattle due to the bad from the sub. I used a rubber o ring and wedged it between the glass and the black part that goes over the metal part glued to the window. And problem solved.
Sent from my SM-N910T using Mustang Evolution mobile app
jrdnsky59 is offline   Reply With Quote
Old 02-20-2015, 01:01 PM   #22
My wife's 2013 had a rattle / vibration that drove me crazy. It was the inside rearview mirror. Try this...just put your finger on the edge of the mirror. Does the noise stop? My dealer said they had some issues with Escapes, but had not encountered any issues with the Mustang. Replaced my mirror under warranty.
graystone2013 is offline   Reply With Quote
Old 02-20-2015, 05:42 PM   #23
Matts14fp6's Avatar
It's my dash trim
Old 02-20-2015, 09:31 PM   #24
VIG
VIG's Avatar
Region: Delaware
Yep. I have a rattle in the dash on the drivers side right up by where the vent is.
It really only happens on cold mornings. I imagine because everything contracts due to the cold and fittings get a little looser.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 02-20-2015, 10:48 PM   #25
Chaz12's Avatar
Oh damn that is hilarious. I probably laughed more than I should have. That guy said he gets some minor rattles around 140 hahaha! Oh God.
2013 Premium Performance White
Bama 91 Race tune, GT500 blue racing stripes with matching hash marks and side stripes, cold air intake, Flowmaster super 44s with Roush 4" Tips, CDC performance grille, side scoops, painted quarter windows, all lights tinted
Chaz12 is offline   Reply With Quote
Old 02-22-2015, 02:14 AM   #26
Mlp07's Avatar
Dash vibrating
The chrome rings from the cluster rattles on mine. I can hear it more in the mornings, also when I'm slowing down and brake I hear something buzz... I can hear it between the steering wheel and cluster but idk what's making that sound,it drives me crazy! It only happen when I'm braking tho. If I accelerate on the 2k rpm's (usually on 5th gear) I hear something rattle on the back of my rear seats.
Mlp07 is offline   Reply With Quote
Old 02-22-2015, 08:21 AM   #27
aleXXXps's Avatar
Every Ford my family has owned (probably 6-7) has eventually developed a rattle. My family calls it the "Notorious Ford Rattle".
My Mustang is a 2012 and has not developed it yet, but I'm waiting for it in due time...
aleXXXps is offline   Reply With Quote
Old 02-22-2015, 08:31 AM   #28
Kevin.Cook
Guest
Posts: n/a
My 2014 doesnt have one. My wife's f150 lacks chrome rings and such so hopefully hers doesnt get the rattle.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 02-22-2015, 09:45 AM   #29
Mlp07's Avatar
Do you guys go to the dealership to get the rattles fixed or live with them? I feel stupid just to go there for a rattle. Maybe I'll go to get my alarm fixed and also check if they can change the airbag plastic cover of my car. It's has like black marks like its loosing it's color idk why, haven't put anything that can damage it. I'll find an excuse to go and get my rattles fixed too.
Old 02-22-2015, 10:42 AM   #30
3.73
Are they supposed to whine after a new install?
Tek1836 is offline   Reply With Quote
Old 02-22-2015, 10:46 AM   #31
tym_v6's Avatar
Depends on how good your dealer is. Mine was just as likely to scratch or dent something whenever the car was in for service.
Old 02-22-2015, 04:28 PM   #32
Mlp07's Avatar
Same here that's why I don't like taking my car to any dealership. Don't want them damaging my car or driving it. Don't really trust them, after founding out my car was being driven by some of the ppl there.
Old 02-22-2015, 05:07 PM   #33
tym_v6's Avatar
Last straw for me was when they crushed a rocker molding and the pinch weld putting my car on their lift. If they can't put it in the air without messing up...
Old 02-23-2015, 07:00 AM   #34
Matts14fp6's Avatar
Mine do slightly. All gears will make some noise, no matter what people say
Old 04-05-2015, 11:28 PM   #35
Good morning,
does anyone know if the chrome application around the center air vent can be safely removed without breaking it?
As you can see/hear in my short video there is an anyoing squeak when you push the chrome application which leads to an anyoning sound when driving
http://youtu.be/Vx7-M1gtuoc
If someone could share a video it would be great
Thanks
Mark
hdh_mustang_v6 is offline   Reply With Quote
Really bad vibrating after dual exhaust dudeitsdylan 2005-2010 V6 Mustang 20 12-31-2012 11:08 PM
Vibrating poncho2049 1996-2004 Mustang GT 5 10-24-2012 05:00 AM
Vibrating clutch peddle Mike SVOR Pre-2005 V6 Mustang 5 08-23-2012 10:51 PM
Loud vibrating noise!!! Blackstang 1979-1995 Mustang GT 30 10-29-2011 09:56 PM
Vibrating Noise Problem Dan0066 Pre-2005 V6 Mustang 4 06-11-2006 11:53 AM
09:07 PM
