Driveshaft install - Mustang Evolution
Old 02-07-2015, 09:58 PM   #1
Harm_3.7's Avatar
Driveshaft install
Hey guys I'm new to the forums and had a quick question about my car. Today I got my one piece aluminum driveshaft installed and I hear a howling like noise when I'm around 70ish mph. Anybody know what this could be?
Harm_3.7 is offline   Reply With Quote
Old 02-08-2015, 08:26 AM   #2
Kevin.Cook
Guest
Posts: n/a
Does it sound like its coming from the engine bay or underneath the car?
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 02-08-2015, 01:51 PM   #3
Harm_3.7's Avatar
It's sounds like it's coming from the rear. I also have 3.73 gears installed but only started to hear this noise when I installed my driveshaft.
Old 02-08-2015, 02:12 PM   #4
Kevin.Cook
Guest
Posts: n/a
Maybe lift it and reinspect the bolts. Also, make sure it clears everything else and nothing is rubbing.
---------- Post added at 03:12 PM ---------- Previous post was at 03:11 PM ----------
Also, sometimes you can get sounds from the wheels at higher speeds, so make sure to check that they are properly inflated.
Old 02-08-2015, 02:25 PM   #5
Harm_3.7's Avatar
Tired should be good because I just got an oil change as well from ford and they check the tire pressure. Also I did not install the bolts I had it done by a friend at his shop. He torqued the bolts to about 80 ft pounds is that what they are supposed to be torqued too?
Old 02-08-2015, 02:27 PM   #6
Socal Stangman's Avatar
I tend to think it's more of a gear issue.
Old 02-08-2015, 02:35 PM   #7
Harm_3.7's Avatar
I've had the gears installed for over a month now and never heard this noise before.
Old 02-08-2015, 02:45 PM   #8
GrabberMeBlue's Avatar
I'm wondering if the two piece stock driveshaft dampens the sound more and now that you put a one piece aluminum driveshaft on, the sound from the steeper 3.73 gears is more noticeable.
2012 Grabber Blue Mustang Convertible V6 Premium
1979 Solar Gold Trans Am
1995 Bright Red Trans Am Convertible
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 02-08-2015, 02:47 PM   #9
Kevin.Cook
Guest
Posts: n/a
Not sure if you get this, but now that I installed my driveshaft, i get a clunk sometimes when changing gears.
Old 02-08-2015, 02:53 PM   #10
This could be as well.
Old 02-08-2015, 02:54 PM   #11
Harm_3.7's Avatar
Would you guys think my magnaflow catback rubs on the driveshaft since it's bigger piping than stock?
Old 02-08-2015, 03:02 PM   #12
Look at the driveshaft. If it is rubbing, you should easily see a line around the driveshaft where it is.
1979 Gold Trans Am
Old 02-08-2015, 03:12 PM   #13
Kevin.Cook
Guest
Posts: n/a
Get some loud mufflers. This should fix it
Old 02-08-2015, 03:14 PM   #14
Harm_3.7's Avatar
Thanks for the help guys I will be taking it back to where I got my gears installed tomorrow to see if it is the gears or the drive shaft.
Old 02-08-2015, 03:16 PM   #15
Harm_3.7's Avatar
Haha already have the magnaflow competition catback I don't know if there's much louder than that or is there 😱
Old 02-08-2015, 05:57 PM   #16
Kevin.Cook
Guest
Posts: n/a
No mufflers!
Old 02-08-2015, 10:34 PM   #17
Don't open that can of worms😝
toad 185 is offline   Reply With Quote
Old 02-09-2015, 07:44 AM   #18
I don't think anything should be making a noise.
When I had my Axle exchange aluminum driveshaft installed it did away 100% of the clunk and does not make any noise at all.
I would think Harm_3.7 has a rear differential whine that needs to be taken care of. I hope the shop that installed it does not give him the old" IT IS SUPPOSED TO SOUND LIKE THAT "CRAP" and redo it. The problem is that a few things will need to be purchased again and shops hate to do that.
Of course at 70+ MPH it could be wind or tire noise. Hopefully just tire howl.
Old 02-09-2015, 12:43 PM   #19
Harm_3.7's Avatar
Taking it back to the shop later today lets hope they don't try to pull that on me!
Old 02-09-2015, 12:49 PM   #20
Kevin.Cook
Guest
Posts: n/a
Well you can usuall gauge where the shop techs are as far as mechanical skills by asking them if your muffler bearings are still ok. This will give you all the info you need in order to determine if you should leave your car with them.
Old 02-09-2015, 01:10 PM   #21
Harm_3.7's Avatar
Haha I actually did my research before I left my car with them. I don't even trust my dealer with my car 😜
Old 02-09-2015, 05:49 PM   #22
Harm_3.7's Avatar
So guys I got the gears checked out and they check out to be wearing right and everything. They even redid the whole install and it still seems to make the noise. Thankfully I didn't have to pay again! So could use some opinions on what should be my next step?
Old 02-09-2015, 06:55 PM   #23
Kevin.Cook
Guest
Posts: n/a
You could get it on a lift with someone in the car and have them put it in drive and accelerate. Then you check under the car and see what is causing it. As long as the rear wheels arent on the ground, the car shouldnt go anywhere. And this will allow you to see them accelerate to whatever speed you need them to in order to diagnose.
WIN A 2015 Driveshaft Shop Driveshaft & Half-Shafts at AmericanMuscle! AMAlexLazarus 2015 Mustang GT 13 02-22-2015 02:54 PM
2015 Mustang GT Driveshaft Shop Aluminum DS Steeda Install tj@steeda 2015 Mustang GT 0 01-30-2015 08:01 AM
Driveshaft install without a lift dblhelx General Mustang Discussion 11 08-28-2014 06:31 AM
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
install your own aluminium driveshaft? roushcoyotepony 2011-2014 Mustang GT 12 01-04-2013 08:31 AM
01:20 PM
