Courtesy lights stuck on - Mustang Evolution
Old 02-05-2015, 09:55 PM   #1
Region: Arkansas
I noticed today driving home from a friends house that my two dome/courtesy lights where on and very hot suggesting they had been on for awhile. checked both doors and they were closed tightly. after getting home I open and shut both doors and they would not turn off. normally this would be due to a bad door jamb switch but I looked all around both doors and could not find any??? any suggestions? I pulled the fuse to turn them off for the time being. hope its something simple that I'm overlooking. thanks
Cold Silence is offline   Reply With Quote
Old 02-05-2015, 11:47 PM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
To the left of your steering wheel, check this switch. If it's all the way up, that's why your lights are on. Roll it down and you'll feel a sort of click. It's your dash light adjustment switch but rotating it all the way up also turns on your dome lights
2012 Kona Blue 3.7L V6:
Old 02-06-2015, 12:37 AM   #3
Gravydog316's Avatar
Maybe one of the door switches needs replacing, or a good cleaning.
Or you need a new timer.
Old 02-06-2015, 08:06 AM   #4
Strange Mud's Avatar
ya could have used the light to read your owners manual.....
poor impulse control
Old 02-06-2015, 08:11 AM   #5
Kevin.Cook
Guest
Posts: n/a
Try WhoDat's suggestion. This is something that gets bumped sometimes and causes it. Let us know if that does not work.
Old 02-06-2015, 11:06 AM   #6
Region: Arkansas
WhoDat was correct. thank you. I've never touched that as long as I have owned the car and didn't even think it could have been the problem. ha. thanks guys.
Old 02-06-2015, 05:39 PM   #7
Siber Express's Avatar
Don't worry, you are not the first I have told or seen told about the Dimmer, most cars do not even have that anymore.
Old 02-06-2015, 06:08 PM   #8
Waylap1's Avatar
Region: New Hampshire
Took the time to find and pull the right fuse. Didn't know about dimmer.
This should be a meme
Waylap1 is offline   Reply With Quote
Courtesy of Mr. Mikes.com - what do you guys think? Kustumb Mustang Paint, Appearance & Detailing 12 02-27-2014 09:25 PM
1964-2013 Mustang (All) Courtesy Door Light Image - Mustang Logo msgt46270 2011-2014 Mustang GT 22 08-21-2012 08:02 AM
*free courtesy check* 05MUSTANG4.0L Pre-2005 V6 Mustang 9 06-26-2012 07:54 AM
05:01 AM
