service engine soon indicator went off - Mustang Evolution
Old 02-06-2015, 01:18 PM   #1
elkoritaNAY's Avatar
what the heck does that mean?
Flowmaster force 2 exhaust, jlt cai, x4 bama tuner, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit, Bbk shorty ceramic tuned headers
elkoritaNAY is offline   Reply With Quote
Old 02-06-2015, 01:29 PM   #2
Socal Stangman's Avatar
It could be a 100 different things. Go to Autozone, spend 40.00 and buy a code reader. Then come back with the results.
Wait you have a tuner right? Use that to read the code.
Old 02-06-2015, 01:47 PM   #3
02 sensor negative current control circuit/open bank 2 sensor 1 ...?
Old 02-06-2015, 01:55 PM   #4
JoeyM91's Avatar
Possibly a bad O2 sensor. I would say the O2 extensions, but you don't have longtubes.
Old 02-06-2015, 01:59 PM   #5
all I need is replacement? or what? can I wait for the service?
Old 02-06-2015, 02:00 PM   #6
JoeyM91's Avatar
What's the code exactly? Should be P something.
Depending which O2 sensor it is, it can cause rough idle and odd behavior.
Old 02-06-2015, 02:02 PM   #7
How long ago did you install the shorty headers? Reason I ask, is it's very easy to disconnect the passenger side o2 sensor harness when manipulating the headers and your hands around in there to get to that bottom bolt closest to your firewall. I pulled mine loose without even knowing it during install and got the same code. Plugged it back in code gone. Get a flashlight and look around below the passenger side header close to the firewall. I'm betting you'll find the connector from the o2 sensor hanging out down there.
2012 Kona Blue 3.7 MT82
Airaid CAI, Flowmaster A-back, BBK ceramic shorties, black enkei raijin 18x8.5, Steeda ultralites/pro action dampers, whiteline PHB & brace
RJW Aggressor matte black stripes, GT bumper/CS valance/Saleen grille, AM black shift knob
steviedon is offline   Reply With Quote
Old 02-06-2015, 02:03 PM   #8
p2254
Old 02-06-2015, 02:06 PM   #9
JoeyM91's Avatar
That's going to be upstream left, so the ones just below the headers on your drivers side.
I'd check what Steve suggested first. Make sure the wire is connected well and hasn't come loose.
Worst case scenario, take out the O2 sensor from the other side and swap them. See if you get a different code. If you do, it's likely a bad sensor.
Old 02-06-2015, 02:08 PM   #10
JoeyM91's Avatar
Also saw this one it. Might try reflash ing back to stock and then reapply your tune as well:
http://www.moddedmustangs.com/forums.../topics/361081
Old 02-06-2015, 02:09 PM   #11
ahh okay thanks guys... I clear the dtc code w the tuner... it didn't appear again but good advice I'll check it out and see if it's loose or not
Old 02-06-2015, 02:10 PM   #12
I installed the headers maybe oct nov of last year
Old 02-07-2015, 11:56 AM   #13
update: I clear the dtc code via the tuner. drove the car a bit and the light hasn't come off again. in hoping it was just a malfunction in the instrument panel or something. did call ford and will have it evaluated though. I was honest with them and told them about my mods up front let's see if they make a big deal out of it.
Old 02-07-2015, 12:54 PM   #14
One thing to remember is there is a reason why dealerships can charge 100+ an hour to diagnose/ fix a car. The check engine light code generally a starting point on how to fix the car not a simple pointer on how to fix a car. If you throw an O2 code that generally means the sensor is not reading within range. It can often be the sensor although it can be a lot of other things upstream. For example if you have a pinhole exhaust leak it can occasionally cause it to read out of range and throw a code. Point I am trying to make is be sure to do research before replacing anything or else you may be wasting money.
StarzTA17 is offline   Reply With Quote
Old 02-07-2015, 01:05 PM   #15
if it is a faulty O2 sensor it'll be free under warranty...
Old 02-07-2015, 04:59 PM   #16
Commercial Member
au01st's Avatar
With aftermarket headers, curious to see what the dealer would say and if they would really replace it for free...
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 02-07-2015, 05:05 PM   #17
yeah I've had zero contact w the dealer since purchasing in October 2013. a faulty O2 sensor is not mod fault I guess
Old 03-13-2015, 09:35 PM   #18
Hey everyone the sensor went off again almost after one month since I cleared. I cleared it again, but my question is should I be worried or what?
Old 03-13-2015, 10:08 PM   #19
aleXXXps's Avatar
Sounds like it may just be dirty? If you leave it, you probably can go a good while without issues. But I'd change it as soon as possible just to avoid problems down the road.
aleXXXps is offline   Reply With Quote
Service Engine Soon light on WhiteStang99 Pre-2005 V6 Mustang 20 07-22-2015 08:42 PM
service engine soon light arggggh! niko Pre-2005 V6 Mustang 9 07-24-2007 12:38 AM
Check Fuel Cap & Service Engine Soon Light??????? mattstang Pre-2005 V6 Mustang 8 12-25-2006 01:33 PM
service engine soon light (ugh) johnww Pre-2005 V6 Mustang 9 03-17-2005 05:39 PM
service engine soon light tek55 Pre-2005 V6 Mustang 4 11-13-2003 02:00 PM
11:48 PM
