Suspension checklist/advice - Mustang Evolution
Old 02-02-2015, 09:08 AM   #1
Hello,
I recently bought a set of Eibach Sportline springs for about 150 bucks. I wanted to go with the prokits, but didnt want to spend extra for just a mild drop. From my understanding of what I have read, I will need to do the following on order to get my suspension upgraded correctly.
Purchase checklist:
New shocks, will be going with the eibach damper kit.
LCA
UCA
Adjustable panhard bar
Questions:
Will I need an LCA and UCA for the front and rear of the car? (Still a bit confused).
Are camber plates necessary and if so will I need them for the front and rear?
Will I need to get a camber kit as well?
If I upgrade the tires to 18 or 19, will there be tire rubbing issues?
Thanks for your inputs.
AznGuyNamedEd is offline   Reply With Quote
Old 02-03-2015, 03:30 PM   #2
Oh2freshstang's Avatar
UCA/LCA go in the rear. (There is 1 UCA & 2 LCAs) Make sure u also look into LCA relocation brackets since u will be lowered u will need them to correct the rear end geometry.
Caster camber plates are the same thing as a "camber kit" & they are for the front. They connect to the top of the struts. Some people go with just camber bolts instead of caster camber plates but they're known for being weaker than OEM so I would be cautious going that direction.
I would also look into Koni Orange shocks/struts. There known for being better than eibach & pretty economical.
90k Maintenance checklist Crixus 2005-2010 Mustang GT 6 09-13-2014 12:30 PM
Checklist for strut/shock upgrade UncleSpud 2011-2014 Mustang GT 5 08-18-2013 10:17 PM
head intake swap checklist 5.slow 1979-1995 Mustang GT 21 05-07-2012 08:02 PM
suspension options...need advice jmp782 Pre-2005 V6 Mustang 2 10-12-2008 03:12 PM
desire advice... stock investment type advice... dark The Bar 4 04-23-2006 06:07 PM
04:46 AM
